NAD Masters M10 V2 Streaming Amplifier Adds Power and Dolby Digital Decoding
Does the new NAD Masters M10 V2 Network Amplifier deliver more than the Naim Uniti Atom for $500 less? It would appear we have a fight.
NAD M10 V2 Streaming Amplifier
Network streaming amplifiers have become the focus for numerous high-end brands in 2021 and the two brands who have consistently delivered in terms of access to streaming platforms, superior control apps, and sonic performance are our friends at Naim Audio and NAD. The NAD Masters M10 V2 Streaming Amplifier represents a new chapter for this well-received product and it’s clear that NAD are looking to dethrone the Naim Uniti Atom which currently sits at the top of the pyramid.
Naim Audio Uniti Atom
The Competition: Naim Uniti Atom
How does NAD plan on doing this?
From a cursory look at the new spec sheet, the NAD Masters M10 V2 is going to deliver more power, an improved control app, Dolby Digital decoding, and a lower price.
The NAD Masters M10 V2 features 100 watts per channel of amplification and BluOS streaming capabilities, and adds the capability to expand with Dolby Digital Surround decoding, an enclosed IR remote control, and updated gain algorithms. It ships globally in August 2021 and will retail for US $2,749.
The Naim Uniti Atom retails for $3,290 which is considerably more and that’s enough of a price difference to buy a quality entry-level audiophile turntable like the Pro-Ject Debut EVO along with the M10 V2.
Just Add (More) Speakers
The M10 V2 includes audiophile–grade speaker terminals and two independent subwoofer jacks. Output settings for the subwoofer are easily controlled and adjusted through the BluOS Controller app.
NAD M10 V2 Streaming Amplifier Front
Front: NAD Masters M10 V2
NAD M10 V2 Streaming Amplifier Rear
Rear: NAD Masters M10 V2
Home theater fans can easily build a Dolby Digital Surround Sound wireless 4.0, 4.1 or 4.2 immersive home theatre system using a pair of BluOS surround-enabled wireless speakers or amplifiers. The M10 V2 is capable of transmitting to rear channels wirelessly, with very low latency, making connecting wires around the room unnecessary. Otherwise the original M10 may fit the bill for those without home theater needs.
Total Control
The M10 V2 offers an abundance of control options including a full- color touchscreen front panel. New to this iteration of the product is an included an IR remote control for easy access to basic audio controls and presets.
Streaming music can be controlled through the BluOS app, which includes dozens of natively integrated music streaming services and thousands of Internet radio stations.
The NAD Masters M10 V2 supports AirPlay 2, Bluetooth aptX HD, is Roon Ready, and can be used with popular voice control assistants. For smart homes, the M10 V2 can be integrated into Control4, Crestron, Lutron, and other home-automation systems, so you can control music playback, along with other home systems like lighting, shades, HVAC, and security.
Small & Mighty
Bringing everything but the speakers to the hi-fi experience, the M10 V2 features audiophile-grade amplification and DAC, with built in sources and pre-amp capabilities.
Featuring an upgraded 7” IPS color touchscreen, the M10 V2 delivers purer colors and a wider viewing angle than its predecessor. Renowned nCore amplification technology conservatively rated at 100 watts per channel is included behind the full-color display that doubles as an intuitive touchscreen controller for volume, sources and other audio controls.
The M10 V2’s updated gain algorithms allow for higher output levels with inefficient speakers. Higher gain is also included in the subwoofer outputs, which allows for a wider range of subwoofer-main speaker combinations.
The internal ESS Sabre DAC effortlessly handles BluOS audio streams, which processes up to 24-bit/192kHz, and supports MQA and other lossless and high-resolution audio formats from streaming services such as Amazon Music Ultra HD, Deezer, Qobuz, and Tidal.
Room Friendly
Created by the award-winning design firm DF-ID, the M10 V2 features a solid brushed aluminium chassis and Gorilla Glass top and front panels. The minimalist design allows for the NAD Masters M10 V2 to fit into any living space, and does include the addition of Dirac Live room correction which has proven to be very effective with other NAD network amplifiers.
The enclosed calibrated microphone allows for measurement of the room’s acoustic anomalies, helping to correct peaks and dips caused by the room’s acoustics up to 500Hz (a full-bandwidth version is available through Dirac).
Up to five listening profiles can be uploaded and saved to create a tailored experience if there are multiple listening positions, you have two or more channels active or want to compensate for whether or not the curtains are drawn, for example.
Modern Hi-Fi
The M10 V2 includes RCA analogue, optical and coaxial digital, HDMI eARC, and USB Type A inputs, to connect compact disc players, game consoles, external drives, media adapters, flat-panel displays, and other components.
Two-way aptX HD Bluetooth is also featured showcasing the versatility of the M10 V2. Listeners are further able to choose their listening medium of choice such as stereo loudspeakers, wireless headphones, a surround sound setup or a multi-room set-up of up to 63 other BluOS wireless players.
Features
  • Wireless 4.0, 4.1 and 4.2-channel surround sound options (new in V2)
  • Hybrid Digital nCore Amplifier with updated gain algorithms
  • Continuous Power: 100W into 8/4 Ohms
  • Dynamic Power: 160W into 8 Ohms 300W into 4 Ohms
  • 32-bit/384kHz ESS Sabre DAC
  • Dirac Live Room Correction
  • IPS Color LCD display
  • Infrared remote control handset included
  • Amazon Alexa & Google Assistant voice control skills
  • AirPlay 2 integration, with support for Siri Voice Assistant
  • Roon Ready
  • Spotify Connect and Tidal Connect
  • Two-way Qualcomm aptX HD Bluetooth
  • NFC Bluetooth pairing for compatible smart devices
  • BluOS multi-room compatible
  • Gigabit Ethernet; Wi-Fi 802.11ac (WiFi 5)
  • HDMI eARC, USB Type A inputs
  • Stereo line analogue and coaxial/optical digital inputs
  • Preamp output, two independent subwoofer outputs with updated gain algorithms
  • IR Input, 12V Trigger Out
  • Apps for iOS, Android, macOS, Windows, Crestron, Control4, RTI, URC, Elan, Lutron, iPort
  • Wide variety of premium music services supported in BluOS app, including Amazon, Spotify, Tidal, TuneIn, Napster, Deezer, Qobuz and many others
  • Support for all major lossless and lossy formats, including WAV, FLAC, AIFF, ALAC, AAC, MP3, Ogg Vorbis, and others
  • MQA decoding and rendering
Price & Availability
The NAD Masters M10 V2 BluOS Streaming Amplifier will be available globally this month (August 2021) for USD $2,749.
For more information: https://nadelectronics.com
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Hi-Fi Components
On Thursday, February 20, 2025, the latest Focal Powered by Naim luxury audio store opens in Tampa, Florida.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn't for everybody, but it's hard not to be impressed with its styling and audio technology.
Depending on your budget, the $499 NAD C 316BEE V2 might be the ideal stereo integrated amplifier to build a hi-fi system around.
At $3,680, the Eversolo DMP-A10 music streamer packs in so much it just may be the Swiss Army Knife of network streamers.
