Laptops
New SLAPPA BulkHead PRO Laptop Series
PRESS RELEASE
SLAPPA Distribution LLC., today announced the launch of the SLAPPA BulkHead PRO Laptop series, adding new depths to the SLAPPA PRO laptop line. SLAPPA’s PRO laptop line is designed for true Road Warriors, incorporating unique material combinations and well thought out features that are important to those who are always on the go. In this new BulkHead line, SLAPPA incorporates it’s Multi-Bag system, which means each BulkHead is actually a series of bags that are attached together to make one larger bag and can be completely separated into 4 individual bags. The line is made from SLAPPA’s highly rugged and tactile Buck-Blast material that is water resistant and easy to clean. In addition to being highly protective laptop storage, the BulkHead series is designed to be used as an overnight bag or a “gig” bag for DJ’s.
“Does the market need another overpriced nylon laptop case? We thought there were plenty of those on the market, so we instead focused on engineering a completely new type of bag”, says SLAPPA President, Dominick Martinetti. “In the BulkHead we have combined top grade materials, very smart features and as is the case with all SLAPPA products, a lot of attention to detail.”
The BulkHead PRO, as it is aptly named, is the ideal carry-on bag, as it can break down into multiple bags and fit into even the smallest airplane compartments. An optional trolley with a 5-stage collapsible handle and inline skate wheels make for very efficient travel. The bag’s design allows users to consolidate a great deal of storage into one piece of luggage, and offers a tremendous amount of padded protection throughout the entire set of bags.
Features include:
• ez-zip bag connection system
• Removable comfort straps with SmartClip system for easy length adjustment
• Industrial strength, rainproof zippers with zipper head locks
• 2 zipper pullers per compartment with rubber SLAPPA logo pull
• Brushed steel SLAPPA logos
• 3 SLAPPA combination locks
• Removable phone case with a stainless steel epoxy finish belt clip
• 3-D rubber name card holder for I.D.
The SLAPPA BulkHead PRO is now available in 3 different versions ranging from $119.99 to $179.99 at www.slappa.com.
About SLAPPA Distribution LLC.
SLAPPA Distribution LLC. is a distributor of digital storage cases and accessories for digital products that are sold under the “SLAPPA” brand name. SLAPPA products have been recognized as “ground breaking” and “the best available”, and can be found at retail outlets around the globe. SLAPPA’s innovative team continues to produce quality style savvy designs for digital gear, such as CD/DVD storage cases. For more information on SLAPPA, visit the website at www.slappa.com.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
