Moshi Voice Control Digital Clock Radio
Offers 11 voice control commands including playing the radio, setting alarm and asking for the date
Moshi announced the Voice Control Digital Clock Radio. By simply saying “Hello Moshi”, the Digital Clock Radio allows users to activate eleven voice control commands including playing the radio, setting the time, setting alarm, and even snooze.
Similar to the original Moshi Alarm Clock, the Moshi Digital Clock Radio is easy to use and set up. It is equipped with Technology That Listens™ which means the alarm clock recognizes your voice command without any setup required. However, the new Moshi Digital Clock Radio allows users to also easily listen to the radio in the morning without having to find buttons while half asleep or away from the clock.
“The Moshi Voice Control Digital Clock Radio provides comfort and convenience to its users,” said Michael Nostrant, President and CEO of Moshi parent company SnS International. “There is no easier way to wake up or play music other than by saying “Hello Moshi” and having the device submit to your command.”
The Moshi Digital Clock Radio is available now at www.moshilifestyle.com for $69.99 MSRP.
About Moshi:
Moshi specializes in interactive voice recognition technology that is applied to consumer electronics, primarily alarm clocks. Their voice-activated alarm clocks, equipped with Technology That Listens™, are made personally for their customers. They listen to your every command, whether you are setting the alarm from your bed or asking the temperature from the closet.
Moshi is guided by the belief that electronics should work for. Just talk to your clock and it will listen, as all electronics should. Moshi products cater to the fundamental needs of children, adolescents, adults, and seniors alike. Our customers look for fresh, unique and innovative products that provide efficiency and comfort to their lifestyle.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
