NEC U300X and U310W DLP Projectors
NEC announced today its new U Series with the 3000-lumen U300X and 3100-lumen U310W. The complete elimination of shadows and glare typically found with standard projection systems is accomplished by mounting these ultra short throw projectors to the wall above the screen, making them ideal for education environments using interactive or standard whiteboards.
The 3D-ready U300X and U310W are built with powerful DLP and DLP Link technologies from Texas Instruments. For corporate customers that lack the space required for a standard projector, these projectors offer a compelling alternative. They offer XGA and WXGA resolutions, respectively, and brightness up to 3100 lumens. Their connectivity includes HDMI and dual computer inputs, as well as variable audio out to connect the projector to an external speaker and control the volume through the projector's remote control.
U Series models make use of a variety of eco-friendly features that lengthen the life of the projector, saving money and energy in the process. ECO Mode technology extends lamp life up to 3000 hours while lowering power consumption. Power management controls contribute to energy savings by automatically turning the unit off when an incoming signal is not detected from any of the inputs, while quick start (20 seconds) and shutdown allow for immediate use and power off functionality without the need for a cooling period.
The U300X and U310W projectors include the following features:
  • Throw ratio of 0.377:1 (U300X) and 0.3:1 (U310W)
  • Brightness of 3000 lumens (U300X) and 3100 lumens (U310W)
  • Contrast ratio of 2000:1
  • Lamp life up to 3000 hours (in ECO Mode)
  • 3D capability increases interactivity between presenters and audience
  • HDMI connectivity and dual computer inputs, which ensure quick switching between presentations
  • Variable audio out connects the projector to an external speaker and controls the volume with the projector's remote control
  • Integrated RJ45 connection provides for quick connection to the LAN (10/100 base-T capability)
  • Virtual Remote (DDC/CI) controls the projector directly from a computer without the need for additional control cables
  • Remote diagnostics enable the user to monitor and make adjustments to the projector remotely
  • Closed captioning enables users to display text information for the hearing impaired
  • Automatic vertical keystone correction allows the projector to be tilted up or down and still produce a square image without the need to make manual image adjustments
  • Auto Power On eliminates the need for a remote control by automatically turning the projector on when AC power is supplied
  • Quick start lets you begin presenting in about 20 seconds, while quick shutdown allows immediate power off with no cooling required
  • Powerful 10-watt speaker fills the volume requirements for most classrooms and conference rooms
  • Optional wall mount kit, which is available separately or as a bundled solution with the projector, provides flexibility during integration and allows for wall mounting directly above the screen (NP01WK1)
Price and Availability
  • NEC U300X – $1.299 (available December 2010)
  • NEC U310W – $1,199 (available December 2010)
Placing record on Turntable PP-1 from above
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
EE1 Plus with Cable EE1 Plus with Cable
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Michell Audio Apollo Phono Preamplifier and Muse Power Supply Michell Audio Apollo Phono Preamplifier and Muse Power Supply
Does the Michell Audio range of high-end turntables finally have a complementary phono pre-amplifier to match its capabilities? The Michell Apollo looks ready to...
Optoma Photon Go UST Projector Black Optoma Photon Go UST Projector Black
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Shanling EH2 Headphone Amplifier and DAC Shanling EH2 Headphone Amplifier and DAC
Forte Distribution previews Shanling's $399 EH2 DAC Headphone Amp for CanJam Attendees
FiiO FT7 Open-back Planar Magnetic Headphones Angle FiiO FT7 Open-back Planar Magnetic Headphones Angle
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
