Naim’s CI Series Delivers a Comprehensive Solution for Focal CI Loudspeakers: ISE 2024 Barcelona
New Naim Audio CI amplifiers and streamer for the custom installation market are a perfect complement to Focal’s line of in-wall and in-ceiling speakers.
Naim Audio CI Series 2024
When Focal announced its extensive range of Littora CI loudspeakers in 2022, we suspected that Naim was working behind the scenes on a range of multi-channel amplifiers and some form of streamer or controller to be sold along with it. Giving up that portion of the market to competitors made zero sense to us when the British manufacturer had the capabilities to make it happen.
The Focal Powered by Naim retail experience is designed to get customers to buy everything from both brands; and that includes headphones, network amplifiers, and in-wall/in-ceiling loudspeakers for both home and marine environments.
The new CI Series range from Naim consists of three products designed to complement integrated setups, and Focal’s in-wall and in-ceiling loudspeakers. With these innovations, the leading British brand in high-end streaming and amplification is taking a unique approach that is focused on the customer and installer.
This series marks a new era for Naim and Focal, as they are offering complete solutions in the Custom Integration (CI) market for the first time.
They combine Naim’s core DNA with Focal’s expertise in acoustics to create a perfect audio setup. CI systems, cater for home (indoor/ outdoor), maritime, and commercial spaces.
Naim CI Series with Rack Mounts
Naim CI Series
The CI Series range includes three new rack-mountable products:
  • CI-Uniti 102: an all-in-one streamer and amplifier – $1,499 USD | $1,949 CAD
  • CI-NAP 101: a low and high impedance mono power amplifier – $1,999 USD | $2,599 CAD
  • CI-NAP 108: an 8-channel power amplifier – $2,999 USD | $3,899 CAD
Availability: Q2 2024
Naim Audio C1 Uniti 102
Naim Audio C1-Uniti 102
CI-Uniti 102 (“The Brain”)
The CI-Uniti 102 is a streamer/amplifier that offers both musical performance and versatility. It is designed to seamlessly integrate into any indoor or outdoor space, providing amplification for CI Focal speakers and enhancing audio from all media sources (TV, Spotify, gaming consoles, etc.).
Its integrated DSP provides full system calibration, enabling it to interconnect with the CI-NAP 108 and CI-NAP 101, making it suitable for all situations.
The new Focal & Naim Manager software, and Speaker Profiles, compatible with CI Focal speakers, enable you to customize the DSP fully for an optimal installation, whether in a commercial environment, at home or outdoors.
The CI-Uniti 102 is controlled by the end user via the Focal & Naim application and home automation platforms such as Crestron, Control4, RTI, Savant, and Elan.
Naim Audio CI Uniti 102 Rear
Naim Audio CI-Uniti 102
For the integrator, the Focal & Naim Manager software allows complete configuration of each of the CI-Uniti 102’s outputs, with:
  • Speaker Profiles for each loudspeaker in the CI Focal catalogue.
  • EQs for on-the-spot calibration.
  • Crossovers for use with subwoofers.
  • A limiter to control maximum listening levels.
  • Delays for temporal alignment.
  • Configuration settings for use on a Dante network.
  • Selection of available sources for the end user.
  • Wired and wireless streaming capabilities (TIDAL, TIDAL Connect, Qobuz, Spotify, UPnP™, Internet Radio, Airplay 2, ChromeCast, Dante).
  • Versatile connectivity (HDMI, Bluetooth®, S/PDIF, analogue).
  • An ultra-silent, efficient, compact integrated power amplifier producing 150W at 8 ohms.
  • Two independent stereo RCA outputs that can be used for subwoofers or sub-zones.
  • Multiroom capability for up to 32 rooms.
  • “Trigger” outputs providing remote standby for the CI-NAP 108 and CI-NAP 101.
  • A universal 90V to 240V power supply
Naim Audio CI NAP 108
Naim Audio CI-NAP 108
CI-NAP 108
The CI-NAP 108 is a rack-mountable 8-channel power amplifier. When paired with the CI-Uniti 102, it makes it possible to connect multiple speakers in different rooms or amplify eight separate audio streams, with its local inputs for each amplified channel. The CI-NAP 108 is also an ideal solution for pairing with audio-video processors to deliver a combination of sound quality and power.
Naim Audio CI NAP 108 Rear
Key Features:
  • 10 RCA inputs, including 8 local inputs and 2 L/R bus inputs.
  • 10 RCA outputs for serial connection with other amplifiers, such as the CI-101.
  • A silent, efficient, compact integrated power amplifier.
  • Two Euroblock outputs per channel for easy parallel connections between speakers.
  • Independent level control.
  • Input signal detection with automatic standby after 20 minutes.
Naim Audio CI NAP 101
Naim Audio CI-NAP 101
CI-NAP 101
The CI-NAP 101 is a rack-mountable mono power amplifier capable of operating in low or high-impedance mode. Along with the CI-Uniti 102, it is specifically intended for use with subwoofers or speakers on a 70/100V line while maintaining exceptional audio quality.
With the ability to operate at an output load of 2 ohms, it is the perfect solution for amplifying 1000 IWLCR Utopia in-wall speakers, accompanied by two 1000 IWSUB Utopia subwoofers from Focal. Additionally, it can be paired with an audio-video processor to combine sound quality and power.
Naim Audio CI NAP 101 Rear
Key Features:
  • Stereo RCA inputs and stereo RCA outputs for serial connection.
  • An ultra-silent, efficient, compact power amplifier capable of driving the most demanding loudspeakers.
  • A perfect product for powering a Focal 1000 Series system with 1×1000 IWLCR Utopia and 2×1000 IWSUB Utopia.
  • Two Euroblock outputs for easy parallel connections between speakers
  • Amplification for low-impedance loudspeakers and 70V/100V line loudspeakers with selectable high-pass crossover.
  • Level control.
  • A universal 90V to 240V power supply.
For more information, visit: naimaudio.com
Related: Naim’s Uniti Nova Power Edition Network Amplifier Delivers 150 Watts and AptX HD Support: ISE 2024 Barcelona
Epson QS100 UST Projector Front Lifestyle
Epson just expanded their high brightness Q Series projector line to include a UST projector for those looking for a discrete large screen viewing...
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
HDTV 4K & 8K TV
HDTV 4K & 8K TV
TCL's latest flagship miniLED TV offers high-end performance at a wallet-friendly price.
Apple is adding Lossless Audio and Ultra-Low Latency to the AirPods Max Headphones, but only when wired.
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
Owners of Samsung's 2024 HW-Q990D, HW-Q800D, and HW-S801D models have a big and annoying problem... Here's what to do if your soundbar is affected.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
