New Gefen DVI Extender Sends Analog and Digital Audio Plus HD Video Up to 150 Feet
WOODLAND HILLS, CA — Small in size but big on performance, the new Gefen DVI/Audio CAT5 Extender provides unbeatable options for the extension of high definition audio/video systems.
Whether you aim to use it with a computer or HDTV system, this Gefen extender has got you covered. Computer users will appreciate the fact that it sends DDC controls, digital or analog audio plus DVI video over two industry-standard CAT5 cables. HDTV viewers will applaud its stereo and digital audio support for surround sound.
Small enough to fit in the palm of your hand, the DVI/Audio CAT5 Extender’s footprint sender and receiver units come equipped with DVI, analog audio and S/PDIF ports. Two category-5 cables send everything connected up to 150 feet in distance. A five-volt power supply, which can be connected at either end, feeds the system.
Detailed information may be found at: http://www.gefen.com/kvm/product.jsp?prod_id=3329
The Gefen DVI/Audio CAT5 Extender (MSRP $599) can be purchased online or through an authorized Gefen reseller, also listed online.
About Gefen:
A leader in the high definition digital domain, Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is utilized all over the world in professional AV/IT and consumer electronics/home theater environments. Their add-on hardware maximizes system functionality and enhances operability by enabling AV systems to go beyond their original functionalities. Solutions support an array of connectivity interfaces including HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, RCA, USB, Firewire and RS-232. A selection of high quality cabling is also available. Additional information may be found at www.gefen.com.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
