Loudspeakers
Monoprice Announces Monolith THX LCR & Satellite Speakers
Monoprice continues to expand its Monolith THX Certified speaker line-up with LCR and Satellite speakers.
Monoprice Monolith M-OW3
In recent months, Monoprice has greatly expanded its Monolith speaker lineup with three batches of THX Certified subwoofers (1) (2) (3) and the Encore Speaker line
You would think that may be enough, but, nope, the flood of new speakers continues as Monoprice has taken the lid off two wall-mountable THX-certified speakers and a set of wall-mountable compact THX-certified satellite speakers.
This means that no matter what type of speaker setup you desire for your home theater, Monoprice may have just the right solution for you.
What All The Speakers Have In Common
THX Certification: This speaker line has been submitted and passed THX standards for application and performance. The speakers in this group meet the THX Select Certification Category (Suitable for rooms up to 2,000 cubic feet in size).
THX Certification Process
Cabinet Construction: All the speakers are constructed with Medium Density Fiberboard (MDF).
Cabinet Design and Finish: The speaker has sleek rounded-edge enclosures with a Black matte finish.
Impedance: All the speakers have a 4-ohm impedance. Make sure your amplifier or receiver is compatible with running 4-ohm speakers over a long period of time and at variable volume levels.
Connections: Each speaker has a set of 5‑way binding posts (3 sets for the M-OW3).
Wall-mounting: All speakers can be wall-mounted. A keyhole slot(s)  is incorporated into each speaker.
Let’s take a closer look at what each speaker offers in addition to the above features.
Monolith M-OW3
Monoprice Monolith MW-03 Front and Back
Monolith MW-03
With the width and overall look of a sound bar, the M-OW3 combines front left, center, and right channel speakers into a single LCR enclosure that can be wall-mounted. The LCR  design eliminates the need for separate left, center, and right channel speakers. This means saving space and less speaker clutter.
Tip: Although the M-OW3 looks like a soundbar, it can’t be connected directly to your TV as it doesn’t have any built-in amplification or HDMI, Digital Optical, or analog audio connections. You must connect the M-OW3 to an amplifier or home theater receiver via standard speaker connections in order to use it. Since the M-OW3 is an LCR speaker it has 3 sets of speaker connections.
Product Number: 41286
Woofers: 4.5-inch polypropylene drivers (3 Total)
Tweeters: 25mm silk dome with waveguide inset with each woofer (3 Total).
Passive Radiators: Six 4.5″ inch polypropylene cones. This helps extend low-frequency performance.
Recommended Amplifier Power: 50 ~ 150 watts
Sensitivity: 84.7dB
Frequency Response: 70Hz ~ 20kHz (+/- 3dB)
Crossover for Low Frequencies: 2.4kHz @12dB/octave
Crossover for High Frequencies: 2.4kHz @18dB/octave
Dimensions: 47.2″ x 7.0″ x 3.5″ (1200 x 178 x 90 mm)
Weight: 23.1 lbs. (10.5 kg)
The Monoprice Monolith M-OW3 Speaker is available for $499.99/each at Monoprice.com.
Monolith M-OW1
Monolith MW-01
Although best suited as a center channel speaker, the M-OW1 can also be used as a front left, right, or surround-channel speaker. It can be positioned horizontally or vertically for optimum placement.
Product Number: 41285
Woofer: One 4.5″ Driver with a polypropylene cone
Tweeter: One 20mm silk dome with waveguide and neodymium magnet.
Passive Radiators: (2) 4.5-inch polypropylene cone.
Recommended Amplifier Power: 30 ~ 100 watts
Sensitivity: 84.4 dB
Frequency Response: 70hz ~ 20kHz (+/- 3dB)
Dimensions: 7.0″ x 16.1″ x 3.5″ (178 x 409 x 90 mm)
Weight: 15.4 lbs. (7 kg)
The Monoprice Monolith M-OW1 Speaker is available for $499.99/pair at Monoprice.com or Amazon.com.
Monolith Compact Satellite Speakers
Monolith THX Satellites
Although the OW-1 speakers can be used as surround channel speakers, a better solution (especially for those that don’t have a lot of space), might be to use the new Monolith Compact Satellite speakers. In addition, depending on how you mount them the satellites can also be used for height channels.
Product Number: 41288
Woofer: One  4.5-inch polypropylene cone
Tweeter: 20mm silk dome with waveguide
Recommended Amplifier Power: 25 ~ 125 watts
Sensitivity: 81.03dB
Frequency Response: 80Hz ~ 20kHz (+/- 3dB)
Crossover for Low Frequencies: 1.7kHz @12dB/octave
Crossover for High Frequencies: 1.7kHz @18dB/octave
Dimensions: 6.0″ x 6.3″ x 5.9″ (153 x 160 x 150 mm)
Weight: 4.2 lbs. (1.9 kg)
The Monoprice Monolith Compact Satellite Speakers are available for $249.99/pair at Monoprice.com.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
The eCoustics editorial team grows to its largest point ever, adding coverage for new music releases and custom installation A/V solutions.
New products from Apple, Beats, JBL, Sony and Hisense are sure to be atop everyone's wishlist this Holiday season. Order now to beat the...
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
