Monsterously Powerful…Sublimely Delicate… Killer Price… the new AV123 MFW-15 Subwoofer
The MFW-15 subwoofer is part of the next generation of subwoofers from AV123.com. The new line is positioned to be the very best value this leading loudspeaker manufacturer/direct seller has ever offered. The ‘trickle down’ of technology has enabled AV123 to provide gorgeous HAND FINISHED custom cabinets, high quality custom amplifiers and custom drive units at an incredibly low factory direct cost to consumers.
The ~110 pound MFW-15 subwoofer, starting at $599 each, was designed from the ground up by AV123’s Mark Schifter and renowned subwoofer guru Mark Seaton. The MFW-15 features a 25mm front baffle and plenty of bracing along with a custom designed 15″ driver, 350 watt high efficiency design amplifier with separate control panel for Level, Phase and Low Pass Frequency at the top back of the cabinet and an internally folded slot port. The subwoofer is offered in beautiful Rosewood, Cherry, Black and our unique Moho.
MFW-15…
So how does it perform? You can expect 15-17Hz low end extension in most rooms and output of 103dB at 20Hz (1M measurement) and greater than 115dB above 35Hz (1M). It’s not all about room shaking though… the MFW-15 is very smooth and tight; great for the music lover or home theater enthusiast.
All MFW-15’s are wrapped in a real wood veneer (via renewable resource) or beautifully finished in a silky-smooth satin black. The hand finished MFW-15 subwoofer is right at home with fine furniture, and looks far more expensive than its price would suggest. You get all this starting at only $599 for one or $1099 for two in Satin Black. The first units are shipping now.
The MFW-15 subwoofer, from AV123.com, is destined to be THE new reference in performance, value and furniture quality build for an unbelievable price. It is certain to please both music and home theater listeners.
Specifications
• System: Single driver, folded, slot port with front termination
• Drivers: 15″ custom woofer
• Amplifier: Custom 350 watt high efficiency design.
• Control: Easy-access top panel with gain, variable phase and crossover
• Input: High and low level in and out plus LFE in (crossover defeat).
• Frequency Response: 18-200Hz; 15-17Hz in room low end. Greater than 115dB output above 35Hz and 103dB max output at 20Hz at one meter.
• Dimensions: (H x D x W): 23.94″ x 22.44″ x 18.125″
• Weight: ship weight = 125 lbs each
• Price: $599 each in Satin Black. $699 each in real wood finishes. Dual sub special pricing available.
• 3 Year Warranty
• For more information, please visit www.av123.com.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
