NAD’s Masters M66 BluOS Streaming DAC/Preamplifier Is The Future: High-End Munich 2023
Flagship component offers leading-edge capabilities like BluOS high-resolution music streaming, Dirac Live Room Correction, Dirac Live Bass Control and four independent subwoofer outputs, a first for a two-channel pre-amplifier.
NAD M66 BluOS Streaming DAC Preamplifier Angle
With the growing popularity of active loudspeakers, products like the NAD Masters M66 make a lot of sense; the state-of-the-art DAC/Preamplifier will work just as well with a separate power amplifier but the first scenario takes one box out of the equation and that might prove to be preferable for a lot of listeners. The integration of two Dirac Live platforms only adds to the value of the M66 and the ability to update the software via firmware updates will keep the product relevant for years.
The M66 does convert analog signals to digital, but NAD has also included the ability to bypass the internal DAC for those who may want to run their own tuner, external phono pre-amplifier or digital source into the unit if it possesses a superior sounding DAC. In practice, one could use the M66 to stream from over 20 major streaming platforms, connect two turntables and a CD player and still have inputs available for other sources.
NAD M66 BluOS Streaming DAC Preamplifier Angle Lifestyle with iPad
NAD Electronics will unveil the Masters M66 BluOS Streaming DAC-Preamplifier at the High End Munich 2023 show in Germany ahead of its retail launch. The M66 is a no-compromise component so advanced, it represents an entirely new category of hi-fi separates for the Canadian manufacturer.
Demonstration sessions of the NAD Masters M66 BluOS Streaming DAC-Preamplifier will run, for the first time, in Room D108 in Atrium 3.
In addition to an audiophile-grade DAC and a network streamer based on the acclaimed BluOS multi-room music platform, the M66 has a wide range of inputs, including MM/MC phono and HDMI eARC. The M66 also features both Dirac Live Room Correction and Dirac Live Bass Control, enabling it to deliver more accurate in-room response than any two-channel component ever offered.
Build quality is outstanding. With its aluminum casework, vibrant 7″ touchscreen, and a new volume control, the M66 will inspire pride of ownership for decades to come. Visually, sonically, and technologically, it’s a perfect match to NAD’s award-winning M23 power amplifier. But of course, the M66 can be paired with any high-performance amplifier.
NAD M66 BluOS Streaming DAC Preamplifier Lifestyle Angle with M23 Amplifier
NAD M66 with M23 Amplifier
Music Streaming
Featuring a network streamer based on the renowned BluOS multi-room music management system, the M66 provides access to nearly all the music ever recorded, in resolution up to 24-bit/192kHz. Like all BluOS-enabled components, the M66 has full MQA decoding and rendering capability.
The intuitive BluOS Controller app, available for Android, iOS, macOS, and Windows, has integrated support for more than 20 streaming services, including several that offer lossless and high-resolution music. BluOS users can also access thousands of internet radio stations, and play music stored on local or network drives.
Multi-room Music
With the M66, users can play music just in one room, or share music over a home network with up to 63 other BluOS-enabled components from NAD and other hardware partners. The M66 can also be integrated into control systems from smart home specialists such as Control4, Crestron, ELAN, RTI, and URC. In addition, users can control playback by voice using Amazon Alexa, Google Assistant, or Apple Siri.
NAD M66 BluOS Streaming DAC Preamplifier Lifestyle Front with M23 Amplifier
Tune the Room
Featuring Dirac Live Room Correction, the M66 enables users to address the weakest link in any audio system: the listening room itself. Connect the supplied calibrated microphone to the M66’s USB port and launch the Dirac Live app on a smart device or personal computer.
After playing test tones through the listeners’ speakers, Dirac will analyze the results, then upload filters to the M66 that compensate for common acoustic problems like standing waves and unwanted reflections. The results are transformative: listeners will enjoy tighter bass, improved timbral accuracy, vastly improved clarity, and more precise imaging.
All About the Bass
In a first for a stereo component, the M66 has four balanced (XLR) and four unbalanced (RCA) subwoofer outputs and integrates the full version of Dirac Live Bass Control, which allows independent calibration of multiple subwoofers. Dirac Live Bass Control optimizes bass output in both the frequency and time domains, resulting in a seamless blend between the main speakers and subwoofer(s). Listeners will enjoy smooth, consistent low-frequency response throughout the listening room, not just in the sweet spot.
Performance
The digital section of the M66 employs ESS Technology’s flagship ES9038PRO Sabre DAC, an audiophile-grade design acclaimed for its ultra-low noise and distortion, exceptionally wide dynamic range, and superb time-domain performance.
For volume adjustment, the M66 employs an ultra-precise resistor-ladder control circuit. Compared to traditional analogue circuits, the M66’s digital volume control markedly reduces thermal and related distortions, maximizes dynamic range, and more accurately matches left- and right-channel output across the entire volume range.
