In-Wall Speakers
Nice North America Carries On The SpeakerCraft Tradition at CEDIA 2023
Under new ownership, the SpeakerCraft, ELAN, and Panamax brand names will be rebranded as Nice.
Nice Audio Products
Nice, a global leader in home and building management solutions, will be showing several audio products from September 7-9, 2023 at the CEDIA Expo in Denver, Colorado.
The products include:
  • SC-IC3 Small Aperture Speaker
  • SC-IC-SUB8 Small Aperture Subwoofer
  • SC4-100 4-Channel Amplifier
  • SB-40P Passive Soundbar
  • AIM MK3 Speakers
These products are the first series of advanced, Nice-branded audio solutions as part of the company’s broader transition of the SpeakerCraft brand. In addition, they also plan to announce ELAN and Panamax energy management products that will round out their whole home management solutions by the end of 2023.
From Jeff Shaw, Vice President of Product Management: “We are thrilled to build on the SpeakerCraft legacy with the first in a new series of Nice Audio solutions…With this next stage, we are committed to enhancing the customer and partner experience through continued innovation, performance, and flexibility. In doing so, we intentionally optimized these products to work together as a complete system or as standalone devices to  meet the needs of integrators and designers.”
Nice SC-IC3 Small Aperture Speaker and SC-IC-SUB8 Small Aperture Subwoofer
Nice SC-IC3 Small Aperture Speaker and Nice SC-IC-SUB8 Small Aperture Subwoofer
This small aperture speaker provides flexible installation options with both round and square grilles included and flush mount kits available. The Nice SC-IC3 is a high-performance 3.5-inch in-ceiling speaker designed to blend in with the decorative needs of modern homeowners. With a carbon fiber woofer, a 1-inch aluminum tweeter, and a custom crossover design, the SC-IC3 is designed to deliver impressive, dynamic sound through a 4.75-inch opening.
  • Power Handling (Watts): 30 – Minimum / 70 – Maximum
  • Frequency Range: 70Hz-20kHz
  • Impedance: 8 Ohms
  • Sensitivity: 78 db
  • Weight: 0.7 lb
  • Depth Behind Wall: 3.5”
  • Dimensions (Diameter): 5.25” (with Grille)
  • Shipping Dimensions: 6 x 8 x 8 inches (155 x 200 x 200 mm)
  • Shipping Weight: 2.2 lb
The Nice SC-IC-SUB8 High-Performance Small Aperture In-Ceiling passive Subwoofer incorporates an 8.27-inch driver and filtering circuits that remove unwanted frequencies, a custom woofer, and dual 1.5-inch voice coils resulting in optimal performance.
  • Woofer: Material Polypropylene
  • Hole: Cutout Dimensions 4.75-inches
  • Power Handling: (Watts) 50 – Minimum / 100 – Maximum
  • Frequency Range: 20Hz~300Hz
  • Impedance: 8+8 Ohms
  • Sensitivity: 71 dB
  • Weight: 32 lbs
  • Cabinet (LWD): 25.188 x 12 x 7.125-inches (640 x 305 x 181mm)
  • Port Tube: 19-inches (483mm) Length, 3.25-inches (83mm) Diameter
  • Sub Speaker Diameter:: 5.25-inches (with Grille)
  • Shipping Dimensions:12 x 36 x 15-inches (302 x 907 x 874 mm)
  • Shipping Weight: 34.4 lbs
Nice SC4-100 4-Channel Analog Filtering Amplifier
This amplifier incorporates flexibility and convenience for distributed audio and home entertainment applications. The SC4-100 is powerful and easy to configure and install. Up to 100 watts of power can be provided to each of the four independent channels. The amplifier is also bridgeable in pairs with enables 2, 3, or 4-channel configurations.
Each channel also has two selectable analog high-pass filters to optimize the performance of connected satellite speakers or subwoofers, without the hassle of DSP or IP. Other features include Independent level control, single indicators, audio sensing, and in/out triggers.
Everything is housed in a single rack mount chassis.
  • Input Sensitivity: 0.08V
  • Gain: 30 dB
  • THD+N: 0.05
  • Frequency Response (1W): 20~20K
  • S/N Ratio: 98dB
  • Auto Sens Level: 5mV
  • Crosstalk at 1KHz: 80dB
  • Crosstalk at 10KHz: 70dB
  • Noise: 0.3mV
  • Dimensions (LWH) 11.5 x 17 x 1.5 in
Nice SB-40P Passive Soundbar
The SB-40P 3-channel passive soundbar is designed to deliver dynamic sound with an independent center chamber that produces enhanced dialog clarity, and left and right chambers that create a wide soundstage for music and movies. The combination of graphite, polypropylene, and carbon fiber materials, produces exceptionally clear and dynamic audio perfect for a stand-alone home entertainment solution or integrated into a whole home audio system.
  • Woofers: 6 x 3-inch Graphite Woofers
  • Tweeters: 3 x 1-inch Titanium Dome Tweeters
  • Power Handling: 60 Watts
  • Frequency Response: 140HZ – 20kHz
  • Impedance: 6 ohms
  • Sensitivity: 88dB 2.83V/1m
  • Dimensions (HWD): 5.18 x 39.8 x 2.75 inches
Nice AIM MK3 Speakers
The AIM MK3 incorporates an innovative ARC Tweeter Array, amiable woofer, and WavePlane technology combined with a newly designed crossover to support the most demanding audio content and tailored to deliver explosive dynamics, three-dimensional detail, and rich musicality for high-fidelity immersive audio platforms. With space-age materials, acoustic innovations, and five models, the Nice AIM MK3 series offers flexibility and performance.
Full specifications are forthcoming on these loudspeakers at CEDIA 2023.
Availability and Purchasing
To place an order for the Small Aperture Speaker, Small Aperture Subwoofer, 4-Channel Amplifier, Soundbar, or AIM MK3 speakers, please contact your local Nice dealer, regional sales manager or go to: https://go.niceforyou.app/audio.
Building on the legacy of SpeakerCraft, Nice Audio Solutions solidifies the company as an industry leader in the speaker category.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
In-Wall Speakers
Enjoy low bass performance down to 30Hz from subwoofers hidden in your wall that are only 4-inches deep.
In-Wall Speakers
Ambisonic leverages expertise in outdoor speakers for new line of in-wall speakers using planar ribbon technology for home theater.
In-Wall Speakers
Simply paint over Stealth Acoustics in-wall speakers to enjoy sound that you never have to see.
In-Wall Speakers
ASCENDO's home theater speaker system delivers reference level performance from specially designed in-ceiling speakers.
Denon's latest A/V Receiver offers 11.4 channels of amplification and 13.4 channels of audio processing as an AV preamp. Coming early 2024.
