HDTV 4K & 8K TV
New Adapter from Gefen Connects SDI Devices to HDTV Displays
WOODLAND HILLS, CA [February 6, 2004] Gefen, an interconnectivity solutions
provider for computer and electronics components, announced the released of
its new ex-tend-it SDI to DVI Adapter. The new Adapter enables high
definition serial digital video transmitted through SDI to be converted to
DVI (digital visual interface) for output to DVI displays. It works with all
SDI and serial digital video sources, which are commonly used in broadcast
and post-production, and outputs a DVI signal compatible with LCD monitors,
HDTVs (high definition televisions), video projectors and plasma displays
with DVI.
Gefen’s SDI to DVI Adapter, priced at $999 (US), outputs RGB DVI at
1280×1024 resolution and supports PAL, NTSC, 720p, 1080p and 1080I HDTV formats.
The unit may be ordered online at www.gefen.com or through one of Gefen’s
worldwide dealers. A complete dealer list may be obtained by emailing
gsinfo@gefen.com.
Specifications:
Input: SMPTE 259M-C (270Mbps)
Input: SMPTE 292M (1.485/1.001 Gbps)
720P @ 60, 59.94, 50, 30, 29.97 and 25 Hz
1080p @ 30, 29.97, 25, 24 and 23.98 Hz
1080I @ 60, 59,94, 50, 48 and 47 Hz
Output: DVI (digital RGB) and DVI-HDTV
Connector: DVI-D, Female
Compliant: DVI 1.0
Dimensions (inches): 1.2 x 3.75 x 5.5
Power: external power adapter with locking power connector
About Gefen Inc:
Gefen provides computer and electronics connectivity solutions through its
ex-tend-it Professional Series, which offers multi-platform extension,
switching, distribution and conversion technologies. Gefen is currently
pioneering a full line of DVI and HDTV products that enable high definition
digital video signals to be split, switched and extended. A selection of
HDMI, fiber optics, DVI and CAT5 cabling is also available through Gefen as
well as audio, USB, CAT5, PS/2, RS232 and similar peripheral support
solutions. Detailed product information may be found at www.gefen.com.
For More Information:
Linda Morgan
linda@gefen.com
818-889-3970
Hagai Gefen
hagai@gefen.com
818-884-6294
Stretch It. Switch It. Split It.
Gefens Got It.
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
