DAPs
The Newer iRok 6-in-1 Digital Audio MP3 Player from Jaton
Jaton started our new portable product, the iRok Digital Audio Flash MP3 Player. With a extreme 0.07 lbs weight and a 2.5″ x 1.25″ x 0.55″ super mini size with a rechargeable battery, FM Radio, Voice Recoding … It would be a best flash type MP3 player in the market.
Here are some specifications:
— 1GB or256MB memory size model of the iRok MP3 Player
— For screen, the iRok uses the latest and hottest OLED display with double colors, a great taste that gives you a clearer and sharper view even without the back light effect.
— Built-in FM radio takes your favorite stations anywhere you go, along with its automatic or manual station searching options, and a memory that stores up to 30 stations!
— Built-in Mic-in voice recorder and Line-in recorder give you the convenience of recording sound clips anytime and anywhere.
— High speed USB 2.0 connection guarantees the fastest connection between the iRok MP3 player and your PCs
— Five equalizer modes, which include Normal, Jazz, Classical, Rock, and Pop, give you the options of fine tuning the specific kinds of music you enjoy.
— Forget about changing or charging the AA batteries. iRok comes with a built-in USB rechargeable Li-ion battery that can last up to 30 hrs of normal continuous usage!
— Multi-Language Display supports, which include characters in English, Chinese Traditional, Chinese Simplified,, and alphabets in Japanese, Korean, Euro, and Russian.
If you are looking a MP3 Player has a modern design and all features with an attracting pricing for holiday gift. Jaton iRok MP3 player will be your best choice.
Jaton is a over 20 years manufacturer of computer and consumer electronics products. Please visit www.jaton.com to know more about us and our products.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
