Motorola XT615 Smartphone
At just 9.8mm thin with a 4-inch edge-to-edge touch screen and Android 2.3, the sleek Motorola XT615 Android smartphone combines technology and style in one device, available in licorice or ultra white. Features include a 8-megapixel camera with LED flash, yet runs on a average speed 800MHz processor, which was probably used to keep the price down.
With the new Moto Switch user interface, this smartphone learns what music you listen to, who you talk to and which apps you use and keeps all of that information front and center. You'll never have to look twice (although you might want to just for fun), because all of your content is displayed on a crystal-clear 4-inch touchscreen that is guaranteed to impress. With an asymmetric design and pulsing lanyard hole light, the Motorola XT615 loves personalization on the outside too, so attach your favorite keychain or phone charms and make it your own.
Motorola XT615 Smartphone - side
Key Features and Specifications:
  • Bands: WCDMA, HSDPA/Quad-band GSM
  • Platform/ OS: Android Gingerbread 2.3 with Moto Switch UI 2.0
  • Dimensions: 117.7 x 60.5 x 9.8 mm/ 123.6g (with battery)
  • Display: 4.0″ 480×854 FWVGA
  • Camera: 8MP LED flash/VGA front, LED Flash
  • Connectivity: 3.5mm, USB 2.0 HS, BT3.0 EDR/A2DP, 3G hotspot, WLAN
  • CPU/Memory: 800MHz; 1GB ROM/512MB RAM, supports up to 32GB microSD card
  • Video & Audio: capture/playback/stream MPEG4, H.263, H.264; AMR, AAC, AAC+, eAAC+, MIDI, MP3, WAV
  • Battery: 1390mAh
  • Others: contact sensor, gravity sensor, eCompass
Pricing and Availability:
The Motorola XT615 Android Smartphone will be available across China and Taiwan (Taiwan Mobile) starting December 2011 for RMB2,999 or NTD$10,900. Check price
See more about: Newest Smartphones, Motorola Smartphones, All Smartphones, Motorola Reviews & News
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
