In-Wall Speakers
Monoprice Introduces Monolith THX In-Wall Speakers
Monoprice expands its in-wall speaker line with two Monolith THX Certified loudspeakers that are easy to install and complement monoprice’s previously released in-wall subwoofers.
Monoprice Monolith In-Wal THX Speakers
Monoprice has been very active in the speaker and subwoofer categories over the past year with a number of new product introductions under their Mononlith brand (see links at the end of this article). Their latest entries are the THX Certified THX-275IW and THX-465IW in-wall speakers.
Tip: These speakers should be a great complement to Monoprice’s recently announced M-IWSUB8 and M-IWSUB82 In-Wall Subwoofers.
Features Shared by Both Speakers
THX Certification Process
  • THX Certification: This speaker line has been submitted and passed THX standards for application and performance. The THX-275IW is THX Select Certified (Suitable for rooms up to 2,000 cubic feet in size) while the THX-465IW  is THX Ultra Certified (Suitable for rooms up to 3,000 cubic feet in size).
  • Impedance: Both speakers have a 4-ohm impedance. Make sure your amplifier or receiver can double its power output into 4 ohms.
  • Connections: Each speaker has a set of spring‑loaded binding posts.
  • Easy Install: The heavy‑duty dog-ear mounting system makes for a fast and problem-free installation. The magnetically detachable grille is powder coated in white and can be painted to match any decor
Tip: Monolith™ THX® Certified in‑wall and in‑room speakers use the same driver and crossover components. This means you can mix and match Monolith THX-certified speakers to suit any room. Using Monolith THX in‑wall and in-room speakers for the left, center, right, and, rear channels in a home theater will still be timbre matched.
Monolith THX-275IW
Monoprice Monolith In-Wal THX-275IW Speakers
  • Product Number: 42830
  • Tweeter: 1x 25mm silk dome with neodymium magnet
  • Mid-range: 1x 50mm silk dome
  • Woofer:  1 x 6.5″ long fiber pulp cones with NBR surrounds
  • Grill Color: White
  • Frequency Response: 43Hz to 20kHz ±3dB
  • Sensitivity: 87.6dB (2.83V/1m)
  • Low-Frequency Crossover: 550Hz @6dB/oct
  • Midrange Crossover: 550Hz to 3.1kHz @12dB/oct
  • High-Frequency Crossover: 3.1kHz @12dB/oct
  • Amplifier Power Range: 50 to 300 watts
  • Dimensions (HxWxD): 16.5″ x 11.1″ x 3.7″ (419 x 281 x 94 mm)
  • Weight: 11 lbs. (5.0 kg)
Monolith THX-465IW
Monoprice Monolith In-Wal THX-465IW Speakers
  • Product Number: 42829
  • Woofer:  4x 6.5″ long fiber pulp cones with NBR surrounds
  • Frequency Response: 37Hz to 20kHz ±3dB
  • Sensitivity: 88.0dB (2.83V/1m)
  • Low-Frequency Crossover: 750Hz @6dB/oct
  • Midrange Crossover: 750Hz to 3.4kHz @12dB/oct
  • High-Frequency Crossover: 3.4kHz @18dB/oct
  • Amplifier Power Range: 50 to 450 watts
  • Dimensions:  Dimensions (HxWxD) 36.3″ x 11.1″ x 3.7″ (921 x 281 x 94 mm)
  • Weight: 26.9 lbs. (12.2 kg)
Price & Availability
Tip: If you don’t have experience installing in-wall speakers, you should consult a home theater installer.
Tip: If you need an amplifier(s) to go with your speakers, check out:
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
For less than the cost of dinner and a movie out with the family, you can bring home this eight channel home theater speaker...
Arendal's flagship loudspeaker series are THX Ultra Certified for large home theater speaker system configurations.
In-Wall Speakers
Enjoy low bass performance down to 30Hz from subwoofers hidden in your wall that are only 4-inches deep.
In-Wall Speakers
Ambisonic leverages expertise in outdoor speakers for new line of in-wall speakers using planar ribbon technology for home theater.
