New JL Audio Marine Speaker Systems Announced
Because not all boats are styled the same way, the JL Audio marine speaker lineup will now be available in two distinct styles, each available in two different color schemes. The new looks will be available in 2008 on all marine coaxials, component systems and subwoofer drivers, except the MX650-CCX.
Sport Grille:
This all-new, aggressively styled spoked grille design features
interchangeable logo badges in different colors and looks great in sport-styled boats. Available in all-white and titanium / black color combinations.
Classic Grille:
Our traditional slat grille design blends in seamlessly with luxury-themed boats and is now available in all white or titanium / black color combination.
M770-ETX-CG: 7.7-Inch Enclosed Tower Coaxial Speaker System
Ideal for wakeboard towers or any tube-mounted application, these beautiful enclosed coaxial systems deliver stunning JL Audio sound quality thanks to their 7.7-inch JL Audio coaxial speakers. Unlike most enclosed speaker systems, these feature 100% fiberglass construction with a smooth gel-coat finish, for years of reliable service. Aluminum decorative accents on the enclosures add a custom touch.
Each enclosure’s mounting post is designed for full 360 degree rotation and quick removal/installation. The posts are compatible with a selection of mounting fixtures designed to fit a wide range of pipe diameters. Mounting fixtures are sold separately.
M770-ETX-CG
Nominal Diameter: 7.7 in. (196 mm)
Continuous Power Handling: 100 W
Impedance: 4 ohm
MSRP: Price is estimated at $1100 at time of delivery — clamp available separately
Availability: April, 2008
MX650-CCX
Nominal Diameter: 6.5 in. (165 mm)
Actual Outside Diameter: 6.9 in. (175 mm)
Continuous Power Handling: 50 W
Impedance: 4 ohm
Mounting Depth: 2.7 in. (69 mm)
MSRP: $279.95
Made in the U.S.A.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
