Neoix AMORR is $129 Android Smartphone sans LTE
Neoix AMORR Smartphone
San Diego-based startup, Neoix, Inc. has launched their second Android smartphone for the low price of $129. The new AMORR phone comes unlocked and will work with any GSM carrier that supports HSPA+ (not LTE), which includes T-Mobile, AT&T, MetroPCS, and others (not Verizon or Sprint). Some carriers label HSPA+ as 4G, but it’s really enhanced 3G. Regardless of the nomenclature, its 4-year old technology that will yield 50-75% slower speeds than LTE. However, for casual web browsing and social networking it should be fine.
Neoix AMORR Smartphone - front and back
The Neoix AMORR features a 5.5-inch qHD (960 x 540) display, half the resolution of Full HD, along with eight different preloaded UI themes. Each AMORR is accentuated by brushed gold trim, and the back-cover compliment is determined by you. Two interchangeable back-covers are included. The soft-touch black patterned obsidian is perfect for everyday use while the high-gloss richly stenciled gold option is perfect for those events when opulence is in order.
The AMORR has a number of audio enhancements and customizable reverberation settings available for the individual to fine-tune their experience. Camera color effect settings enable the user to give personalities to their photos. As always, the battery is removable which allows users to keep a spare battery handy for those times when they are away from a power outlet for an extended period of time.
Neoix AMORR Smartphone - box
Like all Neoix products, the AMORR includes a one-year warranty, repair options, and “Worry Free” assurance. If a customer accidently damages their device, they have the option of sending it in for repair. If the device is damaged beyond repair, the included “Worry Free” assurance offers a one-time replacement following the original purchase date for a $75 deductible.
Price and Availability
The Neoix AMORR smartphone is available now for $129 at Amazon.com.
Specifications
Platform CPU MT6580 1.3 GHz Quad Core
OS Android 5.1
Network GSM/WCDMA
Frequency Band 4G (HSPA+)3G (WCDMA): 850/1900
2G (GSM): 850/900/1800/1900
Display Size 5.5″
Resolution qHD (960 x 540)
Type Multi touch G+G capacitance screen
Memory & Storage ROM 8 GB
RAM 1 GB
Expandable Memory TF Card, up to 32 GB
Camera Rear Camera (Sensor Type) 8 MP
Front Camera (Sensor Type) 5 MP
Camera Features (Rear Camera) Autofocus, Flash
Video Recording Yes
Connectivity Wi-Fi Yes, b, g, n
EDGE Yes
HSDPA Yes
HSUPA Yes
HSPA+ Yes
GPS Yes
BT / FM Yes / Yes
NFC No
Hall No
Connectors Ear Jack 3.5 mm
USB Micro 5 PIN
OTG No
SIM Dual SIM Dual Standby(SIM card Micro SIM Card)
Sensors G- sensor Yes
Proximity Sensor Yes
Light Sensor Yes
Fingerprint Identity Sensor No
Functions HotKnot No
Miracast No
TP Wake up Gestures Yes
Battery Battery Capacity 2050 mAh
Talk Time 3.2 hours (12 hours with screen off)
Standby Time 296 hours
Dimension & Color Size 158 x 78.5 x 8.5mm
Weight 205g
Color Black, Gold
Gift Box Options Standard Yes
Deluxe Option
In Box Accessories Head Set Yes
N. America Standard Charger Yes
Micro USB Cable Yes
User Manual No
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
