Preview: Monitor Audio Introduces Gold Series 6G Loudspeakers
Priced from $2,250 to $7,000 per pair, Monitor Audio’s Gold Series 6G loudspeakers include six models for stereo or home theater setups.
Monitor Audio 6G Series Loudspeakers Black
For over 50 years, Monitor Audio has been producing high quality loudspeakers speakers from Cambridge, England. The company continues to innovate with a steady flow of product updates. Just this year they’ve released the Studio 89 stand-mount loudspeakers along with an outdoor Climate Series range of speakers. But today the company is updating their Gold Series loudspeaker line priced from $2,250 to $7,000 per pair.
Now in its 6th generation, the new Monitor Audio Gold Series 6G replaces the Gold Series 5G from 2019. The new range brings of host of innovations implemented from the company’s flagship Platinum Series and Hyphn loudspeakers, while adding an on-wall speaker option.
Monitor Audio Gold On-Wall 6G Speakers in High Gloss Black
Monitor Audio’s Gold Series 6G is currently sandwiched between the Silver Series 7G and Platinum Series 3G, and is designed to offer two-channel and home theater solutions at competitive price points in contemporary finishes.
There are six models in the Gold Series 6G Speaker line-up:
  • Gold 50 6G Bookshelf Speaker ($2,250/pair)
  • Gold 100 6G Bookshelf Speaker ($4,000/pair)
  • Gold 300 6G: Floorstanding Speaker ($5,250/pair)
  • Gold 500 6G: Floorstanding Speaker ($7,000/pair)
  • Gold On-Wall 6G On-Wall Speaker ($2,700/pair)
  • Gold C250 6G Center Channel Speaker ($2,250/each)
Monitor Audio Gold 300 6G Loudspeakers in Satin White
Gold 6G Features
Here is a brief overview of what all the speakers in the Gold Series 6G line share.
Transparent Design Philosophy: The Gold Series 6G speakers carry on Monitor Audio’s R&D approach of maintaining a balance between design and technology, both equally important.
Musical neutrality and acoustic transparency are balanced within physical speaker designs to provide optimized blending into the environments the speakers will be used in.
Monitor Audio Gold 6G Series Woofer Assembly
Metal Cones: The Gold Series 6G incorporates a new metal cone in the form of Hexagonal Diaphragm Technology (HDT). HDT draws on the RDT III cones utilized in the ground-breaking Hyphn and the flagship Platinum Series 3G, which consists of a Nomex honeycomb layer sandwiched between aluminum and carbon fibre skins.
The HDT cone employs a new hexagonal pattern to disrupt symmetries in the cone breakup, creating a cone that shifts the frequency up by 10% compared to the RST II cones found on the Silver Series 7G.
The new cone also incorporates Monitor Audio’s proprietary C-CAM technology which supports a stronger, more fatigue-resistant cone.
The result is that the new HDT, C-CAM cones are among the strongest, most piston-like cones Monitor Audio has engineered so far.
The HDT and C-CAM cones are used across the 6G model range, including a new 3-inch mid-frequency driver, a 6-inch bass-mid unit, and 6- and 8-inch bass drivers.
Monitor Audio Gold 250C 6G Center Channel Speaker in Satin White
Monitor Audio Gold 100 6G Loudspeakers in Macassar
Monitor Audio Gold 6G Series Tweeter Assembly
Tweeter Tech: In addition to the HDT, and C-CAM cones, for high frequencies, a revised version of Monitor Audio’s MPD III (Micro Pleated Diaphragm) transducer is used (this is similar to the tweeters used in the Hyphn and the Platinum Series speakers)  This design delivers precise high-frequency sound with greater consistency, clarity, and accuracy.
Monitor Audio Gold 6G Series Crossover Design
Crossover Design: The Gold Series 6G’s crossovers have been optimized for in-room performance. This especially supports better performance for the new On-Wall 6G model, where usage is closer to Custom Install than traditional Hi-Fi.
Cabinet Design: All the Gold Series 6G’s cabinets are designed to form the most rigid structure possible allowing the drivers to perform to their optimum capabilities. A top trim detail on the 100 and 500 models allows the MPD III high-frequency transducer to be placed further up the cabinet.
This supports better cabinet edge diffraction on these larger models. This helps deliver consistent and precise imaging across the entire frequency range.
