Preview: Monoprice Monolith Dual Driver THX Ultra M-210 and M-212 Subwoofers
Does your movie watching experience suffer from a lack of low end impact? The Monoprice Monolith Dual Driver Subwoofers might change all that.
Monoprice Monolith M-210 and M-212 THX Subwoofers
Following its five recently released THX Certified Subwoofers, Monoprice has announced the addition of two more models, the M-210 and M-212. What makes these subwoofers different is that instead of one driver, each sub packs in two drivers. This provides home theater fans with powerful bass without taking up a lot of floor space as the two drivers are stacked within the enclosure.
The new Monoprice Monolith dual driver subwoofers are offered in 10-inch and 12-inch sizes. Let’s take a look at what they offer (in addition to the dual drivers).
What Both Subwoofers Have in Common
THX Ultra Certification: This means that these subwoofers have been submitted and passed THX standards for application and performance.  The M-210 and M212 have both been certified THX Ultra which means they are optimized for use in rooms of up to 3,000 cubic feet in volume.
THX Certification Process
Lots of Power Output: 1,000-watt (RMS)/1,800-watt (Peak) using a Claridy DSP1000 Class D amplifier with DSP (Digital Signal Processing)
Driver Design: Each subwoofer has two recently developed high-excursion drivers capable of handling the above-mentioned power output without distortion.
Flexible Port Design: The port on each subwoofer can be used in an open or sealed setup.
Monolith M-210 Dual Driver THX Subwoofer
Monoprice Monolith M-210 THX Subwoofer Front Back
Product Number: 38545
Driver Number and Size: 2 x 10-inches.
Driver Material:  2 layer long fiber pulp/glass fiber cone x 2
Voice Coil: 60mm, with high-temperature aluminum wire and black anodized aluminum bobbin construction.
Magnet: 144 oz ( 2 x 72 oz)
Enclosure: High-Density Fiberboard (HDF) that is horizontally and vertically braced. 1 slot-style front-mounted port is provided that can be used open or sealed.
Frequency Response (-6db) with Extended EQ Operation
  • Sealed Port: Not Recommended
  • Vented Port: 16-200 Hz
Frequency Response (-6db) with THX EQ Operation
  • Sealed Port: 20 – 200 Hz
  • Vented Port: Not Recommended
Harmonic Distortion: Less than 3% from 20-100 Hz (90dB @ 1m reference point)
Variable Level Control: +15/‑20 dB
Crossover Control: Inline/Bypass variable from 40 to 160 Hz.
Phase Control: 0 to 180 degrees variable (used to match the in/out motion of the subwoofer driver to the rest of the speakers in your system).
Inputs: 2 RCA, 1 XLR
Outputs: 1 XLR
Signal Turn On: Selectable always on or Auto-Detect.
Auto Turn Off Time: 30 minutes
Dimensions: 23.6″ x 17.7″ x 36.4″ (600 x 450 x 925 mm)
Weight:  162.0 lbs. (66.5 kg)
Finish: Black Ash
Monolith M-212 Dual Driver THX Subwoofer
Monoprice Monolith M-212 THX Subwoofer
Product Number: 38544
Driver Number and Size: 2  x 12-inches
Driver Material:  2-layer long fiber pulp/glass fiber cone x 2
Voice Coil: 60mm x 2, with high-temperature aluminum wire and black anodized aluminum bobbin construction.
Magnet: 144 oz total (2 x 72 oz)
Enclosure: The enclosure is made of High-Density Fiberboard (HDF) that is horizontally and vertically braced. The port that is provided can be used open or sealed.
  • Sealed Ports: Not Recommended
  • Vented Ports: 16-200Hz
  • Sealed Ports: 20-200Hz
  • Vented Ports: Not Recommended
Outputs: 1 XLR
Dimensions: 36.4″ x 17.7″ x 23.6″ (925 x 450 x 600 mm)
Weight:  174.2 lbs. (79.0 kg)
Finish: Black Ash
Monoprice Monolith M-210 THX Subwoofer Exploded
Price & Availability
The M-210 Dual 10-inch Driver Monoprice Monolith THX Ultra Certified Subwoofer (Product Number 38545) is available for $1,299.99 at Monoprice.com.
The M-212 Dual 12-inch Driver Monoprice Monolith THX Ultra Certified Subwoofer (Product Number 38544) is available for $1,799.99 at Monoprice.com
Also, check out our other recent Monoprice Monolith Subwoofer and Speaker Reports:
Monoprice Shakes Things Up With Two New Massive THX Subwoofers
Monoprice Monolith THX Subwoofers Shake The Foundation
Affordable Subwoofer Shootout
Monoprice Monolith Encore Home Theater Speakers Are Very Affordable
Bonus: Subwoofer Setup Tips and Tricks
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
For less than the cost of dinner and a movie out with the family, you can bring home this eight channel home theater speaker...
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
At $699, the Acoustic Energy AE Sub is 12-inch subwoofer packing 250-watts of power with low bass extension down to 26Hz.
