NaimNet NNLS In/On-Wall Speakers
NaimNet today launches a range of specialist high-end in- and on-wall loudspeakers. They will be available in July.
These NNLS speakers are the result of responding to feedback from installers and specifiers. Most NaimNet installers felt that the market was glutted with low-performance in- or on-wall loudspeakers, but that there was a shortage of CI speakers that truly performed.
The NNLS loudspeakers are of heavy and solid construction, as one would expect of a NaimNet design. Cabinets are of solid substantial CNC routed HDRB with solid aluminium baffles for the NNLS02 and NNLS03. High performance drive units utilising the latest materials technology are responsible for the impressive audio performance. The long-throw bass units with pressure-cast aluminium-alloy baskets deliver high power handling and realistic sound pressure levels. The mid- and high-frequency units employ similarly advanced technology and have high power handling for performance and reliability.
The HDRB cabinets can be sprayed or hand painted to any colour to match a client’s decor. In addition, the grilles can be painted or printed with a design to suit their environment. NaimNet Custom Art Print grilles are also available separately to enable the client to change the look and feel of the room at will.
The in-wall models require a maximum of 90mm depth so that they will mount into any standard inner or outer stud wall, including standard European metal framed stud wall systems. The cabinets mount into a simple rectangular cut-out with solid aluminium mounting toggles to ensure a rigid vibration-free mounting into materials from 10 to 40mm thickness. Substantial terminals allowing bare wire or spade connectors are recessed. This, together with wire channels in the cabinet back allows cable routing without increasing effective cabinet depth.
The on-wall models simply mount with either two- or four-point wall fixings. Channels in the cabinet back make invisible routing of the cables very easy.
NNLS02 and NNLS03 designs include a pair of mid-range units configured to reduce side radiation, thereby reducing reflections from adjacent walls — the controlled directivity making them ideal as front left, right or centre channels as they are less affected by room acoustics and will produce a sharper more solid stereo image.
The wider dispersion of the NNLS01 makes it suitable for softer furnished rooms, surround channels or areas where sound is required across a wider area
The cabinets are closed-back reflex aligned to ensure the maximum performance in every mounting position. The port flow is carefully optimised and laminar flow is achieved using a selected felt lining to the slotted port.
Designed from the outset to deliver realistic, accurate and enjoyable music, movies and speech reproduction these speakers are not poor substitutes for free-space designs. Speech especially is a major failing of most in- or on-wall loudspeakers. BBC Radio Four should sound like Radio Four, not as if every presenter has a heavy cold.
About NaimNet
NaimNet multi-room components offer whole-home Audio Video distribution and control without any performance compromise enabled by the advanced IP technologies used. The fully scalable NaimNet system is equally cost effective in small apartments or substantial mansions. NaimNet is StreamNet™ connected. There is no practical limit to the size of the system.
Ethernet connected, using a standard domestic PC network, NaimNet offers control using a wide range of convenient devices according to personal taste and requirements. NaimNet also facilitates whole-house control of lights, AV, screens and blinds, heating, and security, because of easily configured interfaces to network-connected partner products.
Naim Servers store music with bit-for-bit accuracy. Every musical nuance is copied onto the hard drive without any compression, for selection and playback at any time. Playback is bit-accurate. Uncompromised musical performance ensures that the Naim Music Server takes its rightful place among Naim source components delivering the finest music in the home.
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Hi-Fi Components
Experience the latest from Naim and Focal at AXPONA 2025, including the North American debut of the Bathys MG wireless headphones.
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Hi-Fi Components
On Thursday, February 20, 2025, the latest Focal Powered by Naim luxury audio store opens in Tampa, Florida.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Digital Music Systems
The last days of gear getishism? Network Amplifiers are the future of hi-fi, offering a one-box solution for audiophiles. Just add speakers.
