New Series of Professional DVI-D Distribution Amplifiers Now Shipping from TV One
The TV One-task series of DVI-D Distribution Amplifiers consist of three professional units that distribute two and four DVI-D signals from a single input. The 1T-DA-552 provides two DVI outputs, the 1T-DA-554 provides four DVI outputs and the 1T-DA-564 provides four DVI outputs plus four Analog Stereo and four S/PDIF Coaxial Audio outputs. Each product in this series is compliant with HDMI v1.3 and all are HDCP Compliant.
The 1T-DA-500 Series provides a cutting-edge technology that supports Deep Colour (10-bit and12-bit) video plus new, lossless Dolby TrueHD, Dolby Digital + and DTS-HD Master Audio digital audio. In addition, all devices exhibit high bandwidth (up to 225MHz – 2.25Gbps) and support PC resolutions up to 1920×1200 and all HDTV resolutions up to 1080p. All units provide signal amplification and equalization for high performance processing of audio and video allowing the signals to travel great distances without quality loss.
A front panel switch allows the EDID reference to be selected from either a connected display on a priority basis or from an internal resolution look-up table. All DVI Distribution Amplifiers can be cascaded for expanded functionality and can also function as HDMI Distribution Amplifiers using optional cable adapters. An Rack Mounting kit can be purchased separately and allows mounting either one or two DVI Distribution Amplifiers in a standard 19″ Rack.
The suggested retail prices for the units are listed below:
1T-DA-552 – Two Output DVI-D Distribution Amplifier – £165 (€ 214)
1T-DA-554 – Four Output DVI-D Distribution Amplifier – £210 (€ 272)
1T-DA-564 – Four Output DVI-D Distribution Amplifier with Audio – £230 (€ 298)
These amazing new units along with the entire product range can be found on the TV One website, www.tvone.eu. Alternatively the Sales and Technical Department are available to answer any queries and can be contacted on +44 (0) 1843 873311 or emailed at sales.europe@tvone.com.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
