NAD C 389 HybridDigital DAC Amplifier Unveiled: High-End Munich 2022
High-End Munich 2022 has begun and the NAD C 389 HybridDigital DAC Amplifier offers more for less.
High-End Munich 2022 is underway for the first time in three years, and it’s going to be one of the best consumer A/V shows in many years as we emerge from the pandemic and hundreds of brands pull back the curtains on thousands of new products. We expect to see a flood of affordable products this year because the market is evolving; NAD has been focused on this move to streaming for many years and we’re starting to see products that offer better sound quality, modularity, and lower prices.
NAD Electronics today announced the C 389 HybridDigital DAC amplifier, which appears to be a less powerful version of NAD’s C 399; it chops about 25% off the price and power. The C 389 clocks in at 130 watts per channel versus 180 watts for the C 399.
The key difference is in the amplification topology. The C 399 uses the superior nCore amp technology whereas the C 389 uses multiple HybridDigital UcD amplifier modules, still excellent, in a balanced bridged configuration. Lastly, there’s slight space savings with the C 389. It’s just over 3/4″ shorter at (100 mm / 3-15/16”) than the C 399 (120mm / 4-3/4”).
NAD C 389 Integrated Amplifier Front
Priced at $1,499, the C 389 features the same 32-bit/384kHz ESS Technology Sabre DAC chip used in the brand’s up-market Masters Series amplifiers. The chipset claims to offer near-zero levels of clock jitter, exceptionally wide dynamic range, and ultra-low noise and distortion, delivering astonishing clarity and holographic imaging on all sources.
For the output stage, the C 389 uses a customized version of NAD’s HybridDigital UcD design, with multiple UcD amplifier modules in balanced bridged configuration and an innovative switch-mode power supply that can provide ample reserves of current on demand.
Delivering 130 Watts per channel of continuous power, the C 389 can produce real-life listening levels with any loudspeaker load, with virtually unmeasurable distortion and noise through the audioband, and effortless reproduction of musical transients.
NAD C 389 Integrated Amplifier Rear
With a full suite of digital and analogue inputs, including an ultra-low-noise phono stage and HDMI eARC interface, the C 389 can accommodate all your source components. In addition to two sets of speaker outputs, the C 389 has two subwoofer outputs, preamp outputs, and a dedicated headphone amp.
Modular Design
The C 389 incorporates the latest iteration of NAD’s Modular Design Construction technology, MDC 2, and with its two MDC2 expansion slots, the C 389 can adapt to technical advances and evolving user needs.
Introduced in 2006, NAD’s Modular Design Construction future-proofing technology lets owners of MDC-capable components add new capabilities by inserting an expansion module into an MDC slot on the rear panel.
Introduced in 2021, MDC2 is an all-new design that allows two-way communications between the expansion module and host component. NAD’s first MDC2 module is the MDC2 BluOS-D, which features BluOS high-res multi-room streaming and Dirac Live room correction.
BlueOS
The MDC2 BluOS-D connects to your home network via Wi-Fi or wired Ethernet. With the MDC2 BluOS-D installed, the C 389 can be part of a whole-home music system with as many as 64 zones.
Controlled via the BluOS Controller app, available for Android, iOS, macOS, and Windows, listeners can play music from over 20 streaming services including Tidal, Deezer, Qobuz, Amazon Music HD, or Spotify, or from their personal music libraries. Like all BluOS-enabled components, the MDC2 BluOS-D will bring MQA decoding and rendering capability to the C 389, as well Apple AirPlay 2 and control by popular voice assistants.
Connect the supplied microphone to the MDC BluOS-D’s USB port, and then run the free Dirac Live app on a smart device or personal computer. Dirac Live room correction compensates for acoustic problems like standing waves and room reflections. The results are transformative and offers deeper, more textured bass; more precise imaging; and improved timbral accuracy.
Key Features
  • Customized HybridDigital UcD amplifier in fully balanced bridged configuration
  • Continuous Power: 2 x 130 Watts per channel into 8/4 ohms (preliminary)
  • Instantaneous Power: 210 W into 8 ohms, 300 W into 4 ohms, 350 W into 2 ohms (preliminary)
  • Vanishingly low harmonic and intermodulation distortion
  • Nearly unmeasurable noise through the entire audioband
  • Dual MDC2 ports for expanded functionality
  • Optional MDC2 BluOS-D module adds BluOS Hi-Res multi-room music streaming and Dirac Live room correction
  • Jitter-free 32-bit/384kHz ESS Sabre DAC
  • Ultra-low-noise MM phono stage with infrasonic filtering circuitry
  • Two optical, two coaxial digital inputs
  • HDMI-eARC input
  • Two pairs of line-level analogue inputs with ultra-low-noise buffer amplifiers
  • Speaker A/Speaker B outputs
  • Two-way Qualcomm aptX HD Bluetooth
  • Dual subwoofer outputs
  • Dedicated headphone amplifier
  • CI-Friendly – IR remote, 12V Trigger in/out, IR in/out, RS-232 Serial port
  • Seamless integrations with smart home control systems such as Control4, Crestron, RTI, URC, Lutron, and Elan
Price & Availability
The NAD C 389 HybridDigital DAC amplifier will be available for retail sale in early Summer 2022 for a suggested retail price of $1,499 USD.
Related: Best Streaming Amplifiers
Epson QS100 UST Projector Front Lifestyle
Epson just expanded their high brightness Q Series projector line to include a UST projector for those looking for a discrete large screen viewing...
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Digital Music Systems
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn't for everybody, but it's hard not to be impressed with its styling and audio technology.
Depending on your budget, the $499 NAD C 316BEE V2 might be the ideal stereo integrated amplifier to build a hi-fi system around.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
