Monoprice Unveils Monolith M518HT THX 5.1 Channel Speaker System
Monoprice continues to expand its THX Certified speaker line-up with an affordable M518HT 5.1 channel speaker system.
Monoprice Monolith THX-M518HT 5.1 Home Theater Speaker System
Soundbars provide a simple, no-hassle solution to improve TV sound, but there is another straightforward option that can provide a full surround sound experience without spending a lot of money. That option is a pre-packaged 5.1 channel surround sound speaker system, in combination with an affordable home theater receiver.
Monoprice is offering one-half of this solution with the Monolith M518HT THX Certified 5.1 Home Theater System.
THX Certification
THX Certification Process
THX Certified Performance Classes
The M518HT is THX Certified. This speaker system has been submitted and passed THX standards for application and performance for the Compact Certified Performance Class. This means that the speaker system is optimized for rooms up to 1,000 cubic feet in size and an approximate 8-foot distance from the viewing/listening position and the screen/speaker system setup.
The M518HT Package
Monoprice Monolith M518HT 5.1 THX Home Theater Speaker System
The M518HT comes with 5 satellite speakers and a subwoofer. However, unlike most all-in-one speaker packages, the M518HT doesn’t have a separately designed center channel speaker. Instead, you can use one of the five satellite speakers that are included. The remaining four satellite speakers are for the left front, right front, left surround, and right surround channels.
Tip: The satellite speakers can be shelf or wall-mounted. Each speaker has a keyhole mount for single screw mounting.
Center/Satellite Speaker Features/Specs
Monoprice Monolith THX-M518HT Satellite Speaker front and rear
Subwoofer Features/Specs
Monoprice Monolith THX-M518HT Subwoofer front and rear
  • Design: Down firing driver with port (bass reflex)
  • Driver Size: 8-inches
  • Driver Material:  2 layer long fiber pulp/glass fiber cone
  • Voice Coil: 30mm high‑temperature aluminum wire and aluminum bobbin.
  • Magnet: Ceramic Y30
  • Enclosure: Vented (ported) MDF cabinet with horizontal and vertical bracing
  • Amplifier: Claridy 150‑watt (RMS) Amplifier with DSP control.
  • Frequency Response
    • EQ1 Setting (24 to 200 Hz)
    • EQ2 Setting (30 to 200 Hz)
    • THX® Setting: (35 to 200 Hz)
  • Variable Level Control: +15/‑20 dB
  • Crossover Control: Variable from 40 to 160 Hz.
  • Phase Control: Variable from 0 to 180 degrees. This is used to match the in/out motion of the subwoofer driver to the rest of the speakers in the system.
  • Input Connectors: RCA-style stereo pair
  • Output Connectors: RCA-style stereo pair (direct passthrough)
  • Signal Turn On: Always On or Auto-Detect. selectable
  • Auto Turn Off Time: 30 minutes (no low-frequency audio signal is detected)
  • Dimensions (HxWxD): Not provided as of the article publication date.
  • Weight: 19.8 lbs. (9.0 kg)
Monoprice Monolith THX-M518HT Subwoofer Bottom
Availability and Pricing
The Monoprice Monolith M518HT THX 5.1 channel speaker system (product number: 41287) is available with a black finish for $799.99 at Monoprice.com
How To Complete Your System
At the beginning of the article, we mentioned that in order to use this speaker system, you need a home theater receiver to go along with it. If you already have a home theater receiver, the M518HT is a great complement. If you are starting from scratch, you will need to purchase one.
Unfortunately, Monoprice doesn’t offer a modest-priced home theater receiver to go along with this system (at least not as of the publish date of this article), but there are several brands that offer 5.1/5/2 channel models that would be a good fit with the M518HT speaker system:
More about Monoprice
Monoprice Monolith Encore Home Theater Speakers Are Very Affordable
Monoprice Announces Monolith In-Wall Subwoofers
Monoprice Announces Monolith THX LCR & Satellite Speakers
Monoprice Monolith Dual Driver THX Ultra M-210 And M-212 Subwoofers
Monoprice Monolith THX Subwoofers Shake The Foundation
Monoprice Shakes Things Up With Two New Massive THX Subwoofers
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
SVS will showcase their flagship Ultra Evolution home theater speaker system for T.H.E. Film Festival movie screenings.
The best speakers from Arendal Sound have arrived, but their new flagship towers will set you back $9,500/pair USD.
Does Sony's advanced new wireless home theater system earn its lofty price tag?
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
A/V Furniture & Accessories
Do expensive video cables really make a difference? The $45 THX HDMI Interconnects prove you don't have to spend a fortune to achieve all...
Cyber Monday 2024 deals you won't want to miss out on from SVS, RSL, THX, Technics, Creative, Denon, Samsung and more.
For less than the cost of dinner and a movie out with the family, you can bring home this eight channel home theater speaker...
Arendal's flagship loudspeaker series are THX Ultra Certified for large home theater speaker system configurations.
