Monoprice Shakes Things Up With Two New Massive THX Subwoofers [Updated]
Monoprice has expanded its Monolith subwoofer range with very powerful THX Ultra certified 13-inch and 16-inch subwoofers.
Monoprice Monolith 13-inch THX Ultra Subwoofer Angle
In order to have a great home theater setup, you need a good subwoofer, and to that end, Monoprice is offering up two that provide more power and low-end bass response than most home theater enthusiasts could possibly hope for.
The two Monolith subwoofers are offered in compact 13-inch and large 16-inch sizes. Let’s take a look at what they offer.
What Both Subwoofers Have in Common
THX Certification Process
THX Ultra Certification: This means that these subwoofers have been submitted and passed THX standards for application and performance.
Lots of Power Output: 2,000-watt (RMS)/3,800-watt (Peak) Class D amplifier with DSP (Digital Signal Processing)
Driver Design: A newly developed high-excursion driver capable of handling the above-mentioned power output without distortion.
Flexible Port Design: The ports can be used in an open, semi-sealed, sealed setup.
Cabinet Design and Finish: Sleek rounded-edge enclosures with a gray oak finish.
Digging Deeper – 13-inch THX Monolith Subwoofer
Monoprice Monolith 13-inch THX Ultra Subwoofer Front Back
Product Number: 41496 (13-inch model)
Driver Size: 13-inches
Driver Material:  2 layer long fiber pulp/glass fiber cone
Voice Coil: 100mm, with high-temperature aluminum wire and black anodized aluminum bobbin construction.
Magnet: 300 oz (that’s 19 pounds!)
Enclosure: The enclosure is made of High-Density Fiberboard (HDF) that is horizontally and vertically braced. 3 ports are provided on the 13-inch model and 4 ports are provided on the 16-inch model, all of which can be left open, partially, or fully sealed depending on application and preference.
Monoprice Monolith 13-inch THX Ultra Subwoofer Interior
Frequency Response (-6db)Sealed PortsVented Ports (2)Vented Ports (3)
Extended EQ N/A16 to 200Hz16 to 200Hz
THX EQ20 to 200 Hz19 to 200Hz20 to 200Hz
Harmonic Distortion: Less than 1% from 20-100 Hz (90dB @ 1m reference point)
Variable Level Control: +15/‑20 dB
Reference Level: 100mV @ 40Hz (89dB @ 1m)
Crossover Control: Inline/Bypass variable from 40 to 160 Hz,
Phase Control: 0 to 180 degrees variable (used to match the in/out motion of the subwoofer driver to the rest of the speakers in your system).
Inputs: 2 RCA, 1 XLR
Outputs: 1 XLR
Signal Turn On: Selectable always on or Auto-Detect.
Auto Turn Off Time: 30 minutes
Dimensions: 23.8″ x 20.3″ x 29.1″ (605 x 515 x 740 mm)
Weight: 153.2 lbs. (69.5 kg)
Finish: Black Ash
Digging Deeper – 16-inch THX Monolith Subwoofer
Monoprice Monolith 16-inch THX Ultra Subwoofer Front Back
The majority of the specifications for the 16-inch model are identical to the 13-inch model, including the inputs, output, and control options.
Here are the features and specifications that are different in the 16-inch Monolith THX Subwoofer.
Driver Size: 16-inches
Number of Ports: 4 (can be sealed or vented)
Frequency Response (-6db) with Extended EQ Operation
  • Sealed Ports: N/A
  • Vented Ports (1): 17 to 200Hz
  • Vented Ports (2): 14 to 200Hz
  • Vented Ports (3): 14 to 200Hz
  • Vented Ports (4): 16 to 200Hz
Frequency Response (-6db) with THX EQ Operation
  • Sealed Ports: 20 to 200Hz
  • Vented Ports (2): 24 to 200Hz
Dimensions: 25.6″ x 22.0″ x 28.1″ (650 x 560 x 715 mm)
Weight: 171.6 lbs. (77.8 kg)
Finish: Black Ash
Monoprice Monolith 16-inch THX Subwoofer Diagram
Price & Availability
  • The 13-inch Monoprice Monolith THX Ultra Certified Subwoofer (Product Number 41496) is available for $1,599 at Monoprice.com
  • The 16-inch Monoprice Monolith THX Ultra Certified Subwoofer (Product Number 42031) is available for $2,299 at Monoprice.com.
UPDATE 11/3/21: Monoprice adds to its Monolith THX subwoofer line with three models in 10, 12, and 15-inch sizes. Read our full report.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Close To Perfect, Expanded Atmos Mix Takes Yes Surround Sound To Immersive Heights.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
