Monoprice Announces Monolith In-Wall Subwoofers
Monoprice adds to its growing Monolith Subwoofer lineup with two in-wall models. Find out what this means for you.
Monoprice Monolith M-IWSUB8 and M-IWSUB82 In-Wall Subwoofers
Monoprice has been very active in the speaker and subwoofer category in the past several months with a number of new product introductions under their Mononlith brand (see links at the end of this article).
It also looks like they aren’t stopping as they have announced the M-IWSUB8 and M-IWSUB82 Subwoofers.
What makes these subwoofers different is that they are designed for in-wall installation. Although it takes a little more work to make sure you place them in the right spot before you cut into your walls, they eliminate the need to find floor space for traditional subwoofer boxes.
However, it’s also important to note that, unlike most subwoofers, these subwoofers are passive. This means you have to place an external subwoofer amplifier between the subwoofer output of a home theater receiver and the input connections on the subwoofer as they don’t have their own built-in amps – more on this at the end of the article.
If you think that an in-wall subwoofer might be the right solution for your setup, let’s check out the features and specs of these latest entries from Monolith.
Monolith M-IWSUB8
Monoprice Monolith M-IWSUB8 In-Wall Subwoofer
M-IWSUB8
Product Number: 42831
Driver Number and Size: 1 X 8-inches
Driver Material: Polypropylene cone with rubber surround.
Grill: Removable magnetic and paintable to your color preference (Grill comes in White).
Frequency Response: 36 – 200Hz ±3dB
Sensitiivty: 91dB
Monoprice Monolith M-IWSUB8 Flat
M-IWSUB8
Crossover Type: Acoustic filter
Crossover Frequency: 120Hz @ 12dB/oct
Impedance: 4 ohms
Input Connectors: Spring‑loaded binding posts.
Dimensions:  11.9 x 13.3-inches (With Grill), 10.8 x 12.2-inches (Without Grill)
Easy Install: Heavy‑duty mounting tabs are provided for easy installation. The subwoofer frame is designed to fit within standard 16″ wood stud walls.
Monolith M-IWSUB82 Dual 8-inch In-Wall Subwoofer
Monoprice Monolith M-IWSUB82 In-Wall Subwoofer Front and Rear
M-IWSUB82
Product Number: 42832
Driver Number and Size: 2 x 8-inches
Sensitiivty: 91dB
Monoprice Monolith M-IWSUB82 In-Wall Subwoofer Profile
M-IWSUB82
Impedance: 4 ohms
Dimensions: 11.7 x 21.3 inches (With Grille), 10.8 x 20.4 inches (Without Grille)
Subwoofer Amplifier
Monoprice Monolith SWA-400 Subwoofer
As mentioned at the top of the article, to use these subwoofers, you need to connect an external subwoofer amplifier. You can use almost any available subwoofer amp that is compatible with 4 ohm impedance speaker loads, but Monoprice also offers its own; the SWA-400 (400 watts output with DSP and presets to optimize performance with 8, 10, or 12-inch in-wall subs) which is priced at $308.99 on Monoprice.com.
Monoprice Monolith SWA-400 Subwoofer Amplifier Front and Rear
Tip: If you are using more than one in-wall subwoofer, you will need a separate amp for each one.
Price & Availability
The M-IWSUB8 (Product Number: 42831) – $399.99 at Monoprice.com.
The M-IWSUB82 (Product Number: 42832) – $599.99 at Monoprice.com
Tip: If you don’t have experience installing in-wall speakers, you should consult a home theater installer.
Monoprice Monolith M-IWSUB8 Crossover
M-IWSUB8 Crossover
monolith-1wsub82-crossover
M-IWSUB82 Crossover
Also, check out our other recent Monoprice Monolith Subwoofer and Speaker Reports:
Monoprice Monolith Dual Driver THX Ultra M-210 and M-212 Subwoofers
Monoprice Shakes Things Up With Two New Massive THX Subwoofers
Monoprice Monolith THX Subwoofers Shake The Foundation
Monoprice Announces Monolith THX LCR & Satellite Speakers
Monoprice Monolith Encore Home Theater Speakers Are Very Affordable
Bonus: Subwoofer Setup Tips and Tricks
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
