NAD C 245BEE Four-Channel Power Amplifier
Provides Numerous System Building Options, Power to Spare, Optional Bi-Amplification and Multizone Compatibility
NAD Electronics, the highly regarded manufacturer of high-performance audio/video components, introduces the C 245BEE Four-Channel Power Amplifier, an uncommonly talented installer-friendly amplifier.
The exceptionally versatile C 245BEE features a 4-channel architecture that provides installers with several system building options. When used with NAD’s C 165BEE Preamplifier, it delivers more than enough power to drive virtually any loudspeaker, as well as the option to bi-amplify. Connected to the Zone Output of an NAD AV Receiver, the C 245BEE can also send different music programs to remote speakers.
The C 245BEE was designed, like many earlier generations of award-winning NAD amplifiers, by NAD Engineer Emeritus, Bjorn Erik Edvardsen. Harnessing multiple discrete high-power output devices, it easily provides the instantaneous peak current required for good bass response.
The C 245BEE is rated at 35 Watts/per channel, Minimum Continuous Power, into 4 or 8 ohms, with all channels driven simultaneously, for 20Hz — 20kHz, with 0.03 percent THD (NAD Full Disclosure Power). It can also handle 55W, 85W and 100W Dynamic Power into 8, 4 and 2 ohms, respectively; and 2 x 90W Minimum Continuous Power into 8 Ohms in bridge mode.
Vanishingly low distortion and the near absence of noise allow music to emerge from a ‘black’ background that enhances stereo perspective, and enables the subtle details of the music to be clearly heard. Generous dynamic power gives music a relaxed yet lively quality. The power supply features a custom toroidal transformer that maintains very low impedance for the lowest noise possible and a good damping factor.
Value and Flexibility
The C 245BEE has three options for powering up: a front panel switch, a 12V trigger control (supported by many companion NAD products), and a signal-sensing ‘auto’ turn on. In Standby mode, it draws less than one Watt thanks to a separate high-efficiency power supply, saving power and reducing carbon emissions. A ‘vacation’ switch completely disconnects the power.
Each input has a ‘loop out’ feature allowing multiple C 245BEEs to share the same signal, which is ideal for elaborate custom installations. Pairs of channels can be switched on and off with Speaker A and B switches on the front panel. Additional refinements include a short signal path from input to output, gold-plated sockets, multi-way binding post speaker outputs, and a detachable IEC power cable.
Whether it’s used to bi-amp stereo speakers, add surround channels to a Home Theatre, or power music zones to a whole house audio system, the C 245BEE has what’s needed for great performance. Unique in its blend of performance and flexibility, the C 245BEE is also a tremendous value, equivalent to amplifiers costing two to three times more.
The C 245BEE 4-Channel Power Amplifier will be available later this month from authorized NAD dealers for a suggested price of $599 (U.S. MSRP).
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Depending on your budget, the $499 NAD C 316BEE V2 might be the ideal stereo integrated amplifier to build a hi-fi system around.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Digital Music Systems
At $2,499, the NAD M10 V3 (3rd gen) streaming amplifier adds a MM phono input along with Dirac Live Room Correction and Bass Control.
Latest generation of popular network amplifier features upgraded ESS Sabre DAC, MM phono input, Dirac Live readiness, and Dolby Digital decoding.
