Neutrik Introduces opticalCON Transceiver Adapter at AES 2008
SAN FRANCISCO, CA — In an effort to ease design integration of its opticalCON chassis connectors in combination with SFP (small form-factor pluggable) transceivers, Neutrik introduces an opticalCON Transceiver Adapter at AES 2008 (Booth 809). The opticalCON Transceiver Adapter seamlessly connects an opticalCON chassis and an LC SFP transceiver.
SFP transceivers are compact, optical transceivers used in fiber-optic communications. Neutrik’s opticalCON Transceiver Adapter is compatible with all LC SFP transceivers and enables use of Neutrik’s rugged opticalCON or conventional LC connectors. It features an automatic sealing shutter which avoids any transceiver contamination on-site and also helps users avoid vandalism by “protecting” the transceiver.
Neutrik’s newest transceiver adaptor is available in several variations depending on signal mode. Each is designated a particular color coding for easy and instant identification on-site. Neutrik’s new receiver adaptors include, Multimode transceiver adapter (NAO2M-SFP-LC) which features a black color coding, Single mode transceiver adapter (NAO2S-SFP-LC) with a blue color coding and Single mode APC transceiver adapter (NAO2SA-SFP-LC) with a color coding of green.
“At Neutrik, integration is the key to staying at the forefront of connectivity trends and needs,” says Jim Cowan, president of Neutrik USA. “Products such as the new opticalCON Transceiver Adapter enable us to offer our customers an optical solution from Neutrik, to seamlessly integrate with SFP transceivers.”
opticalCON increases the reliability and maximizes the uptime for fiber optic connection systems. While this new system is based on a standard optical LC-Duplex connection; the opticalCON improves this original design to ensure a safe and rugged connection. It enables up to four copper wires to run power or data signals through. A special SMPTE-version1 has been optimized for broadcast applications, which provides an additional ground-shell contact.
In order to create a simplified installation, one can connect a conventional LC-Duplex connector on the rear, which causes the chassis connector to act as a “feed-through.” The opticalCON cable connector comes pre-assembled with a choice of three mobile field cables, which can be ordered at almost any length.
The opticalCON also features a rugged connection, all metal housing and heavy-duty cable retention. opticalCON uses conventional LC connectors, which are easy to clean, and has a Push-Pull locking mechanism. In addition, the colored labeling plates are included to identify the fiber mode.
Neutrik manufactures a wide array of XLR connectors and receptacles, jacks and plugs, speaker connectors and accessories for the professional audio industry. Neutrik USA is located at 195 Lehigh Avenue, Lakewood, NJ 08701.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
