55% Thinner Than Conventional TV Cables
Monster is providing owners of flatscreen TVs with a solution to the problem of unsightly “cable clutter” with its new FlatScreen SuperThin Cables for HDMI. Now available at retail, Monster SuperThin Cables for HDMI are 55% thinner than conventional cables, making it easy for consumers to simplify their flatscreen TV connections and create neat, virtually invisible connections for their home theater systems. Importantly, Monster SuperThin Cables for HDMI fully support the HDMI 1.4 standard for high-definition audio and video, allowing consumers to enjoy the maximum performance capabilities of their flatscreen HDTV sets.
Super Thin TVs Need SuperThin Cables for Neat, Clean Installations
The breakthrough SuperThin cable design is ideal for aesthetically designed home theater systems featuring super slim flat-panel TVs, allowing consumers to easily hide their cables from plain view. Ultra-flexible, they bend at near right angles allowing TVs to mount close to the wall, as well as simplifying connections in very tight spaces. Furthermore, the cables feature a paintable jacket for even greater elegance, and “stubby” connectors for seamless integration in home theater installations.
Head Monster Noel Lee noted: “Because they are so much smaller and lighter, our SuperThin Cables match the sleek appearance of the consumer electronics products they connect. Many people have been looking for a way to create totally clean-looking, nearly undetectable flatscreen TV installations, with no compromise in HDTV performance, and Monster SuperThin Cables are the solution.”
Monster’s new SuperThin Cables for HDMI are available in 1-, 2-, and 4-meter versions for suggested retail prices of $49.95, $59.95 and $79.95, respectively.
