Musical Fidelity’s M8x Vinyl is the Swiss Army Knife of Reference Phono Preamplifiers
Musical Fidelity’s new flagship M8x Vinyl Phono Stage is both fully discrete and fully balanced with improved gain stage and more.
Musical Fidelity M8x Vinyl Phono Stage Silver Front Angle
Pro-Ject Audio Systems CEO, Heinz Lichtenegger, raised a few eyebrows when he announced the acquisition of Musical Fidelity, but it is all starting to make a lot more sense.
Not only has the brand featured a rather successful rebirth with the award-winning A1 integrated amplifier and Nu-Vista Reference series — but it just unveiled one of the most interesting phono preamplifiers we have seen in many years.
If your phono cartridge collection requires something that offers state-of-the-art performance and loading options, the Musical Fidelity M8x Vinyl needs to be on your radar.
Musical Fidelity M8x Vinyl Phono Stage Front View Angle Black
The Musical Fidelity M8x Vinyl Phono Stage comes in black or silver.
Before we delve deeper into what the Musical Fidelity M8x Vinyl has to offer, you are probably wondering if you require a phono pre-amplifier at all.
Depending on the brand/model of your turntable, it may provide one or more connection options:
  • Traditional Phono with Ground Connection – this connection requires that the amplifier you connect to the turntable needs to have a dedicated phono connection supported by a built-in phono stage.
  • RCA Line Outputs – This means that the turntable has a built-in phono preamp and can be connected to any analog RCA input provided on an amplifier or receiver.
  • USB Output – This allows the turntable to be connected to a PC or Laptop. This enables users to rip vinyl records via a PC or Laptop to a digital format such as a USB flash drive or CD.
With that in mind (and leaving out USB for now), if your turntable does not have a built-in phono preamp and your amp or receiver doesn’t have a dedicated phono input, you will need to place an external phono preamp between your amp/receiver and the turntable in order to use it.
Tip: Even if your amp/receiver has a dedicated phono input, an external phono preamp will likely do a much better job than the internal phono stage inside of your amplifier, especially if the external phono preamp is compatible with both MC (Moving Coil) and MM (Moving Magnet) cartridges.
Musical Fidelity M8x Vinyl Phono Stage Front Closeup
There are a wide range of phono preamps to select from and Musical Fidelity offers three models worth considering, the entry-level V90-LPS, high-end M6x Vinyl, and the new flagship M8x Vinyl. Built on the foundation of the M6x Vinyl, the M8x Vinyl adds some new features providing better performance and more flexibility than the M6x.
What’s New?
Whilst the M6x Vinyl is fully discrete, it is not fully balanced. The M8x Vinyl is both. In the M8x Vinyl, each channel’s positive (+) and negative (-) signal has its own amplifier stage. This also means that there are more than double the number of parts in the phono stage.
Musical Fidelity M8x Vinyl Top Open View Inside
The M8x has three gain stages. This allows more gain with lower noise and distortion. Gain settings include 40, 43, 46, 49, 60, 63, 66, 69 dB.
For those with really low output MC cartridges (anything below 0.4mV), the Musical Fidelity M8x Vinyl is ready to properly load and amplify the signal coming out of the cartridge.
The phono pre-amplifier also features discrete input power filtering and DC blocking circuitry. This provides clean power to the fully balanced phono stage.
The Super Silent Power Transformer is now encapsulated to further protect the phono stage from external electro-magnetical radiation.
The M8x Vinyl includes DECCA & COLUMBIA EQ in addition to the standard RIAA EQ found on the M6x Vinyl.
Additional EQ refinements include a dual split-passive EQ stage and two-step subsonic filter.
Musical Fidelity M8x Vinyl Rear
The M8x Vinyl provides more inputs and load settings that support ultra-precise cartridge tuning. RCA and XLR outputs both have their own individual stages allowing them to be used at the same time.
The front panel provides aluminum control buttons and two large control dials (the dial on the left is the input selector and the dial on the right is the gain selector).
The M8x Vinyl carries on the Musical Fidelity tradition of providing sturdy build quality and an external look that matches well with Musical Fidelity amplifiers and associated components.