The M66 is the first component to feature NAD’s innovative Dynamic Digital Headroom (DDH) circuitry. When enabled with a control in the BluOS app, DDH eliminates digital inter-sample peak clipping distortion, which can occur during digital-to-analogue conversion of sudden high-frequency transients. The benefits are especially obvious with percussion instruments: cymbals are less splashy and more realistic; rim shots are less strident and more impactful.
NAD M66 Streaming DAC Preamplifier Front
Pure Analogue
To enable functions like Dirac Live Room Correction and Dirac Live Bass Control with all signal sources, analogue signals are converted to digital by ESS Technology’s ES9822PRO flagship DACs. However, the M66 has a selectable Analogue Direct mode that bypasses all digital processing. The M66 has separate signal paths for digital and analogue sources, and separate power supplies for the digital and analogue sections, so that analogue signals are unaffected by digital interference when the Analogue Direct mode is engaged. Users can even disable the M66’s Wi-Fi and Bluetooth circuitry to minimize RF interference.
Connect Everything
With its full suite of analogue and digital inputs, the M66 can accommodate all user source components. For vinyl enthusiasts, there’s an ultra-low-noise MM/MC phono stage with precise RIAA equalization, high overload margins, and an innovative circuit that removes infrasonic noise without compromising bass response.
For TV and movie viewing, the M66 has an HDMI eARC interface for connection to an HDTV. In addition, the M66 has two coaxial and two optical S/PDIF inputs, an AES/EBU balanced digital input, two sets of RCA analogue inputs, and one pair of XLR balanced inputs.
NAD M66 BluOS Streaming DAC Preamplifier Rear
Output Options
The M66 has balanced XLR and unbalanced RCA outputs for connection to a power amplifier, as well as four XLR and four RCA subwoofer outputs. Its dedicated headphone amplifier has very low output impedance and ​ maximum output voltage, enabling the M66 to drive demanding high-impedance studio monitor headphones. The M66 also has Bluetooth connectivity, with support for the AAC, LDAC, and aptX HD codecs.
Future Proof
On the M66’s rear panel are two expansion slots that support MDC2, the latest version of NAD’s Modular Design Construction future-proofing technology. In the future, this will allow M66 owners to add new capabilities simply by inserting an optional MDC2 module.
Everything about the NAD Masters M66 BluOS Streaming DAC-Preamplifier will inspire pride of ownership: its elegant aluminium casework, gorgeous front-panel touchscreen, and ultra-precise weighted volume control.
With features like BluOS streaming, Dirac Live Room Correction, and Dirac Live Bass Control, the Masters M66 is truly a masterpiece of sound. “We believe the M66 represents the pinnacle of what is technically achievable today,” said Cas Oostvogel, product manager, NAD Electronics. “And thanks to NAD’s MDC2 future-proofing platform, the M66 will remain at the forefront as technology evolves.”
Features
  • Ethernet and Wi-Fi networking
  • BluOS network streamer provides access to over 20 streaming services, including several that deliver lossless and high-resolution audio
  • Flagship ESS Sabre DAC and ADC chips
  • Innovative Dynamic Digital Headroom (DDH) circuit eliminates digital intersample peak clipping distortion
  • Full MQA hardware decoding and rendering
  • Optional Analog Bypass Mode
  • Separate signal paths for digital and analogue sources; separate power supplies for digital and analogue sections
  • Support for Apple AirPlay 2, Spotify Connect, Tidal Connect
  • Seamless integration with smart home control systems such as Crestron, Control4, ELAN, RTI, URC, and others
  • Amazon Alexa, Google Assistant, and Apple Siri voice control
  • Dirac Live Room Correction
  • Four balanced and four unbalanced subwoofer outputs
  • Dirac Live Bass Control enables seamless blend between the subwoofer(s) and main speakers, and smooth bass response throughout the listening area
  • Ultra-quiet MM/MC phono stage with precise RIAA equalization, high overload margins, and infrasonic filter
  • HDMI port with eARC support
  • Two optical and two coaxial S/PDIF inputs, one AES/EBU balanced digital input, two pairs of RCA line-level analogue inputs, one pair of XLR balanced inputs
  • Dedicated headphone amplifier with low output impedance and very high output voltage capability
  • Ultra-precise resistor-ladder digital volume control
  • 7″ front-panel touchscreen
  • Elegant aluminium casework
  • Two MDC2 expansion slots for adding future capabilities
  • IR remote
Global retail availability will begin fall 2023 at a suggested retail price of US $5,499 / CDN $7,299.00.
For more information: nadelectronics.com
Related reading: Bluesound Celebrates 10 Years With The NODE X Wireless Multi-room Music Streamer
8 Comments
8 Comments
  1. ORT
    May 13, 2023 at 6:06 pm
    I don’t know Ian…Are not screens, pacifically colour (cool European spelling!) noted for causing/introducing digital noise within the DUHtastream that only the finest and mostest smartest frAudiophilian Aural Grifters or “frAG” (as in “busted” (ears to normal folk) will pick up on and thereby render all “serious/critical”, i.e., “stoopid-picky listening” worthless?
