Monoprice’s Monolith Audition Speakers Are Very Affordable
Good loudspeakers don’t have to be unaffordable. The Monoprice Monolith Audition Series Loudspeakers will not break the bank.
One of my favorite 1950’s “B” sci-fi films is Monolith Monsters. The gist of the story is that a meteor crashes to earth and its fragments start growing when exposed to water – as the fragments grow, they become skyscraper-size Monoliths. As a result, they topple and shatter, causing a multiplying effect where new Monoliths grow that could cover the world.
So what does a 1950’s movie have to do with this article? In an analogous fashion, Monoprice has its own Monolith strategy…to dominate the A/V space.
The Monoprice/Monolith Brand
Monoprice landed in the AV space several years ago and emerged as a popular maker of low-priced, but high-quality HDMI cables. Since then it has expanded exponentially by branching out into many other product categories. With its Monolith brand, it is making a big impact on audio and home theater fans. From turntables, amplifiers, speakers, subwoofers, and speaker systems, consumers, press, and competitors have taken notice.
With that in mind, Monoprice is following up on the previous release of their already affordable Monolith Encore 6 and 5-series home theater speaker lines, with a new Audition speaker line that is designed to provide good sound quality at even more affordable price points.
Monoprice Monolith Audition Speakers
The Audition series includes T5 and T4 Tower, B5 and B4 Bookshelf, and C5 and C4 Center Channel speakers (six speakers total).
The speakers are sold individually which allows for flexible setup configurations.
  • Just as with the Encore series, you can use the Audition T5 or T4 tower speakers as front speakers in combination with the audition B5 or B4 bookshelfs as surrounds and the center channel.
  • You can use the audition towers for both front and surround speakers combined with the audition center channel speakers.
  • You can use the audition bookshelfs as both your front and surround speakers combined with the audition center channel speaker.
  • For a complete home theater setup, you can add one or more subwoofers, such as the Monoprice Monolith M-10 V2, which we previously featured in a Preview and  Affordable Subwoofer Shootout articles.
  • You can assemble a 2-channel stereo setup with just a pair of Audition T5/T4 towers or B5/B4 bookshelfs.
What All Six Audition Series Speakers Have in Common
Cabinet Design: Rectangular MDF (Medium Density Fiberboard) cabinets with internal bracing.
Bass Reflex: All the speakers include rear-mounted ports (aka vents) for an extended low-frequency response.
Impedance: 4 ohms
Tweeter Waveguide: Each speaker has a 20mm silk or cloth dome tweeter with a neodymium magnet that sits inside a large waveguide for better dispersion, a wider sweet spot for stereo listening, and more precise imaging.
Monoprice Monolith Audition Tweeter
Midrange and Woofer Driver Material: Polypropylene cones with NBR surrounds.
Connections: 5-Way Binding Posts (The T5 and T4 include two sets to support Bi-amping/Bi-Wiring).
Monoprice Monolith Audition Binding Posts
Finish: Black PVC
Monolith Audition T5/T4 Tower Speakers
Monoprice Monolith Audition T5 Tower Speaker Front and Back
Specifications Audition T5Audition T4
Product Number4315543158
Speaker Type3-Way3-Way
Main WoofersTwo 5.25-inch Two 4-inch
Mid-WooferOne 5.25-inchOne 4-inch
TweeterOne 20mm Silk Dome One 20mm Cloth Dome
Sensitivity86.9dB 85.5dB
Frequency Response48Hz ~ 20kHz56Hz ~ 20kHz
Low-Frequency Crossover (6dB/Octave)220Hz250Hz
Mid-Frequency Crossover (12dB/Octave)2.4kHz2.5kHz
High-Frequency Crossover (18dB/Octave)2.4kHz2.5kHz
Dimensions (LWH)9.8 x 6.5 x 35.4-inches (250 x 165 x 900 mm)7.0 x 5.5 x 31.5-inches (180 x 140 x 800 mm)
Weight23.4 lbs. (10.6 kg)17.86 lbs. (8.1 kg)
Price at Monoprice.com$249.99 $199.99
Monolith Audition B5/B4 Bookshelf Speakers
Monoprice Monolith Audition B5 Bookshelf Speaker Front and Back
SpecificationsAudition B5Audition B4
Product Number4315643159
Speaker Type2-Way2-Way
WooferOne 5.25-inch One 4-inch
TweeterOne 20mm Silk DomeOne 20mm Cloth Dome
Sensitivity84.3dB83.7dB
Frequency Response61Hz ~ 20kHz57Hz ~ 20kHz
Low-Frequency Crossover (6dB/Octave)3.4kHz4.4kHz
High-Frequency Crossover (12dB/Octave)3.4kHz4.4kHz
Dimensions (LWH)7.1 x 6.3 x 13.6-nches (180 x 160 x 345 mm)5.5 x 5.5 x 11.0-inches (140 x 140 x 280 mm)
Weight7.3 lbs. (3.3 kg)5.5 lbs. (2.5 kg)
Price at Monoprice.com$124.99$99.99
Monolith Audition C5/C4 Center Channel Speakers
Monoprice Monolith Audition C5 Center Speaker Front and Back
SpecificationsAudition C5Audition C4
Product Number4315743160
Speaker TypeTwo-Way Two – Way
WooferTwo 5.25-inch Two 4-inch
TweeterOne 20mm silk domeOne 20mm cloth dome
Sensitivity86.7dB85.4dB
Frequency Response73Hz ~ 20kHz81Hz ~ 20kHz
Low-Frequency Crossover (6dB/Octave)2.4Hz2.5kHz
High-Frequency Crossover (12dB/Octave)2.4Hz2.5kHz
Dimensions (LWH)7.1  x 18.7 x 6.3-inches (180 x 476 x 160 mm)5.5 x 14.96 x 5.5-inches (140 x 380 x 140 mm)
Weight10.8 lbs. (4.9 kg)8.2 lbs. (3.7 kg)
Price at Monoprice.com$159.99$129.99
Monoprice Monolith Audition C5 Center Speaker Parts Exploded
Monoprice Monolith Audition B5 Bookshelf Speaker Parts Exploded
Monoprice Monolith Audition T5 Tower Speaker Parts Exploded
More From Monoprice
Monoprice’s Monolith Encore 5 Series Loudspeakers Promise A Lot Of Performance For Less Money
Monoprice Monolith Encore Home Theater Speakers Are Very Affordable
Monoprice Unveils Monolith M518HT THX 5.1 Channel Speaker System
Monoprice’s Monolith MTM-100 Powered Speakers Will Dominate Your Desktop
Monoprice Soundstage3 Portable Bluetooth Speaker: Review
Monoprice Announces Monolith THX LCR & Satellite Speakers
Preview: Monoprice Monolith Dual Driver THX Ultra M-210 And M-212 Subwoofers
Monoprice Monolith THX Subwoofers Shake The Foundation
Monoprice Shakes Things Up With Two New Massive THX Subwoofers [Updated]
Monoprice Introduces Monolith THX In-Wall Speakers
Monoprice Announces Monolith In-Wall Subwoofers
Monoprice Monolith Class D Power Amplifiers Unveiled
Monoprice Monolith Turntables Are Super Affordable
Monoprice Monolith Turntable: Review
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
The Atelier program gives Bang & Olufsen's customers the chance to style their own speakers. The Beosound 2 Gradient Collection gets things started.
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
At $279.99, the Creative Pebble Nova desktop speakers feature coaxial drivers with both wireless and wired connectivity.
