A/V Furniture & Accessories
New Potato FLPR iPhone Remote Control Adapter
Instantly Turn Your iPhone or iPod touch Into a Universal Remote Control
New Potato Technologies, an innovator and developer of iPod and iPhone accessories, has introduced FLPR™, a revolutionary new accessory and app that transforms iPhone and iPod touch into a universal remote control. FLPR lets users control multiple electronic devices, including televisions, cable and satellite boxes, stereo systems, lights, ceiling fans and just about anything else that uses an infrared remote control. The revolutionary FLPR replaces a sea of remotes cluttering up the home.
FLPR is a snap to set up. After purchasing the FLPR infrared interface and popping it into the iPhone/iPod touch dock connector, users simply download the free FLPR app from the App Store℠ online store. Once the app is launched, choose the device “type,” select “brand,” “name it” and “use it.” It’s that easy. FLPR comes pre-programmed with over 14,000 remote control codes, including all major electronics brands.
Unlike other universal remote solutions for iPhone and iPod touch, FLPR’s extensive database of over 14,000 pre-programmed remote control codes means that you don’t have to spend time learning your existing remotes “button by button.” FLPR works with hundreds of brands of devices out of box with no programming necessary.
New Potato FLPR Package
FLPR is also a learning remote. If the remote control code for that old television in the guest bedroom is not in the extensive FLPR database, you can easily teach FLPR the code for that old relic, creating a brand new remote.
The user-friendly, stylish interface of FLPR rivals that of expensive, high-end universal remotes. What’s more, FLPR can be personalized with the included free background skins. The screen for each device you control can have a distinct look so you can instantly tell the remote for the television apart from the iPod docking sound system.
FLPR has a range of about 30 feet and is powered by the iPhone/iPod touch. The free FLPR app is available now in the iTunes store.
The FLPR infrared interface is available now from the company’s website and will be in Best Buy stores nationwide on March 28, 2010 for $79.99.
Q Acoustics Q SUB Subwoofer Series in Satin Black
All under $1200, three new Q SUB subwoofers get the most out of Q Acoustics stereo and surround sound speaker systems.
TCL QM7K QD-MiniLED TV Lifestyle 2025 TCL QM7K QD-MiniLED TV Lifestyle 2025
HDTV 4K & 8K TV
With sizes up to 115 inches and fairly affordable pricing, TCL's QM7K MiniLED TV will be one to watch in 2025.
Fluance Wireless Floorstanding Speakers Lifestyle Fluance Wireless Floorstanding Speakers Lifestyle
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Arendal 1961 Loudspeakers Arendal 1961 Loudspeakers
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Placing record on Turntable PP-1 from above Placing record on Turntable PP-1 from above
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
EE1 Plus with Cable EE1 Plus with Cable
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
