Monoprice Unveils 3 Affordable Monolith Class A/B Power Amplifiers For Your Home Theater
Monoprice’s latest Monolith Series power amplifiers offer an affordable path for those looking to improve the sound quality of their home theater system.
Monoprice Monolith M5100X Amplifier Front
Monoprice has started to build a real following in the home theater category with its range of loudspeakers, subwoofers, and power amplifiers. The Monoprice Monolith Series has continued to grow over the past two years and keeping their products affordable has certainly helped.
In 2022, they added two high-end 8-channel Class D power amplifiers, the 8125X and 8250X which are ideal for Dolby Atmos and DTS:X home theater systems.
For 2023, Monoprice is offering up three moderately priced Monolith power amplifiers, the M2100X (2 channels), M3100X (three channels), and M3100X (5 channels). These provide more options for different setup configurations.
Monoprice Monolith M5100X Amplifier Rear
Monoprice Monolith M5100X (5 channel)
Monoprice Monolith M3100X Amplifier Rear
Monoprice Monolith M3100X (3 channel)
Monoprice Monolith M2100X Amplifier Rear
Monoprice Monolith M2100X (2 channel)
These amps are not only designed to complement Monolith speakers, but other loudspeakers you may have or are considering.
What a Power Amplifier Is
The purpose of a power amplifier is to supply power and transfer audio signals to one or more speakers. However, It doesn’t have the extra features and connections you often find on a home theater receiver, such as a radio, input source switching, and audio/video (AV) processing. The only control you typically find on a power amplifier (apart from a power switch) is a primary gain control, which is analogous to volume.
Tip: Mononprice Monolith power amplifiers don’t have a gain control. That function is left up to a connected preamp or AV preamp/processor.
Power amplifiers come in a variety of channel configurations, from a single channel (aka Monoblock) that powers just one speaker, two-channel (stereo), or multi-channel (typically 3, 5, or 7 channels) for home theater applications.
However, to use a power amplifier, a separate preamp or AV preamp/processor is required to get audio signals from content sources to the power amplifier.
For example, an AV preamp/processor decodes or processes audio source signals and passes the signals to the power amp, which, in turn, sends the signals to the speakers. The signals are passed in analog form via line outputs using RCA-type connections or, in some higher-end preamp/power amplifier combinations, XLR connections.
Monoprice Monolith M3100X Amplifier Internal
Features in Common
Tip: The rest of this article refers to more technical information. Check on the provided links for more details on what they mean. Another source that will help is Understanding Amplifier Power Output Specifications
  • Amplifier Type: Class A/B
  • Input Connection Options: RCA, XLR
  • Power Output (Full Bandwidth @ 8 Ohms): 90 Watts per channel
  • Power Output (Full Bandwidth @ 4 Ohms): 135 Watts per channel
  • Tip: Speaker Load Impedance Safe from 4 to 16 ohms
  • EIA 1kHz Output Power at 8 Ohms: 155 Watts
  • Total Harmonic Distortion (THD): A Weighted < 0.02%
  • Frequency Response: 20Hz to 20Khz
  • Signal to Noise Ratio (SNR): A Weighted >100dB
  • Gain Range: RCA Input 28.5dB
  • Gain Range: XLR Input 28dB
  • Damping: >500
  • Input Impedance: 27 kOhms
  • Speaker Connections: 5-Way Binding Posts
  • Trigger Input:: 6 – 12 V (AC or DC); <10 mA input current required
  • Trigger Output: 12 VDC; can drive any load up to 120 mA
  • Dimensions (all three power amps): 21×5 x19.5 x 9.0-inches (545 x 490 x 230 mm)
Differences
Power Amp ModelM2100XM3100XM5100X
Number of Channels235
Net Weight29.5 lbs/13.4 kg32.4 lbs/14.7 kg35.5 lbs/16.1 kg
Price & Availability
5 Comments
5 Comments
  1. J. Allen
    August 5, 2023 at 11:55 am
    So far everything I have purchased that has the Monoprice label on it has been a disappointment.
    • Ian White
      August 5, 2023 at 12:00 pm
      Can you be more specific because I’ve purchased 3 things from them that have been rather great for the money.
      Best,
      Ian White
      • James
        August 6, 2023 at 9:57 pm
        Not just for the money, they beat out some higher prices brands on features and build quality
  2. Dave
    August 6, 2023 at 2:10 am
    I would expect a 2/3 channel to have more power than those but I have 2 of the monolith 12s and they have been fantastic. I just ordered the OSD 3 channel so I’m hoping those work out well for me.
    • James
      August 6, 2023 at 9:58 pm
      Just be aware, the XLRs on these new models are unbalanced so you get the same feature as an unbalanced RCA.
2026 LG Gallery TV Lifestyle
LG’s new Gallery TV takes aim at Samsung Frame, TCL NXTFRAME, and Hisense CanvasTV with MiniLED tech, Gallery+ art, and design-first appeal. Pricing TBD.
LG Xboom by will.i.am portable Bluetooth Speakers 2026 line-up LG Xboom by will.i.am portable Bluetooth Speakers 2026 line-up
LG expands its xboom by will.i.am lineup with the Rock, Mini, Blast, and Stage 501—bringing AI sound, rugged designs, and party-ready power to CES...
Pro-Ject Audio CD Box RS2 Tube Silver CD Player Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Focal quietly drops the $699–$2,299 Omada speakers between Vestia and Theva, packing TAM tweeters and Slatefiber cones in a non-typical rollout but with good...
Rega’s new Mercury and Solis flagship amps showcase peak engineering, but with a $50K full-system buy-in and no network amplifier in sight, the strategy...
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Your ticket to watching movies on a Kaleidescape 4K movie server just got a $1,000 cheaper, but are the trade-offs worth the discount?
The Mola Mola Ossetra is a $25,100 Class D mono amplifier delivering 350W into 8 ohms with ultra-low distortion, challenging Devialet in the high-end...
The Marantz AV 10 Preamp/Processor and AMP 10 Power Amplifier are capable of delivering 15.4 channels of surround sound.
MartinLogan Dynamo 10 Subwoofer delivers fast, controlled bass, wireless and wired options, ARC room correction, and furniture-friendly design for $1,199.
Edge Sound Research’s Embodied Sound System turns surfaces into full-range audio, delivering immersive tactile and music experiences without visible speakers.
