NAD M2 Direct Digital Amplifier
Revolutionary Masters Series Amp Implements New Digital Correction Technology for Dynamic, Efficient, Musically Revealing Performance
NAD Electronics, the highly regarded manufacturer of high-performance audio/video components, introduces the Masters Series M2 Direct Digital Amplifier, delivering in the culmination of a decade long research project a new level of amplifier performance. Immensely powerful, dynamic, efficient, and musically revealing, the M2 is a true digital amplifier that sets new benchmarks for both measurable performance and subjective musical quality.
Superior to any previous digital amplifier, the M2 can be thought of as a Digital-to-Analog Converter (DAC) that directly drives a loudspeaker, but with the same precision as the very best low-level DACs. The M2’s technology is far more sophisticated than the Class D analog amplifiers that are often erroneously referred to as ‘digital.’ In fact, the M2 is the first digital amplifier that can match the best linear amplifiers for low noise and distortion, delivering better than Class A sound with Class D efficiency. At the same time, the M2 is capable of delivering startling power, 250 Watts to each of two channels at 4 or 8 Ohms continuous power, and 500 Watts IHF Dynamic power.
NAD has long been a leader in amplifier technology, extending back to the late Seventies, and has been responsible for many groundbreaking innovations. NAD published a scientific paper in the 1980s defining the importance of Dynamic Power for an amplifier reproducing recorded music. This led directly to the Power Envelope, PowerDrive and Soft Clipping circuits. More recently NAD’s Director of Advanced Development, Bjorn Erik Edvardsen, has developed a unique Distortion Canceling Circuit and Adaptive Antisaturation Clamp (BEE Clamp) first introduced in the Masters Series amplifiers. NAD has also long been committed to creating a digital amplifier — BUT only if it could meet or exceed the performance levels of its own best analog amps, in contrast to the many manufacturers that have ‘gone digital’ with cost savings their primary goal. The M2 is the amplifier NAD has been waiting for, and working toward — a true digital paradigm breaker.
The M2 can also be said to represent a number of FIRSTS. It is the first digital amplifier to fully exploit the resolution potential of HD audio and a fully digital signal path, the first audio amplifier to use high-speed digital error correction to reduce distortion while maintaining full HD resolution, the first digital amplifier to fully implement digital closed-loop processing (a.k.a. error correction); and the first digital amplifier to implement a new technology called Direct Digital Feedback developed by U.K.-based Diodes Zetex Semiconductors Ltd. during its collaboration with NAD on the M2 project.
The M2 uses a unique, custom implementation of Diodes Zetex’s patented Direct Digital Feedback Amplifier™ (DDFA) architecture within a Xilinx field programmable gate array to provide a custom platform for blending DDFA technology with NAD’s own innovations. As a result, the M2 redefines what is possible with digital amplifier technology.
Reinventing Feedback
The M2 takes in a digital signal and outputs an analog signal to drive the loudspeaker. It avoids the limitations of conventional error correction or ‘feed back’ approaches used to achieve very low distortion by generating a feedback signal through comparison with an extremely pure reference, then converting the signal to the digital domain at an 108MHz sample rate before using it for correction. Direct Digital Feedback simply determines the pulse area error, no matter the cause, and passes the information to the digital domain for compensation.
The M2 possesses an extremely wide data path that allows compensation without truncating any information in the original signal. The result: very low noise and distortion in the audio band, combined with blinding speed and precision.
Streamlined Signal Path
Since the M2 can accept a digital PCM input directly, it completely eliminates the noise and distortion added by the cascaded analog amplifying stages typically found in traditional Class AB or even Class D amplifiers. Such streamlining of the system architecture can also reduce the residual noise and distortion of the overall system by eliminating several amplifier stages. The result is a stunning sense of musical intimacy, a feeling of being closer to every performance.
The M2 also includes a DSP is custom programmed with NAD’s high-resolution digital volume control possessing a broad attenuation range and perfect channel balance. A five-position digital impedance compensation filter allows fine-tuning the top octave to match the selected speaker impedance, resulting in a perfectly flat frequency response at 20kHz.
Unmatched Versatility
The M2 is also equipped with a fully balanced, state-of-the-art Analog-to-Digital
Converter (ADC) to accommodate existing analog audio sources and because some owners will want to use a traditional analog preamplifier. The analog input buffer amp and the ADC are the highest quality available, and accept both a single-ended input and a balanced XLR input.
A unique Digital Processor Loop allows advanced users to insert external digital filters into the signal path. For example, the M2’s optical TosLink jack allows fuss-free connection to Macintosh and PC computers, which can access a wide library of crossover filters and room correction programs. Digital outputs in both coaxial and optical formats make it possible to use multiple M2s for the bi- or tri-amplification of advanced loudspeaker systems.
Power and Control Integrity
The M2 employs three power supplies, all highly efficient switch mode types. Each channel receives its own high current power supply in a dual mono configuration. The input stage and control sections also receive dedicated power supplies with multiple regulated secondary voltages for individual sections. The M2’s Digital PowerDrive™ circuit further refines loudspeaker performance by maintaining optimum power delivery and the lowest possible distortion. The M2 has excellent dynamic power capabilities, unlike most digital amplifiers without power reserves. NAD’s Digital Soft Clipping™ prevents the harsh sound and potential speaker damage that can result when a severely overdriven amplifier clips the tops and bottoms of the sine wave. The M2 completely controls this behavior with digital precision.
Equally important, the M2 has been carefully engineered with multi-stage fail-safe protections to prevent amplifier or speaker damage under fault conditions. It handles short circuits, DC offsets, overheating, and over current faults instantly, while displaying an indication of the fault on the front panel. The M2’s RS-232 serial interface allows it to be controlled from a PC or through advanced control systems like those from Crestron and AMX. A 12V Trigger and IR Input permit other popular control options, and add flexibility for home and studio use.
NAD’s M2 Direct Digital Amplifier will be available this Summer from authorized NAD dealers at a suggested price of $5,999 (U.S. MSRP).
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Class D amps from $130 to $50,000—pulling more ears into hi-fi without demanding you sell a kidney. Solid tech, serious power, and none of...
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
Class D amplifiers are revolutionizing the audiophile world, delivering top-tier sound without the hefty price tag. Discover how brands like NAD, Topping, and SMSL...
$3,500 is a lot of money for a hybrid digital power amplifier. The NAD M23 is not your typical hybrid digital power amplifier. Not...
Flagship integrated amp featuring Purifi Eigentakt Hybrid Digital amplifier technology, built-in BluOS multi-room streaming, 32-bit DAC, full MQA decoding, and Dirac Room Correction.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