    God, I hope so. 😉 They (frAudians) do not deserve to enjoy listening to music. The soundtrack of their imitation of a life is doubtless turgid with incessant whining.
    Other than the inclusion of “Master Quisling Anal”, I think this is one cool webber (the new cool toadish way to say “st…ming”).
    I mean that. It looks cool and I bet it decodes the codes that were encoded so well…
    With this I shall take leave…”You remind me of a man”…
    Don QuiORTe’
    • Ian White
      May 13, 2023 at 9:45 pm
      ORT,
      It looks sexy and I want one.
      I’m shallow.
      Ian White
      • ORT
        May 14, 2023 at 3:48 am
        Ian my brother, welcome to the wading pool that is real world audio and video. It ain’t (artificially!) deep but it is most definitely and genuinely fun.
        And nobody pees in it. 🙂
        ORT
        El Posto Scripto – Buy one. I shall be both happy for and envious of you, my friend. It looks so COOOOOOOOL!
  2. Rich
    May 13, 2023 at 11:19 pm
    I’ve become a huge fan of Dirac. It’s not quite as plug and play as they would have you believe however. It takes some experimentation to get the sound right. I have a friend who used to work in the recording industry. He helped me “tune” Dirac to provide a more lush and present midrange to the somewhat dry midrange in a Nad M33. Very effective. I find the high tech equalizer abilities of Dirac even more useful than its room correction abilities. We also fully corrected my floorstanders top to bottom, but surprisingly left the Rel subwoofer uncorrected. Leaving the natural room gain in the subwoofer intact just sounded better.
    I wish Nad was would make a more stripped down version of the M66 without all the plethora of connections and the eARC stuff. Still $5,500 seems pretty cheap for what it offers.
  3. Catherine Lugg
    May 14, 2023 at 2:51 pm
    Oh…..That looks so lovely. It’s punching my want/need button. But I can already hear the eye rolls from my spouse, so *SIGH!* Then again, it also looks HEAVY. If it’s over 25 pounds, I’m done. *SIGH!* But it’s a drool-worthy piece of kit, to be sure.
    • Ian White
      May 14, 2023 at 8:02 pm
      Catherine,
      It’s closer to being in the 35 to 40 pound range.
      Best,
      Ian White
      • Catherine Lugg
        May 15, 2023 at 2:13 pm
        Ian,
        Thanks for the weight info. *SIGH!* Oh well. Ya know, some intrepid manufacturer is gonna trip over the fact that a fair number of Americans and Canadians have “bad backs,” and design accordingly (Besides Bluesound, which I adore).
        • Ian White
          May 15, 2023 at 3:31 pm
          Catherine,
          The previous model was almost 40 so I can’t imagine the new one being less.
          I will say this — NAD and Bluesound are making some great products these days. I proudly own 4 of them.
          Best,
          Ian White
2026 ASUS ROG Gjallar Gaming Soundbar
2026 Volumio Primo V3 Music Streamer with Tablet 2026 Volumio Primo V3 Music Streamer with Tablet
Volumio’s third-generation Primo V3 adds a faster processing platform, ESS ES9039Q2M DAC, NOS mode, eight DAC filters, selectable RCA and XLR output levels, and...
Shanling M0 Pura Portable Music Player in-hand Shanling M0 Pura Portable Music Player in-hand
DAPs
Shanling M0 Pura packs hi-res playback, dual DACs, microSD storage, Bluetooth, and USB DAC support into a tiny $129 DAP.
Final DX10000 CL Collectors Edition Headphones Final DX10000 CL Collectors Edition Headphones
Can Final’s $8,499 DX10000 CL justify its True Diamond driver and closed-back flagship design, or is the price the real headline?
Daily Deals
TIDAL is raising prices in August 2026. How does it compare to Apple Music, Spotify, Qobuz, Amazon Music, Deezer and YouTube Music?
Bluesound NODE review: Can the $750 streamer outclass WiiM and Cambridge with improved sound, stable BluOS, and Dirac Live potential?
Dirac Live Processor brings Room Correction, Bass Control, and Active Room Treatment to PC and Mac users with compatible audio systems.
PSB’s iQ Series powered speakers bring BluOS, HDMI eARC, phono, USB C, and subwoofer control to compact stereo systems from $999.
miniDSP Tide16 adds Dirac Live ART, 16 channel processing, and advanced room correction. Is this the smarter AV processor play?
An immersive and dynamic listening experience, with a bold omni-directional design that creates a spacious, all-encompassing soundstage.
Dirac Live Bass Control adds smarter bass to NAD M33, M33 V2, M10 V2 and C 658 streaming amps, but it is not free.
