Montegiro Lusso Turntable
Visually Dazzling Lusso Boasts Revolutionary Design Employing Conical Towers Layered with Aluminum and Acrylic for Equally Exceptional Audio
Koetsu USA, the U.S. distribution arm of the world-renowned Japanese cartridge manufacturer, introduces into the U.S. market the spectacular Montegiro Lusso Turntable, employing a breathtaking design of alternating layers of aluminum and acrylic at the 2009 International Consumer Electronics Show, beginning here today.
The Lusso Turntable by Montegiro, a company exemplifying German engineering at its best, is an extravagant example of audiophile art and performance. It consists of one wide and three narrower conical towers layered with alternating bands of black acrylic and polished aluminum, right up to the aluminum platter topped by an acrylic platter mat. It includes two tonearms — a 10-inch long carbon and a 9-inch SME model 5009, with other arms available as options. It operates at speeds of 33-1/3 and 45 rpm. A basic model of the Lusso comes with three towers and one tonearm.
Sonically, the Lusso is as exceptional as its appearance. It delivers precise, crystalline highs, a rich mellifluous midrange, and a weighty bass that produce an ideal, musically balanced turntable. A new, highly precise high-end synchronous motor suspended within one of the cones drives the system.
The Lusso’s revolutionary design also features an innovative, advanced bearing system characterized by a highly precise milled shaft polished at the end to minimize friction with the bearing balls, which are made of a special ceramic designed for compatibility with the bearing mirror. The bearing mirror is made of sapphire and supplied by a company that fabricates precision parts for Swiss watchmakers. The outer part of the bearing system is made of stainless steel; the inner part, a special, customized bronze.
The bearing plate is also stainless steel and matched to the bearing shaft. Plate and shaft are attached by first heating the plate then inserting the cold shaft. After cooling, the fit is so tight there’s no need for screws or other fasteners. As a result, the system operates remarkably smoothly with very little friction. The cone-shaped towers are not connected to each other, and rest on height-adjustable feet for a perfectly level set up.
The Montegiro Lusso Turntable is available now for a suggested price of $31,527. It can be seen with other outstanding Koetsu USA products at Suite 29-235 at the Venetian Hotel, during CES.
About Montegiro
Montegiro is a turntable specialist exemplifying German engineering at its best. Montegiro has developed designs that travel from minimalist and organic to extravagant and spectacular, from the exotic bamboo base of its elegant Legno turntable to the signature acrylic and aluminum towers of its breathtaking Lusso turntable. At the same time, it has never lost sight of its final goal, sonic perfection. For further technical information, visit www.montegiro.de
About Koetsu USA
Koetsu USA is a vertically integrated distributor of high-end audio products including phono cartridges, tone arms, turntables, preamps, amplifiers, digital players, loudspeakers, cables, racks and other products. Its brands include Koetsu, Chario, Montegiro, Goldenote, Blacknote, and VEXO. For further technical information, visit Koetsu USA’s Web site at www.koetsuusa.com.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
