Musical Fidelity Unveils Nu-Vista Vinyl S — The Phono Stage Nobody Asked For but Your 600.2 and 800.2 Now Guilt-Trip You Into Buying
Musical Fidelity’s Nu-Vista Vinyl S brings flagship tech to a smaller chassis with extensive MM/MC flexibility, but its $5,500-$6,500 price enters fierce high-end competition.
Musical Fidelity Nu-Vista Vinyl S Phono Stage Silver Angle
If you’ve got any money left after your RSD Black Friday crawl — and let’s be honest, most of us don’t — Musical Fidelity has a shiny new way to drain whatever remains. The new Nu-Vista Vinyl S phono stage arrives as the high-end companion to the Nu-Vista 600.2 and 800.2 integrated amplifiers, underscoring that record playback is still very much alive, but also very much a luxury sport. This one is aimed squarely at listeners shopping in the $5,000 to $7,500 phono pre-amp tier. Ouch. It’s a serious piece of engineering with the full Nu-Vista treatment, but your wallet might need triage after this one.
Nu-Vista Vinyl S Delivers Flagship Architecture in a Smaller Matching Chassis
musical-fidelity-nu-vista-s-front-internal
Musical Fidelity Nu-Vista Vinyl S internal circuitry
The Nu-Vista Vinyl S carries over the core engineering from Musical Fidelity’s Nu-Vista Vinyl 2, including its fully balanced and discrete layout built around eight 7586 nuvistor valves. The difference is the enclosure. Musical Fidelity has reworked the design into a smaller chassis that aligns cleanly with the latest Nu-Vista components.
It keeps the practical elements intact, with a full range of loading, gain, and connection options that make it straightforward to integrate into high-end vinyl systems. For Nu-Vista owners who want a serious phono stage that reflects the flagship’s approach without adopting its full size, the Vinyl S lands directly in that lane.
musical-fidelity-nu-vista-s-rear-silver
Musical Fidelity Nu-Vista Vinyl S (rear) in silver
Musical Fidelity has equipped the Nu-Vista Vinyl S with two balanced XLR and two unbalanced RCA inputs, along with both balanced and unbalanced outputs. Users can fine-tune gain, capacitance, impedance and EQ settings, plus engage a two-stage subsonic filter. This makes the Vinyl S adaptable to a wide range of moving-magnet and moving-coil cartridges.
Its phono pre-amplification section uses three gain stages powered by Class A discrete transistor circuitry. Musical Fidelity chose a fully discrete layout rather than common integrated-circuit designs after extensive listening tests, aiming for the flexibility and component-level control that discrete architecture allows.
musical-fidelity-nu-vista-s-top-internal
The EQ stage is fully passive and split into two sections for improved accuracy of the intended curve and better impedance behaviour. In addition to RIAA, the Vinyl S also includes DECCA and COLOMBIA EQ curves for records that benefit from alternative mastering standards.
The Vinyl S continues the brand’s emphasis on low-noise power design. Super Silent Power Transformers are supported by industrial-grade power sockets with EMI filtering and a DC blocker to reduce interference and eliminate transformer hum.
musical-fidelity-nu-vista-s-top-internal-angle
Its encapsulated toroidal transformer has low core saturation and minimal electromagnetic radiation, making it particularly suitable for phono-level signals. Each discrete amplification stage receives DC-servo control, and the preamplifier runs from two symmetrical low-noise power supplies, one per channel. All balanced nuvistor power-supply stages are passively filtered and regulated for consistent, low-noise performance.
The new chassis matches the mechanical standards of the larger Nu-Vista components. Front and side panels are milled from extruded aluminium, providing rigidity and effective resistance to external vibration. The interface mirrors the layout of the Nu-Vista Vinyl 2 for simple operation, and the updated “S” remote adds convenience for adjustments from the listening position.
musical-fidelity-nu-vista-s-remote-silver
Musical Fidelity Nu-Vista Vinyl S Phono Stage Technical Specifications
Key performance figures for the Nu-Vista Vinyl S include frequency-response deviations of ±0.25 dB for moving-magnet and ±0.3 dB for moving-coil operation. Gain is selectable, reaching up to 69 dB on the balanced XLR output.
MM impedance is fixed at 47 kΩ, while MC impedance is adjustable from 5 to 47 kΩ. EQ support includes RIAA, DECCA and COLUMBIA curves. Subsonic filtering offers three choices: Off, Mild (IEC) and Standard.
The Nu-Vista Vinyl S weighs 14 kg (about 30.9 lbs) and measures 483 × 131 × 404 mm (approximately 19 × 5.2 × 15.9 inches).
The Bottom Line
Musical Fidelity’s Nu-Vista Vinyl S is a serious piece of engineering, built to match the aesthetic and technical ambition of the latest Nu-Vista series. It delivers a fully balanced, discrete architecture with nuvistor valve stages, extensive loading options and multiple EQ curves — the kind of precision vinyl enthusiasts actually need when dealing with cartridges that rarely behave the same from model to model. MM cartridges tend to play nice with most phono stages, but MC and MI designs absolutely do not, and the Vinyl S gives you the tools required to dial them in properly.
musical-fidelity-nu-vista-s-front-black
Musical Fidelity Nu-Vista Vinyl S (front) in black
But let’s be blunt: at an expected retail price between $5,500 and $6,500 (with the UK SRP at £5,499), the competition is anything but casual. E.A.T., MOON by Simaudio, Luxman, Balanced Audio Technology, Rega, Pass Labs and Nagra all offer high-end phono stages with comparable flexibility and long-established reputations in this price tier.
And don’t forget that Musical Fidelity’s own M8x Vinyl sits at $4,300, making it a very real alternative for anyone who wants flagship-level flexibility without climbing into Nu-Vista territory.
There’s also a bigger-picture storyline developing. Musical Fidelity recently shifted from Focal Naim Americas to a new distributor, and the brand’s trajectory since Pro-Ject Audio Systems CEO Heinz Lichtenegger acquired it is finally coming into focus. After the successful revival of the A1 and the strong reception of the Nu-Vista Reference series, the Vinyl S feels like another deliberate move toward a more defined, higher-end identity.
For more information: musicalfidelity.com
2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
AVID HiFi launches Pulsus II and Pellar II phono preamps with MM and MC support, lower noise, and refined analog performance.
Are Aavik’s R-x88 Series the ultimate phono stages for MC and DS Audio optical cartridge users, or just Danish analog excess?
iFi's ZEN Air Phono 2 adds MM and MC support with accurate RIAA playback and low noise, offering a flexible $129 upgrade for turntables...
At $3,799, Musical Fidelity’s M6xi delivers 230 WPC with an onboard DAC, HDMI ARC, and MM/MC phono stage, offering a powerful and flexible solution...
Rega's Aos MC borrows from the company’s $7000 reference phono stage at around $2300. Is it the new sweet spot for serious MC vinyl...
