Network Attached Storage
NETGEAR ReadyNAS Duo v2 and NV v2 Network Storage
NETGEAR introduced the two-bay ReadyNAS Duo v2 and four-bay ReadyNAS NV+ v2 network attached storage systems, which access data twice as fast as previous generations and provide private cloud storage with as few as 8 mouse clicks.
Both systems include hot-swap disk drive bays and automatic capacity expansion, as well as USB 3.0 ports (an industry first) for up to 20% speedier backups. An updated photo sharing application allows print quality private photo sharing without 3rd party services or fees. Both include ReadyNAS Remote, a mobile app for iOS, Android, PC and Mac platforms that delivers 128-bit SSL access to information stored on the ReadyNAS from anywhere. And finally, both can stream music, HD movies and photos to home media devices like TVs, game consoles and TiVo.
NETGEAR ReadyNAS NV+ v2 Network Storage
With the newly redesigned RAIDiator 5 user interface, set up is complete in less than 8 clicks. Common storage tasks such as setting file permissions or creating new user accounts are a breeze. Also, pre-installed on each machine, the ReadyNAS Remote application automatically creates secure connections for easy storage access from phone, tablet and notebooks from wherever life takes you.
ReadyNAS Photos II revolutionizes the private photo sharing landscape by allowing users to securely share their photos or albums without resolution restrictions. Granting upload/download access is a breeze and photos can be uploaded from a mobile handheld or even directly from an Eye-Fi wireless memory card. In addition, all ReadyNAS units feature the ability to stream content through DLNA compatible devices like game consoles and televisions.
Available diskless or populated, ReadyNAS Duo v2 and ReadyNAS NV+ v2 feature a sturdy steel chassis, hot-swappable drive bays and automatic expansion for painless management and zero downtime.
Pricing and Specifications
Duo v2 NV+ v2
Diskless RND2000-200 ($199) RND4000-200 ($399)
Half-populated 1 TB RND2110-200 ($269) 2 TB RND4210-200 ($499)
Fully-populated 2 TB RND2210-200 ($299) 4 TB RND4410-200 ($599)
CPU 1.6 GHz Marvell single-core 1.6 GHz Marvell single-core
Memory 256 MB 256 MB
3.5″ Bay Configuration 2 4
Maximum Internal Capacity 6 TB 12 TB
Gigabit LAN 1 1
USB Ports 1 USB 2.0 (front)
3 USB 3.0 (back)
1 USB 2.0 (front)
3 USB 3.0 (back)
Disk Management ReadyNAS X-RAID2
JBOD RAID 0, 1
ReadyNAS X-RAID2
JBOD RAID 0, 1, 5
Backup Software (included) Memeo Premium Backup
1 liftetime license per box
LCD Panel No Yes
Dimensions (H x W x D) Weight 142 x 101 x 220 mm
5.59 x 3.98 x 8.66 in
205 x 134 x 223 mm
8.07 x 5.28 x 8.78 in
Weight without disk: 2.12 kg / 4.67 lb without disk: 4.70 kg / 10.35 lb
Power Supply External Power Adapter, 60 w External Power Adapter, 90 w
Warranty Terms 3 years, limited warranty 3 years, limited warranty
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
