Nautiz X1 Ultra-Rugged Smartphone
Nautiz X1 Ultra Rugged Smartphone
Handheld Group just released the Nautiz X1, the toughest enterprise smartphone in the world that is waterproof, dustproof, shock-resistant and can handle extreme temperatures. The ultra-rugged smartphone offers an IP67 ingress protection rating and also meets stringent MIL-STD-810G military test standards for enduring humidity, vibration, shock and extreme high and low temperatures.
The Nautiz X1 weighs in at less than 180 grams (6.3 ounces). It has a 4-inch (800×480) special sunlight-readable capacitive touchscreen and ultra-durable Gorilla Glass. It runs on a powerful 1 GHz dual-core processor and has 1 GB of RAM. It features Bluetooth, Wi-Fi, a compass, a professional u-blox GPS, and a 5-megapixel camera. The Nautiz X1 comes with Android 4.0 (Ice Cream Sandwich) or Windows Embedded Handheld 6.5 operating system, and runs on both GSM and CDMA networks. Multiple battery options enable a full day’s work in the most demanding environments.
https://www.youtube.com/watch?v=5IuX7QFdveE
Price and Availability
Handheld Group Nautiz X1 is supposed to be available now, but pricing was not disclosed.
Specifications
Size 4.9″ (125 mm) x 2.6″ (65 mm) x 0.6″ (15 mm)
Weight 6.3 oz (180 g)
Environment
Operating: -4 °F to 140 °F (-20 °C to 60 °C)
MIL-STD-810G, Method 501.5 Procedure II
MIL-STD-810G, Method 502.5 Procedure II
Storage: -22 °F to 140 °F (-30 °C to 60 °C)
MIL-STD-810G, Method 502.5 Procedures I, III
Drop: 26 drops from 4 ft (1.22 m) MIL-STD-810G, Method 516.6 Procedure IV
Vibration: MIL-STD-810G, Method 514.6 Procedures I, II
Sand & dust: IP67, MIL-STD-810G
Water: IP67, MIL-STD-810G
Humidity: MIL-STD-810G, Method 507.5
Altitude: 15,000 ft (4,572 m) at 73 °F (23 °C)
Processor Texas Instruments OMAP 4430 1 GHz dual-core
Memory/Disk 1 GB RAM/4 GB Flash
Expandable Memory MicroSD, SDHC
Operating System Android 4.0 (Ice Cream Sandwich) or Windows Embedded Handheld 6.5
Screen 4″ WVGA (800×480) sunlight-readable capacitive touchscreen, Corning® Gorilla® Glass
Battery 1530 mAh Li-Ion as standard
3060 mAh Li-Ion (optional)
Connections Micro USB 2.0 OTG
Docking Connector 5-pin USB connector
Communication Audio: Speaker / Mic / Headset jack / Built-in vibration function
Bluetooth: Bluetooth Class 2
Cellular (WWAN): GSM/GPRS/EDGE, UMTS/HSPA+ or CDMA EV-DO Rev. A (800 MHz, 1900 MHz)
Wireless LAN: 802.11 b/g/n supports WEP, WPA, WPA2
Navigation Integrated u-blox GPS, WAAS/EGNOS/MSAS-capable, G-Sensor, E-Compass
Camera 5 Megapixel Camera with autofocus and LED Flash
Options
  • Desktop cradle
  • Extended battery
  • Vehicle cradle
  • Carry cases
Totem Tribe Tower Thunderbird Speakers Drivers Close-Up
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Vertere DG-X Turntable Red Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Campfire Audio Axion IEM Connected USB-C with Controller Campfire Audio Axion IEM Connected USB-C with Controller
Earbuds & In-Ear Headphones
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Wattson Audio Madison Power Amplifier Front Wattson Audio Madison Power Amplifier Front
Discover the new Madison Power Amplifier from Wattson Audio — a Swiss-engineered Class A/B amp delivering rich harmonics, ultra-low distortion, and dynamic performance in...
WiiM Voice Remote 2 with components lifestyle WiiM Voice Remote 2 with components lifestyle
With WiiM's continuing quest to improve the music listening experience, the upgraded Voice Remote 2 improves control for WiiM devices.
