Monoprice’s Monolith Encore 5 Series Loudspeakers Promise A lot of Performance For Less Money
Monoprice adds to its Monolith Encore speaker line with the Encore 5-Series which includes the T5 Tower, B5 Bookshelf, and C5 Center Channel Speaker.
Monoprice Monolith Encore Series 5 Speaker System
Following up on their previous release of the very affordable Monolith Encore 6-series home theater speaker line, Monoprice has decided to expand the Encore line by adding an Encore 5 Series that is priced lower than the current models without sacrificing quality.
The 5 series includes the T5 Tower, B5 Bookshelf, and C5 Center Channel speakers.
The speakers are sold individually which allows for flexible setup configurations.
  • Just as with the Encore 6 series, you can use the T5 tower speakers as your front speakers in combination with the B5 bookshelf as surrounds and the C5 center channel.
  • You can use the T5 towers for both front and surround speakers combined with the C5 center channel.
  • You can use the B5 bookshelves as both your front and surround speakers combined with a C5 center channel.
  • You can assemble a 2-channel stereo setup with just a pair of T5s or B5s.
What All Three Speakers Have in Common
Cabinet Design: Rectangular MDF (Medium Density Fiberboard) cabinets with internal bracing.
Impedance: 4 ohms
Tweeter Waveguide:  Each speaker has a 20mm silk dome tweeter that sits inside a large waveguide for better dispersion, a wider sweet spot for stereo listening, and more precise imaging.
Finish: Black PVC
Monolith Encore T5 Tower Speaker
Monoprice Monolith Encore T5 Tower Speakers Front Back
Product Number: 43152
Main Woofers: Two 5.25″ Long Fiber Pulp Cone, Additional support provided by a rear-mounted port
Mid Woofer: One 5.25″ Long Fiber Pulp Cone
Tweeter: One 20mm Silk Dome with Waveguide and Neodymium Magnet
Monoprice Monolith Encore T5 Tower Speaker Parts Exploded
Sensitivity: 87.5dB
Frequency Response: 43Hz ~ 20kHz
Crossover for Low Frequencies: 240Hz @6dB/octave
Crossover for Midrange Frequencies: 2.2kHz @12dB/octave
Crossover for High Frequencies: 2.2kHz @18dB/octave
Connections: 2 sets of 5-way binding posts that allow for bi-wire/bi-amp configuration.
Dimensions (LxWxH): 9.8″ x 6.3″ x 35.4″ (251 x 161 x 900 mm)
Weight: 34.8 lbs. (15.8 kg)
The Monoprice Monolith Encore T5 Floorstanding Speaker is available for $329.99 (each) at Monoprice.com.
Monolith Encore B5 Bookshelf Speaker
Monoprice Monolith Encore B5 Bookshelf Speakers Front Back
Product Number: 43153
Monoprice Monolith Encore B5 Bookshelf Speaker Parts Exploded
Sensitivity: 83.9dB
Frequency Response: 60Hz ~ 20kHz
Crossover for Low Frequencies: Low: 2.4kHz @12dB/octave
Crossover for High Frequencies: High: 2.4kHz @18dB/octave
Connections: One set of 5‑way binding posts
Dimensions (LxWxH): 7.1″ x 6.3″ x 13.5″ (181 x 161 x 344 mm)
Weight: 10.6 lbs. (4.8 kg)
The Monoprice Monolith Encore B5 Bookshelf Speaker is available for $149.99 (each) at Monoprice.com.
Monolith Encore C5 Center Channel Speaker
Monoprice Monolith Encore C5 Center Speaker Front Back
Product Number: 43154
Woofers: Two 5.25″ Long Fiber Pulp Cones
Monoprice Monolith Encore C5 Center Speaker Parts Exploded
Sensitivity: 87.7dB
Frequency Response: 56Hz ~ 20kHz
Crossover for Low Frequencies: Low: 1.5kHz @12dB/octave
Crossover for High Frequencies: High: 1.5kHz @18dB/octave
Dimensions: 7.1″ x 18.7″ x 6.3″ (181 x 476 x 161 mm)
Weight: 15.4 lbs. (7.0 kg)
The Monoprice Monolith Encore C5 Center Channel Speaker is available for $199.99 (each) at Monoprice.com.
Encore Series 6
For reference, we previously reported on the step-up Monoprice Monolith Encore Series 6 speakers.
Comparison
Encore Series 5Encore Series 6
Tower (each)T5 $329.99T6 $399.99
Bookshelf (each)B5 $149.99B6 $179.99
Center (each)C5 $199.99C6 $249.99
More Monoprice News
Monoprice Unveils Monolith M518HT THX 5.1 Channel Speaker System
Monoprice Announces Monolith THX LCR & Satellite Speakers
Monoprice Introduces Monolith THX In-Wall Speakers
Preview: Monoprice Monolith Dual Driver THX Ultra M-210 And M-212 Subwoofers
Monoprice Monolith THX Subwoofers Shake The Foundation
Monoprice Shakes Things Up With Two New Massive THX Subwoofers [Updated]
Monoprice Announces Monolith In-Wall Subwoofers
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Close To Perfect, Expanded Atmos Mix Takes Yes Surround Sound To Immersive Heights.
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
The Atelier program gives Bang & Olufsen's customers the chance to style their own speakers. The Beosound 2 Gradient Collection gets things started.
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
