A/V Furniture & Accessories
Monoprice Unveils 2 New TV Wall Mounts for 37″ – 110″ TVs
Monoprice has introduced 2 new affordable TV wall mounts that are far superior to any TV stand and decidedly safer if you have kids.
Extended rear view of Monoprice Heavy Duty XL Full-Motion Articulating Extra Long Reach TV Wall Mount (model 44486)
It goes without saying that using a TV stand with a household filled with little children is a very bad idea. You can’t think that it would happen, but we had a neighbor in New Jersey back in the 1990s that experienced the worst kind of tragedy with a 50″ plasma and a little child. I remember cutting the strap behind our Panasonic plasma that kept it secured to a media unit from Crate & Barrel and ordering a Sanus TV wall mount for $350 and never looking back.
Most TV manufacturers recommend that you use a TV wall mount for both aesthetic and safety reasons and they would be correct.
TVs have become larger with each new product cycle and it’s hard to imagine using a table stand with something like the new Samsung 98-inch 98Q80C QLED TV; it’s almost mandatory that you hire an installer to secure something this large to the wall where it can’t be moved.
Monoprice has two new TV wall mounts available and both look like good value for the money depending on the size of your TV.
Monoprice SlimSelect Series Ultra Slim Full-Motion Articulating TV Wall Mount (model 44485)
SlimSelect Series
The $59.99 USD SlimSelect Series Ultra Slim Full-Motion Articulating TV Wall Mount (44485) is probably best for a bedroom or small den where you might not use anything larger than 55″; we have a review sample incoming that I’m going to try with an LG 55″ OLED TV that only weighs 32 pounds.
It’s ultra‑slim low-profile design keeps TVs tight against the wall for an ultra-low profile footprint of .91-inches. Its adjustability extends out to 10.5 inches, has 30 degrees of swivel and up to 10 degrees of tilt range for optimal viewing.
Fits various VESA patterns from 200×200 to 600×400. Ideal for TVs ranging between 37 – 90-inches and weighing up to 110lbs.
Heavy Duty XL
The $179.99 USD Heavy Duty XL Full-Motion Articulating Extra Long Reach TV Wall Mount (44486) is really for larger TVs that are going to be used in a living room or home theater space.
This wall mount is constructed with high quality, cold‑rolled steel capable of supporting up to 275 lbs. and hold extra-large displays ranging from 60 – 110-inches.
You can achieve the perfect viewing angle with full articulation capabilities, including ±5° screen rotation, ‑5° ∼ 10° tilt range, 110° swivel range, and dual extra-long 38.6-inch heavy‑duty extension arms.
It will accommodate VESA patterns of 100×100 to 800×600.
Comparison
SlimSelect Series Heavy Duty XL
MSRP$59.99$179.99
P/N4448544486
TypeFull‑MotionFull-Motion
Minimum VESA200×200100×100
Maximum VESA600×400800×600
Maximum Display Weight110 lbs.275 lbs.
Minimum Display Size37″60″
Maximum Display Size90″110″
Minimum Extension0.91″4.3″
Maximum Extension10.5″38.6″
Wall Plate Dimensions13.8″ x 8.3″27.2″ x 11.5″
Tilt Range0° ∼ -10°‑5° ∼ 10°
Swivel Range±30°±110°
Rotation Range±1°±5°
ConstructionAluminum, Steel, PlasticAluminum, Plastic
ColorBlackBlack
Curved Display CompatibleYesNo
Security SystemNoNo
Built‑in LevelHook‑on bubble level includedNo
Cable ManagementNoYes
UL® CertifiedNoNo
RoHS CompliantYesYes
Compatible Wall TypesBrick, ConcreteBrick, Concrete, and Wood Stud
Packaging MethodCorrugated Box, Poly BagCorrugated Box, Poly Bag
Dimensions (LxWxH)10.5″ x 25.2″ x 17.1″
(266 x 639 x 434 mm)
39.6″ x 24.7″ x 4.3″
(1005 x 628 x 110 mm)
Weight8.8 lbs.
(4 kg)
42 lbs.
(19.1 kg)
For more information: monoprice.com
Related reading: Monoprice Introduces Monolith THX In-Wall Speakers
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
For less than the cost of dinner and a movie out with the family, you can bring home this eight channel home theater speaker...
HDTV 4K & 8K TV
Featuring more competitive pricing, advanced video processing and the Samsung Smart Hub, the new generation of Samsung 4K QD-OLED TVs are very compelling options...
HDTV 4K & 8K TV
First shown at CES 2023, the LG 97M3 Wireless OLED TV with Zero Connect Technology is finally shipping, but only in South Korea.
HDTV 4K & 8K TV
LG Electronics USA and the Bronx Bombers plan on making your trip to Yankee Stadium more enjoyable next season. LG OLED TVs are coming...
Monoprice's latest Monolith Series power amplifiers offer an affordable path for those looking to improve the sound quality of their home theater system.
HDTV 4K & 8K TV
Bang & Olufsen debuts the $63,000 Beovision Harmony 97-inch 4K UHD OLED TV. Does it make sense considering the projector or cheaper OLED alternatives?
Killer pies, the Stanley Cup Playoffs, a surprisingly robust home theater system from Monoprice, and the best A/V furniture from BDI.
