Loudspeakers
Mordaunt-Short adds bigger floorstander to Mezzo loudspeaker range
Available Autumn 2008
Building on the enormous success of the Mezzo loudspeaker range, Mordaunt-Short has released the Mezzo 8 floorstander — a true 3-way design. Using one 5¼ mid range and two 6½” Continuous Profile Cone (CPC) bass units, this trio of drivers integrates seamlessly with the Aspirated Tweeter Technology (ATT) providing a phenomenally detailed yet commanding sound with much poise especially for larger listening rooms or home cinemas. Just like Mordaunt-Short’s legendary Performance 6, the mid range itself has its own enclosure and is completely separate from the bass drivers ensuring it deals solely with its allotted bandwidth. The Mezzo 8’s larger cabinet volume provides powerful lower frequencies while the curved design deceives the eye aiding positioning in any size environment. It comes with a custom designed plinth for ultimate stability and ease of use.
Key Mezzo 8 features:
• 25mm aluminium dome tweeter with all new Aspirated Tweeter Technology (ATT)
• Latest generation 5¼” mid and 6½” bass Continuous Profile Cone (CPC) drivers which are light but incredibly rigid to reduce distortion
• Custom designed and isolate mounted crossover for minimal distortion
• Sound deadened driver baskets for low distortion
• Flush front baffle for smooth sound dispersion characteristics
• Striking yet elegant curved cabinet design to reduce standing waves
• Carefully selected internal wadding and critical bracing
• Audiophile grade components throughout
• Stunning light oak and dark walnut finishes
• Easily removable magnetic grilles for an invisible fit with contrasting finishes
• Custom designed plinth for ultimate stability and ease of use
At the heart of Mezzo is its Aspirated Tweeter Technology (ATT). Directly descended from the Performance Series, Mordaunt-Short’s unique high-end tweeter design has been carefully adapted to enable the incredible effect of this patent pending acoustic principle to be experienced across the Mezzo range. Mezzo’s Aspirated Tweeter Technology employs scrupulously designed structural mouldings with strategically positioned vents which help turn rear radiation into “diffuse field energy”. This eliminates the colouration that plagues traditional closed-back designs and means the tweeters literally ‘breathe’ for a phenomenally open and detailed sound. The tweeter also uses an integral one-piece dome and voice coil for more consistent performance across a wider dynamic range. Aluminium is used for the dome as it is light but extremely strong. (See detailed ATT images on the Mordaunt-Short extranet).
Further down the frequency range Mezzo uses the latest generation 5¼” mid and 6½” CPC (Continuous Profile Cone) bass drivers. This proprietary technology produces exactly predictable driver performance by ensuring controlled piston-like movement at low frequencies and minimal break up at higher frequencies. Lightweight and extremely rigid hard-anodised aluminium cones are used for faithful dynamics. This advanced technology produces a deeply stunning and realistic performance with awesome stereo imaging. By keeping the mid range separate from the bass drivers in its own enclosure, it is able to deal solely with its allotted bandwidth reducing inter modulation distortion for a more accomplished and poised sound. The bass drivers themselves provide a rich and commanding sound with flawless timing, perfect for a larger listening room or home cinema.
The driver chassis are bonded to a specially developed sound deadened steel/rubber basket which completely eliminates unwanted resonance effects producing a beautifully clear midrange.
The crossover uses critically selected components for their signal path integrity including high quality polypropylene capacitors in Dual Value Parallel (DVP) configuration which produce outstanding treble. Coiled inductors with low saturation characteristics greatly reduce non-linear distortion artefacts for an extremely clean and detailed sound. The crossover itself is isolate mounted further reducing vibration and unwanted resonance.
One of the most interesting aspects of the speakers’ design is the cabinet. After a critical selection process, a wood composite was chosen and then carefully formed and bonded into shape. Internal bracing provides inherent strength while the cabinet’s curved shape discourages the build up of standing waves for a cleaner and more realistic sound. The curves also offer an aesthetic boon as they give the appearance of a far smaller cabinet but in actual fact provide a bigger enclosure for a more commanding sound. The Mezzo 8 cabinet shares the same footprint with the smaller Mezzo 6 again, adding to the illusion.
Other models already available in the Mezzo range:
The Mezzo 1 proves that Mordaunt-Short’s trademark sound can be delivered from even the smallest of cabinets and offers a taste of genuine high-end hi-fi at a more than attainable price. The ATT tweeter is featured in its most compact cabinet to date and coupled with a 5¼” driver, this petite bookshelf speaker offers a deep and rich performance as well as an impressively large sound stage. Mezzo 1 was designed with two specific purposes in mind; to act as a satellite or rear effect speaker in a home theatre system or as a sublime stereo bookshelf speaker for smaller environments. Either way, these beautiful speakers fit perfectly anywhere.
The Mezzo two-channel range also includes a dedicated standmount the Mezzo 2. Belying its compact size, Mezzo 2 embraces ATT to produce a remarkably expansive sound and stereo image.
Consistent with Mordaunt-Short’s other successful speaker packages, Mezzo features a dedicated centre — the Mezzo 5 — which is designed to deal with the demands of dialogue in movies. Its ATT tweeter integrates fantastically with the rest of the range to produce awesome vocals. The cabinet is a closed box design while the infinite front baffle guarantees consistent dispersion characteristics and performance.
The Mezzo 9 is a truly incredible subwoofer and uses a plethora of features to ensure it integrates seamlessly with any existing home entertainment system. Using dual opposed 8″ CPC ultra long throw woofers in a force cancelling configuration, the sub metes out a thumping 375W of power. All this comes from an incredibly compact cabinet which blends into any listening environment.
The Mezzo 9 subwoofer features a powerful DSP engine which can be tailored to your exact set-up and room acoustics. Notch filters allow response anomalies (room modes) to be equalised out and a Phase Compensation Filter (PCF) enables accurate step-by-step phase adjustment at the crossover point rather than the usual basic phase inversion switch on lesser products. The crossover point is fully adjustable and the roll-off rate selectable. A special test CD and combined Sound Pressure Level (SPL) meter / remote control are supplied making set-up surprisingly simple.
In use the DSP’s engine is able to implement ‘Night’ modes and other dynamic processing so that for instance low level sounds are made louder whilst at the same time explosions appear quieter, ideal for late-night listening. A Music/Movie/Game select mode allows the sub to be changed for specific use and these presets are easily recalled. The sub includes an attractive and dimmable backlit display for full control of all features via the top panel or remote control and this kind of technology once again puts Mordaunt-Short at the forefront of home cinema entertainment.
The Mezzo range comes in a choice of either light oak or dark walnut cabinet that complement any listening environment. The speakers also have easily removable magnetic grilles which sit neatly flush against the baffle.
www.mordaunt-short.com
press@mordaunt-short.com
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
