Digital Music Systems
NAD Unveils Masters M10 V3 BluOS Streaming Amplifier: CEDIA 2024
At $2,499, the NAD M10 V3 (3rd gen) streaming amplifier adds a MM phono input along with Dirac Live Room Correction and Bass Control.
NAD Masters M10 V3 Streaming Amplifier
If you have not already considered a streaming or network amplifier, the new NAD Masters M10 V3 should be very high on your audition list. Having spent a considerable amount of time with the previous generation and other NAD network amplifiers over the past 5 years, we have a lot of confidence that this new model is going to be an exceptional performer.
Not only does it offer a lot of connectivity options; including an HDMI eARC for those looking to consolidate their music listening and movie watching in one compact system, but it also offers Dirac Live Room Correction to help with loudspeaker setup in rooms that may not be ideal.
NAD Masters M10 V3 Streaming Amplifier with NAD C 588 Turntable and DALI Epikore Bookshelf Speakers
NAD Masters M10 V3 BluOS Streaming Amplifier with NAD C 588 Turntable and DALI Epikore Bookshelf Speakers
NAD Masters M10 V3
NAD M10 V3 BluOS Streaming Amplifier claims improved performance using the latest generation of audio technologies over its predecessor, the NAD M10 V2.
The V3 has a full-color touchscreen display and brushed aluminum chassis, and features an ESS SABRE ES9039 DAC that delivers incredible dynamic range and ultra-low distortion.
From Cas Oostvogel, Product Manager at NAD Electronics: “The original M10 was first introduced in 2019, and it was well beyond our expectations in design and performance, The M10 V3 builds on this success through the advancement of new DAC technology and blending the convenience of modern music streaming with the rich listening experience of vinyl.
The M10 V3 features a Hybrid Digital amplifier with nCore technology that is rated to deliver 100 watts of Continuous Power (into 8 and 4 Ohms) and 160 watts of Dynamic Power (8 Ohms), with virtually zero noise or distortion. Just connect the M10 V3 to the speakers of your choice and start listening.
The M10 V3 includes abundant inputs and outputs to connect any source, including a new dedicated MM phono input that adds RIAA equalization. A USB Type A input is provided for connecting a computer or music drive. RCA stereo analog, Optical, and Coaxial inputs are also included.
HDMI eARC is also included for enhanced audio while watching TV and enjoying shows, movies, and games.
BluOS
BluOS 4 App Update
The V3 incorporates BluOS, the multi-room music platform, that can be controlled from any smartphone, tablet, or desktop. Users can use BluOS to stream music streaming services, internet radio stations, and personal music libraries stored on a network drive or computer. BluOS supports hi-res audio up to 24-bit/192kHz.
BluOS allows the V3 to be connected to compatible wireless speakers and audio systems for a multi-room music experience.
BluOS also enables the M10 V3 to be used as a wireless Dolby Digital home theatre system. Using the BluOS app, M10 V3 can wirelessly connect to a second M10 V3, or other BluOS-enabled speakers, and create an immersive 4.1 home theatre system from a sleek and compact device. Apple AirPlay 2 and aptX HD Bluetooth are also supported for limitless streaming of any app or service.
The M10 V3 is compatible with Dirac Live Room Correction and Bass Control. Dirac’s app measures room acoustics and eliminates standing waves, reverberations, and other unwanted distortions.
Dirac Live Bass Control (available as an upgrade) allows users to optimize the subwoofer output in both time and frequency to deliver a smooth and seamless response between the subwoofers and main speakers.
The included BC1 Remote Control features an EQ button for selecting programmed Dirac filter profiles.
From Cas Oostvogel: “With Dirac Live Bass Control available on the NAD M10 V3, we’ve seamlessly integrated Dirac’s advanced bass management algorithms to ensure optimized performance and the most precise and immersive low-frequency experience,…Our partnership with Dirac exemplifies our commitment to elevating audio quality, providing listeners with unparalleled sound clarity and depth for stereo and home theater.”
NAD Masters M10 V3 Rear
M10 V3
Comparison
M10 V3M10 V2
Price$2,499$2,499
BluOS Streaming AmplifierYesYes
Wireless 4.0, 4.1, 4.2 Surround Sound (requires compatible speakers)YesYes
Hybrid Digital NCore Amplifier YesYes
Continuous Power100W into 8/4 Ohms100W into 8/4 Ohms
Dynamic Power160W into 8 Ohms 300W into 4 Ohms160W into 8 Ohms 300W into 4 Ohms
DACESS Sabre ES903932-bit/384kHz ESS Sabre DAC
MQA decoding and renderingYesYes
Status DisplayColor LCD touchscreen displayIPS Color LCD display
Amazon Alexa & Apple Siri voice controlYesYes
AirPlay 2 YesYes
Two-way Qualcomm aptX HD  BluetoothYesYes
Roon ReadyYesYes
Spotify Connect and Tidal ConnectYesYes
NFC Bluetooth pairing for compatible devicesYesYes
BluOS multi-room capabilityYesYes
Gigabit EthernetYesYes
WiFi (ver 5)Yes Yes
HDMI eARCYesYes
USB Type A InputsYesYes
Analog Stereo Line Input YesYes
Coax/Optical Digital InputsYesYes
Phono Stage (MM)Yes
Preamp OutputYesYes
Subwoofer Output2 (independent)2 (independent)
Dirac Live (Limited to 500Hz) license included.YesYes
Dirac Live Full Frequency and Bass control optional BC1Yes
IR remote control with Dirac filter switchingYes
IR Input, 12V Trigger OutYesYes
BluOS apps for iOS, Android, Mac OS, and WindowsYesYes
Streaming Music Services via BluOSYesYes
Internet Radio via BluOSYesYes
Control SupportBC1 Wireless Remote
Crestron
Control4
RTI
URC
Elan
Lutron
iPort
IR Wireless Remote
Crestron
Control4
RTI
URC
Elan
Lutron
iPort
Dimensions (WHD)215 x 100 x 260 mm
8 1/2 x 3 15/16 x 10 1/4 inches
215 x 100 x 260 mm
Shipping Weight5 kg (11 lbs)5 kg (11 lbs)
NAD Masters M10 V3 Streaming Amplifier Front
Price & Availability
Update (September 24, 2024): The NAD M10 V3 BluOS Streaming Amplifier is available now for $2,499 at Crutchfield with international pricing set at EUR €2,499 or GBP £1,999.
Related Reading
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Ask an Expert
Just what is a network streamer? Our explanation and 9 digital streaming options from $99 to $2,500 that offer the best for less.
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
