Monoprice Monolith Encore Home Theater Speakers Are Very Affordable
Monoprice adds to its Monolith speaker line with the Encore Series T6 Tower, B6 Bookshelf, and C6 Center speaker. Find out what they have to offer for your home theater setup.
Monoprice Monolith Encore Speakers
Following up on the recent release of five new Monolith THX subwoofers (from 10-inches to 16-inches), Monoprice has announced its Monolith Encore speaker series featuring the high performance, but reasonably priced T6 Tower, B6 Bookshelf, and C6 Center Channel speakers.
The speakers are sold individually which allows for flexible setup configurations.
  • You can use the T6 towers speakers as your front speakers in combination with the B6 bookshelf as surrounds and the C6 center channel.
  • You can use the T6 towers for both front and surround speakers combined with the C6 center channel.
  • You can use the B6 bookshelves as both your front and surround speakers combined with a C6 center channel.
  • To round things out for a home theater setup, you can add one or subwoofers, such as the Monolith THX Certified subs mentioned at the top of this article.
  • You can assemble a 2-channel stereo set up with just a pair of T6’s or B6’s.
What All 3 Speakers Have in Common
Impedance: 4 ohms
Cabinet Design: Ported Rectangular MDF (Medium Density Fiberboard) cabinets with internal bracing.
Finish: Back Vinyl Veneer
Monolith Encore T6 Tower Speaker
Monoprice Monolith Encore T6 Tower Speakers
Monolith Encore T6
Product Number: 43149
Main Woofers: Two 6.5″ Long Fiber Pulp Cone
Mid Woofer: One 6.5″ Long Fiber Pulp Cone
Tweeter: One 25mm Silk Dome with Waveguide
Monoprice Monolith Encore T6 Tower Speaker Cutaway
Sensitivity: 87.8dB
Frequency Response: 37Hz ~ 20kHz
Crossover for Low Frequencies: 180Hz @6dB/octave
Crossover for Midrange Frequencies: 1.35kHz @12dB/octave
Crossover for High Frequencies: 1.35kHz @18dB/octave
Connections: 2 sets of 5-way binding posts that allow for bi-wire/bi-amp configuration.
Dimensions: 40.0″ x 7.9″ x 13.8″ (1016 x 201 x 351 mm)
Weight: 49.2 lbs. (22.3 kg)
Price & Availability
The Monoprice Monolith Encore T6 Floorstanding Speaker is available for $399.99 (each) at Monoprice.com.
Monolith Encore B6 Bookshelf Speaker
Monoprice Monolith Encore B6 Speakers
Monolith Encore B6
Product Number: 43150
Monoprice Monolith Encore B6 Bookshelf Speaker Cutaway
Sensitivity: 85.0dB
Frequency Response: 49Hz ~ 20kHz
Crossover for Low Frequencies: Low: 1.2kHz @12dB/octave
Crossover for High Frequencies: High: 1.2kHz @18dB/octave
Connections: One set of 5‑way binding posts
Dimensions: 15.7″ x 7.9″ x 9.9″ (400 x 201 x 251 mm)
Weight: 15.4 lbs. (7.0 kg)
The Monoprice Monolith Encore B6 Bookshelf Speaker is available for $179.99 (each) at Monoprice.com.
Monolith Encore C6 Center Channel Speaker
Monoprice Monolith Encore C6 Speakers
Monolith Encore C6
Product Number: 43151
Woofers: Two 6.5″ Long Fiber Pulp Cones
Monoprice Monolith Encore C6 Center Speaker Cutaway
Sensitivity: 87.7dB
Frequency Response: 56Hz ~ 20kHz
Crossover for Low Frequencies: Low: 1.5kHz @12dB/octave
Crossover for High Frequencies: High: 1.5kHz @18dB/octave
Dimensions: 9.9″ x 22.2″ x 7.9″ (251 x 564 x 201 mm)
Weight: 22.0 lbs. (10.0 kg)
The Monoprice Monolith Encore C6 Center Channel Speaker is available for $249.99 (each) at Monoprice.com.
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
SVS will showcase their flagship Ultra Evolution home theater speaker system for T.H.E. Film Festival movie screenings.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
The best speakers from Arendal Sound have arrived, but their new flagship towers will set you back $9,500/pair USD.
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
Does Sony's advanced new wireless home theater system earn its lofty price tag?
The eCoustics editorial team grows to its largest point ever, adding coverage for new music releases and custom installation A/V solutions.
