Naim UnitiQute Wi-Fi Digital Audio Player
Naim Audio just launched the UnitiQute a smaller more compact all-in-one system than NaimUniti Naim Audio’s multi award-winning system.
Naim developed UnitiQute recognising a new breed of consumers — those who want the performance and the convenience that new technology brings but will not accept the compromise in performance that following this route from a non-audiophile brand might entail.
The UnitiQute is the first high-end remote controlled all-in-one audio player to offer so many sources: FM & Internet Radio (plus DAB in supporting markets), MP3 / iPod (Authenticated digital iPod connection), Streamed audio and USB.
Key to UnitiQute is its digital audio streaming capabilities. UnitiQute can wirelessly stream music stored on UPnP™ networked devices, providing access to even more music including — the increasingly popular — hi resolution 24bit / 96kHz WAV or FLAC files.
With its onboard 24bit / 192kHz capable DAC, UnitiQute is the ultimate audio source hub, able to interface with digital audio sources, such as computers and gaming consoles and the latest TVs.
UnitiQute combines proven and multi-award winning analogue engineering as it is derived from Naim’s top selling and again multi-award winning, NAIT 5i integrated amplifier with state-of- the-art up–to-the-minute digital engineering to deliver the sonic performance to make the most discriminating customer proud.
The large linear power supply designed for UnitiQute ensures that it can deliver the necessary goods even at party levels.
The industrial design reflects the company’s belief in understatement and elegance. The design however is not just cosmetic: the choice of non-magnetic materials — to reduce eddy currents significantly — and the fit and finish are all added extras in the performance.
Naim UnitQute with remote
UnitiQute will be available worldwide in March at an anticipated cost of $2000 in the USA and £1350 in the UK. Prices in other markets are available from Naim’s local distributors.
Feature summary
A complete audio system — just add speakers
  • UPnP™-enabled for playback of network-stored audio / internet broadcasts from PC, Mac or NAS drives
  • Front-panel USB for iPod/MP3 player and USB memory stick playback
  • Multi-format radio (FM/DAB/Internet)
  • Apple authenticated enabling digital output from iPod for ultimate quality
  • iPod control, charging and front-panel content display when connected to front-panel USB port via standard iPod cable
  • 3.5mm front panel input that supports both analogue and digital sources
  • Two analogue inputs (3.5mm front-panel socket and RCA)
  • Onboard DAC with five 24bit / 192kHz capable S/PDIF inputs for external digital sources
  • Preamplifier and 45W per channel into 4-ohm, 30W per channel into 8-ohm power amplifier
  • Ethernet and Wi-Fi network connectivity
  • Plays WAV, MP3, Windows Media–formatted content, AAC and FLAC from any suitable UPnP™ device together with WAV, AAC, MP3 and Apple Lossless (from an iPod)
  • Switchable bass contour control for low-volume listening
  • Bass management system for use with subwoofer-satellite loudspeaker systems
  • Digital output on 75-ohm BNC connector (RCA adapter supplied)
  • Front-panel display with intuitive interface, remote-controlled
  • Front-panel 3.5mm headphone output
  • Front panel logo touch-sensitive mute function
  • Full v5 Tuner internet radio service
  • Linear Power supply with 200VA toroidal transformer with three separate windings
  • Separate power supplies for digital, analogue, and power amplifier
  • Ground selector switch for optimum performance
  • High quality Wolfson DAC
  • Naim compact, non-resonant, non-magnetic case
  • OLED, two size, display for high contrast and easy visibility
  • British design and build
Naim products are designed and manufactured at the Naim headquarters in Salisbury England. Naim pride themselves as being an engineering led company where technical excellence vies with sound quality as being the primary driver.
Naim UnitQute - back
Every aspect of the design and build is under Naim’s control. Production is cellular: one person assembles a complete product to instil the pride of “getting it right, the first time — every time”.
CES Innovations 2010 Design and Engineering Awards Honoree
The Naim Audio UnitiQute has been named an International CES Innovations 2010 Design and Engineering Awards Honoree. Products entered in this prestigious program are judged by a pre-eminent panel of independent industrial designers, engineers and members of the media to honor outstanding design and engineering in cutting edge consumer electronics products across 36 product categories.
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Hi-Fi Components
Experience the latest from Naim and Focal at AXPONA 2025, including the North American debut of the Bathys MG wireless headphones.
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Hi-Fi Components
On Thursday, February 20, 2025, the latest Focal Powered by Naim luxury audio store opens in Tampa, Florida.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Digital Music Systems
The last days of gear getishism? Network Amplifiers are the future of hi-fi, offering a one-box solution for audiophiles. Just add speakers.
