Keeping it Simple with the Naim CI-Uniti 102 Streaming Amplifier
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Naim CI-Uniti 102 Streaming Amplifier Angle
Depending on how many sources you still use and the size of your listening space, the Naim CI-Uniti 102 might make the most sense for a surprising number of listeners when you look at it objectively.
If you are familiar with the Uniti Atom, the CI-Uniti 102 feels like the award-winning network amplifier, but more like a pair of Buck Mason skinny jeans with one less pocket and the same degree of expandability in the hands of a good tailor.
The CI-Uniti 102 can function as a simple two-channel streaming amplifier or hub for a multi-room system with more than enough power for in-wall/in-ceiling speakers or even a pair bookshelf loudspeakers in a living room or den.
Naim has already proven that it can build a streaming platform that delivers easy access to all of the relevant streaming apps and it’s not very difficult to set-up. It is also customisable using DSP and EQ for your listening space.
And who doesn’t like an amplifier that can be hidden so easily?
Naim App
Overview
The CI-Uniti 102 is a streamer/amplifier that is designed to provide optimized musical performance from both streaming and physical sources for custom installation needs.
The CI-Uniti 102 can be installed in a variety of indoor and outdoor settings, providing amplification for CI Focal speakers and any other loudspeaker that you might be considering at this price point.
The CI-Uniti 102’s DSP provides system calibration and it also easily connects to its partner components, the NAIM CI-NAP 108 and CI-NAP 101 power amplifiers.
Control is accessible via the Focal & Naim application and home control platforms such as Crestron, Control4, RTI, Savant, and Elan.
Naim CI-Uniti 102 Streaming Amplifier Interface Manager
Additionally, the Focal & Naim Manager software provides system configuration support for the CI-Uniti 102. Here are some examples:
  • Speaker Profiles for each loudspeaker in the CI Focal catalogue.
  • EQs for on-the-spot calibration.
  • Crossovers for use with subwoofers.
  • A limiter to control maximum listening levels.
  • Delays for temporal alignment.
  • Configuration settings for use on a Dante network.
  • Source selection setup for users.
Other capabilities that can be set up and controlled by the integrator or user:
  • Wired and wireless streaming capabilities (TIDAL, TIDAL Connect, Qobuz, Spotify, UPnP™, Internet Radio, Airplay 2, and ChromeCast).
  • Versatile connectivity (HDMI, Bluetooth, S/PDIF, analog).
  • Compact integrated power amplifier with the ability to supply 150W at 8 ohms.
  • Two independent stereo RCA outputs that can be used for subwoofers or sub-zones.
  • Multiroom capability for up to 32 rooms.
  • “Trigger” outputs provide remote standby for the companion Naim CI-NAP 108 and CI-NAP 101 power amps if needed.
  • Rack mount installation that can be hidden if desired.
Naim CI-Uniti 102 Streaming Amplifier with Brackets Angle
Naim CI-Uniti 102 Streaming Amplifier with Mounting Brackets
Specifications
Price$1,499 USD
Product TypeStreaming Amp
Number of Channels4 x Line
2 x Amp
Frequency Response (Line)(-3 db) 5Hz – 70kHz
THD+N<0,006%
Signal-to-Noise Ratio (SNR)110dB (A-Weighted)
Analog Gain29dB
Analog Inputs1 x Analog – Stereo RCA – (47kΩ / 2.5V RMS)
Analog OutputsMain: 1 Stereo RCA
Speaker Outputs: Terminal block / Euroblock / Banana connector – 4mm
Sub/Aux: 1 Stereo RCA
Power Output8Ω 150W 4Ω 260W 2Ω 480W
Digital InputsS/PDIF – up to 96kHz / 24bit
HDMI eARC – LPCM up to 192kHz/24-bit Stereo
Supported Sampling RatesUp to 32-bit/384kHz
NetworkRJ45 Gigabit Ethernet – compatible with IPv4 and IPv6
WiFi 802.11ax (Wi-Fi 6) – 2×2 MIMO – External antenna
BluetoothBluetooth LE 5.1 – External antenna shared with Wifi
Multi-Room AudioNaim Multiroom – Up to 32 devices on a single session
Compatible with all generations of Naim streamers
Streaming ServicesTIDAL TIDAL Connect
Spotify Connect – Free + Premium support
Qobuz
UPnP with play queue
Internet Radio + Podcast Airplay 2
ChromeCast v2
Dante Receiver – 48kHz supported
Bluetooth Classic Audio Receiver. SBC + AAC supported
User InterfaceFocal & Naim App – Basic use Focal & Naim Manager – Configuration
Compatible OSiOS and Android for Focal & Naim App
Windows, MacOS for
Integration PartnersControl4, Crestron, EAN, Savant
Wired Automation2 x 1/8″ (3.5mm) mono jack connectors – 12V trigger outputs
Rack Height1U
Power Consumption (Network Standby Mode)0.5W
Power Consumption (In Use)70W
Mains Power Supply100V to 240V +/-10%, 50/60Hz
Dimension (HWD)1-3/4 x 11-3/4 x 11-3/4 inches (4.45 x 30 x 30 cm)
Weight9.9 lbs (4.5kg)
Pro Tip: The CI-Uniti 102 is one of Naim’s CI Series components. For more details, refer to our previous report
Naim Audio CI Series 2024
The Bottom Line
The Naim CI-Uniti 102 is not the first of its kind in the CI category. Both NAD and Anthem have already introduced rack mountable streaming amplifiers for less than $2,500 and we’re likely to review a sample of the Anthem MRX SLM AVR in a forthcoming column of the Cabin Audiophiler.
If you only require streaming and one additional source like a CD player or turntable – the Naim CI-Uniti 102 could be all you really need.
Price & Availability
The Naim CI-Uniti 102 is priced at $1,499 USD at Crutchfield ($1,949 CAD) and is available through Focal Powerd by Naim Stores and other Authorized Dealers and Online Retailers
Pro Tip: The price does not include professional installation and setup.
For more information: naimaudio.com
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
HDTV 4K & 8K TV
HDTV 4K & 8K TV
