Monitor Audio’s Flagship Platinum 3G Speaker Lineup Celebrates 50 Years of Engineering Excellence
Celebrating 50 years of audio engineering excellence and success, the Monitor Audio Platinum 3G Series feature their latest driver technology and more.
Monitor Audio Platinum 3G Flagship Loudspeakers
First announced in August 2022, the Monitor Audio Platinum 3G flagship speaker series is finally available in time for Monitor Audio’s 50th anniversary. The British loudspeaker manufacturer has become one of the largest and most successful brands in high-end audio and their award-winning products are extremely popular overseas.
Tbe Platinum Series 3G builds on Monitor Audio’s legacy of delivering high-fidelity sound for discerning listeners with several innovations. The 3G line is designed to be at home in both audio-only and home theater applications.
There are four models available so far:
  1. Platinum 300 3G Floorstanding Speaker: $17,900 (pair)
  2. Platinum 200 3G Floortanding Speaker: $13,900 (pair)
  3. Platinum 100 3G Compact Bookshelf/Standmount Speaker: $6,900 (pair)
  4. Platinum C250 3G Center Channel: $5,900 (each)
Key Features
Here is a brief overview of what all the speakers in the 3G line share.
Monitor Audio Platinum 3G Tweeter
3RD Gen MPD III Tweeters: These high-frequency transducers employ a Micro Pleated Diaphragm (MPD). Using a square radiating area, this design reduces distortion, widens pass-band capability, and flattens frequency response for a wider, cleaner more consistent, and lifelike Sound.
Monitor Audio Platinum 3G Woofer
RDT III Cones: Used in the midrange and bass drivers, the RDT III Cones produce piston-like control even with the most extreme performances, providing a more precise, lifelike tonal balance and lower distortion.
Midrange Drivers: In addition to the cones, the midrange driver construction is optimized to ensure a completely smooth frequency transition with the tweeter. This is ideal for AV/Theater applications.
Crossovers: The crossovers are engineered to support the most exact and controlled sound performance across the full frequency spectrum.
Monitor Audio Platinum 3G Loudspeaker Rear Terminals
Bi-Amp/Bi-Wire Connectivity: This provides the ability to connect the HF and LF drivers to separate amplifiers if desired.
Rear Port: The 300, 200, and 100 models include a rear-facing tuned port for added low-frequency response. The C250 model is a sealed cabinet design that does not feature a port.
Monitor Audio Platinum 3G Loudspeaker Rear Port
Cabinet Design: The visually pleasing advanced cabinet design of the 3G series provides an acoustic eco-system that delivers comprehensive and accurate lifelike sound.
Available Finishes: Piano Black, Piano Ebony, and Pure Satin White
Monitor Audio Platinum 3G Loudspeakers Black
Monitor Audio ModelPlatinum 300 3GPlatinum 200 3GPlatinum 100 3GPlatinum C250 3G
MSRP$17,900/pair$13,900/pair$6,900/pair$5,900 each
Description FloorstandingFloorstanding Bookshelf/StandmountCenter Channel
Speaker Type3-Way Bass Reflex3-Way Bass Reflex2-Way Bass Reflex3-Way Sealed
Woofer (RDT III)2 x 8” 2 x 6″1 x 6″2 x 6″
Midrange (RDT III)1 x 4″1 x 4″None1 x 2.5″
Tweeter (MPD III)1111
Frequency Response (-6B In-Room)17Hz – 60 kHz​23Hz – 60 kHz28Hz – 60 kHz​30Hz – 60kHz​
Port Tuning Frequency32Hz38Hz44HzNo Port
Crossover Frequency650Hz, ​3kHz825Hz​, 3kHz2.85kHz850Hz ​
Nominal Impedance4 ohms​ 4 ohms4 ohms3.5 ohms
Sensitivity (2.83 Vrms @ 1m, Free-Field)​​88 dB88 dB85 dB88 dB
Recommended Amp Power (RMS)200 – 800 W​150 – 600 W75 – 300 W​150 – 600 W
Dimensions (HWD) – With Spikes1131.1 x 429.8 x 525 mm​
(44.5 x 16.9 x 20.6″)
1041.6 x 368.7 x 454.9 mm​
(41 x 14.5 x 17.8″)
398 x 225 x 325.6 mm​
(15.6 x 8.8 x 12.8″)
225 x 630 x 325.7 mm​
(8.8 x 24.8 x 12.8″)
Weight53.6 kg​
(118 lb 2 oz)
35.8 kg​
(78 lb 14 oz)
15.2 kg​
(33 lb 8 oz)
25.4 kg​
(55 lb 15 oz​)
Availability and Pricing
Monitor Audio’s Platinum 3G Speakers are available through authorized Retail, Online, and Installation Dealers.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
The Atelier program gives Bang & Olufsen's customers the chance to style their own speakers. The Beosound 2 Gradient Collection gets things started.
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
Zu Audio hints of new products to debut at Capital Audio Fest from November 8-10, 2024, but photos and details are scarce.
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
At $279.99, the Creative Pebble Nova desktop speakers feature coaxial drivers with both wireless and wired connectivity.
