Monoprice’s Monolith MTM-100 Powered Speakers Will Dominate Your Desktop
The $499 Monoprice Monolith MTM-100 Powered Loudspeakers might be ideal for both music listening and gaming on the desktop.
Monoprice Monolith MTM-100 Powered Desktop Speakers with MacBook
The desktop loudspeaker category took off during the pandemic as tens of millions of consumers went remote from their office jobs. Brands like Audioengine, Q Acoustics, PSB, and Edifier experienced a huge uptick in demand for their powered loudspeakers and it would appear the Monoprice is jumping in to the category with both feet — and a lot of drivers.
The Monoprice Monolith MTM-100 Powered Speakers are the latest addition to the growing lineup of Monolith models and could be ideal for gamers looking for that extra degree of punch on the desktop.
Core Features
These speakers consist of a matched pair consisting of a powered primary speaker and a passive secondary speaker. The primary speaker contains the amplifiers and connections for both speakers.
They can be used as part of a desktop audio system for your PC/Laptop or as a compact stereo system for your CD player or other compatible devices (including USB flash drives).
Tip: You can also connect a turntable but depending on the brand/model, you may have to connect a phono preamp between the turntable and the analog audio input of the MTM-100 speaker system.
In addition to physical connectivity, the system also incorporates wireless Bluetooth® with Qualcomm aptX HD Audio for high-quality, CD audio level music listening from compatible devices, such as smartphones.
Tip: The MTM-100 does not send audio signals to Bluetooth headsets or other Bluetooth speakers.
Monoprice Monolith MTM-100 Powered Desktop Speaker Headphone Input
A front panel 3.5mm headphone jack is provided on the primary speaker.
With their speaker/passive radiator complement, these speakers are designed to deliver more powerful sound than you would expect from their compact size. However, they are larger than your typical Desktop PC speakers.
Monoprice Monolith MTM-100 Powered Desktop Speakers Rear Inputs and Outputs
In addition, if you want a bigger bass boost, you can add a subwoofer to the system via its dedicated subwoofer output.
Control
A wireless remote control is provided. The primary speaker also provides a multi-function front panel volume/source select control.
Monoprice Monolith MTM-100 Remote Control
Specifications
  • Product Number: 43241
  • Amplifier Type: Class D
  • Amplifier Output Power: 2 x 50 watts (100 watts total)
  • Woofer (each speaker): 2 x 4-inch cone
  • Tweeter (each speaker): 1 x 1.25-inch silk dome
  • Passive Radiators (each speaker): 2 x 5.25-inch
  • Frequency Response: 50Hz ~ 20kHz
  • Wired Inputs: Stereo analog RCA, digital optical S/PDIF, USB
  • Wired Outputs: Mono analog subwoofer, stereo 3.5mm headphones, speaker connections between the primary and secondary speaker.
  • Bluetooth®: Version 5.0
  • Bluetooth Audio Codecs: SBC, Qualcomm aptX HD
  • Input Power: 100 ~ 240 VAC, 50/60 Hz, 150 watts
  • Dimensions (WHD – each speaker): 6.3 x 14.0 x 7.9-inches (160 x 355 x 200 mm)
What’s in the Box
  • Primary Speaker
  • Secondary Speaker
  • Remote Control with batteries.
  • Speaker Interconnect Cable
  • RCA Analog Stereo cable
  • Foot Mat
  • AC Power Cable
  • User Guide
Availability and Pricing
The Monoprice Monolith MTM-100 Powered Desktop Speakers are available for $499 at Monoprice.com.
More From Monoprice
Monoprice’s Monolith Encore 5 Series Loudspeakers Promise A Lot Of Performance For Less Money
Monoprice Monolith Encore 6 Series Home Theater Speakers Are Very Affordable
Monoprice Soundstage3 Portable Bluetooth Speaker: Review
Monoprice Unveils Monolith M518HT THX 5.1 Channel Speaker System
Monoprice Announces Monolith THX LCR & Satellite Speakers
Preview: Monoprice Monolith Dual Driver THX Ultra M-210 And M-212 Subwoofers
Monoprice Monolith THX Subwoofers Shake The Foundation
Monoprice Shakes Things Up With Two New Massive THX Subwoofers [Updated]
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
With both Bluetooth and wired connectivity, Onkyo's Creator Series GX10DB and GX30ARC Powered Speaker Monitors are a versatile and affordable compact audio solution.
At $279.99, the Creative Pebble Nova desktop speakers feature coaxial drivers with both wireless and wired connectivity.
With updated styling and connectivity, the $349 Andover SpinBase 2 is a compact wireless speaker designed to sit under any turntable.
At $249, the Amazon Fire TV Soundbar Plus features 3.1 channels, but is expandable to 5.1 with optional wireless subwoofer and speakers.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
At $1,999, the Technics HA-507 is a pure analog headphone amplifier and preamplifier with a balanced/dual mono configuration.