Comparison
Musical Fidelity M8x, M6x, V90-LPS Phono Stages (Preamps)
M8x VinylM6x VinylV90-LPS
Price$4,299.00$2,399$329
Product TypePhono Stage (aka Phono Preamp)Phono Stage (aka Phono Preamp)Phono Stage (aka Phono Preamp)
MM Input  SpecsMM Input  SpecsMM Input  SpecsMM Input  Specs
Gain at XLR Outputs40dB, 43dB, 46dB, 49dBNot IndicatedNot applicable
Frequency Response±0.2dB (frequency range not indicated)RIAA or RIAA/IEC ±0 .2dB (frequency range not indicated)+0, –0.1dB, 20Hz to 20 kHz
Input sensitivity5mV IN for 500mV OUT (at 40dB, 1kHz)5mV in for 500mV out (at 1kHz)3.0mV for 300mV out
Input impedance47kohm47KΩ47kOhm
Input capacitance50-400pF selectable50-400pF selectable100pf
THD at 1 kHz<0.005%<0.005%0.01%
Overload margin32dB26dB15dB
Signal-to-noise ratio>102dB „A“-wt. at 40dB>101dB>80dB
MC Input SpecsMC Input SpecsMC Input SpecsMC Input Spec
Gain at XLR outputs60dB, 63dB, 66dB, 69dBNot indicatedNot Applicable
Frequency response±0.2dBRIAA or RIAA/IEC ±0.25dB+0, –0.1dB, 20Hz to 20 kHz
Input sensitivity500μV IN for 500mV OUT (at 60dB, 1kHz)500μV in for 500mV out (at 1kHz)400μV for 300mV out
Input impedance5Ω to 47kΩ selectable5Ω to 1.2kΩ selectable100 ohms
Input capacitance400pF fixed470pF fixedNot Indicated
THD at 1 kHz<0.008%<0 .02%0.01%
Overload margin32dB26dB22dB
Signal-to-noise ratio>90dB A-wt. at 60dB>90dB>70dB
Additional FeaturesAdditional FeaturesAdditional FeaturesAdditional Features
EQ curvesRIAA, DECCA, COLUMBIANot IndicatedNot Indicated
Subsonic filtersoff, mild (IEC), standard (at 20Hz with 18dB/octave)Not IndicatedNot Indicated
Inputs 2 x RCA
2 x XLR
2 x RCA
1 x XLR
MM: 1 x RCA
MC: 1 x  RCA
Outputs1x RCA output: unbalanced, left and right 500mV nom, 5V max
1x XLR output: balanced, left and right 1V nom, 10V max
1 pair RCA: left and right 500mV nom 10V max
1 pair XLR (balanced): left and right 1V nom 20V max
1 x RCA
Power Requirements115/230VAC 50/60Hz (factory pre-set)
100VAC 50/60Hz (alternative)
230V/115V Internally set or 100V optional. AC 50/60Hz1x 12v 500mA DC power supply
Power Consumption0 Watts maximum, <0.5 W in standby (orange LED ON)20 Watts maximum. <0 .5W in standby (orange LED on)Not Indicated
Dimensions (WHD)483 x 102 x 381 mm
19 x 4 x 15 inches
440 x 100 x 385 mm
17.3 x 4 x 15.2 inches
170 x 47 x 102 mm
6.7 x 1.85 x 4 inches
Weight (Net)10.6 kg
23 lbs 6oz
5.5 kg
12 lbs 2 oz
600 g
1 lbs 5oz
Musical Fidelity M8x Vinyl Power Supply Inside Angle
The Bottom Line
External phono stages (aka phono preamps) might be the most overlooked audio component, but for those who are vinyl record-listening fans, they are an important piece of the music-listening puzzle. In many cases, they provide the ability to connect many turntables to audio or home theater systems that may not provide a dedicated phono connection.
The reality is that every phono cartridge has its own unique impedance and output that requires proper equalization if you want to listen to it at its best. Whilst most affordable MM cartridges offer very similar output levels (between 2.5mV and 5mV) and a friendly impedance for the vast majority of phono stages included in a wide range of integrated amplifiers and AVRs — the same can’t be said for MC cartridges or even MI (Moving Iron) from brands like Grado Labs.
The Musical Fidelity M8x Vinyl is definitely on the high-end in this product category but if you also have a high-end turntable and audio system it has a lot to offer – provided you have the cash.
Price & Availability
The Musical Fidelity M8x Vinyl is available in the UK (£3599), Europe (€3999) and Australia (AU$7200). The U.S. pricing has been confirmed at $4,299.00.
For more information: musicalfidelity.com
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
Does the Michell Audio range of high-end turntables finally have a complementary phono pre-amplifier to match its capabilities? The Michell Apollo looks ready to...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Phono Preamps are very practical for Vinyl Record enthusiasts, but is the $4900 Grimm Audio PW1 worth it?
The Pro-Ject Phono Box RS2 delivers the presence and gestalt of vinyl in a manner that makes it a genuine threat to more expensive...
Gryphon Audio has teamed up with Helmut Brinkmann to create a dream turntable system for the ultimate in analog playback.