Gold 6G Comparison
Monitor Audio Gold 6G Series Loudspeakers Black Front
ModelGold 50 6GGold 100 6GGold 300 6GGold 500 6GGold On-Wall 6GGold C250 6G
Price$2,250/pair$4,000/pair $5,250/pair$7,000/pair$1,350/each$2,250/each
Speaker EnclosureBookshelfBookshelfFloorstandingFloorstandingOn-WallCenter
Speaker Type2-Way3-Way3-Way3-Way2-Way3-Way
Sensitivity85 dB86.5 dB87 dB88.5 dB88 dB87.5 dB
Recommended Amp Power (4 ohms)130 – 300 W130 – 500 W130 – 500 W130 – 600 W130 – 300 W130 – 500 W
Continuous Power Handling (CTA-426-8)150 W250 W250 W300 W150 W250 W
Nominal Impedance4 Ohms4 Ohms4 Ohms4 Ohms4 Ohms4 Ohms
Minimum Impedance (20Hz to 20kHz)4.0 Ohms @ 225 Hz3.9 Ohms @ 140 Hz3.9 Ohms @ 165 Hz4.0 Ohms @ 150 Hz5.3 Ohms @ 200 Hz4 Ohms
Bass Driver1 x 8” (203 mm)
HDT C-CAM Bass Drivers
2 x 6” (152 mm)
HDT C-CAM
2 x 8” (203 mm)
HDT C-CAM
2 x 6” (152 mm)
HDT C-CAM
Mid-Bass Driver1 x 6” (152 mm)
HDT C-CAM
1 x 6” (152 mm)
HDT C-CAM
Midrange Driver1 x 3” (76 mm)
HDT C-CAM Mid-Range Driver
1 x 3” (76 mm)
HDT C-CAM
1 x 3” (76 mm)
HDT C-CAM
1 x 3” (76 mm)
HDT C-CAM
Tweeter1 x MPD III Tweeter1 x MPD III Tweeter1 x MPD III Tweeter1 x MPD III Tweeter1 x MPD III Tweeter1 x MPD III Tweeter
Lowest Frequency Response, Free-Field (-6dB)55 Hz49 Hz45 Hz44 HzN/A64 Hz
Frequency Response, In-Room (-6dB)44Hz-60kHz32Hz-60kHz28Hz-60kHz25Hz-60kHz38Hz-60kHz54Hz-60kHz
Max Peak SPL (AES75, 2-weighted)114 dB119 dB117 dB122 dB115 dB121 dB
Bass AlignmentHiVe II Ported HiVe II PortedHiVe II Ported HiVe II Ported PortedSealed
Port Tuning Frequency50 Hz38 Hz35 Hz33 Hz44 HzN/A
Crossover FrequencyLF/HF: 2.5 kHzLF/MF: 700 Hz
MF/HF: 2.6 kHz
LF/MF: 800 Hz
MF/HF: 2.7 kHz
LF/MF: 700 Hz
MF/HF: 2.6 kHz
LF/HF: 2.5 kHzLF/MF: 800 Hz
MF/HF: 2.7 kHz
Dimensions320 x 185 x 303 mm
12 5/8 x 7 5/16 x 11 15/16”
447.7 x 230 x 357.3 mm
17 15/8 x 9 1/16 x 14 1/16”
1098 x 339 x 463 mm
43 1/4 x 13 3/8 x 18 1/4”
1155 x 383 x 475 mm
45 1/2 x 15 1/16 x 18 11/16”
465 x 300 x 124.2 mm
18 5/16 x 11 13/16 x 4 7/8”
205 x 537 x 335 mm
8 1/16 x 21 1/8 x 13 3/16”
Weight (each)8.5 kg
(18 lbs, 12 oz)
14 kg
(30 lbs, 14 oz)
21.2 kg
(46 lbs, 12 oz)
26.5 kg
(58 lbs, 7 oz)
9 kg
(19 lbs, 14 oz)
15.3 kg
(33 lbs, 12 oz)
Finish Options For All Gold Series 6G Speakers: High-Gloss Black, Satin White, or Macassar
Monitor Audio Gold 6G Series Loudspeakers Macassar Rear
Rear view of Monitor Audio Gold 6G Series Loudspeakers in Macassar Finish
Initial Impressions
With key innovations from Monitor’s flagship lines making it into the Gold 6G series, it makes a strong case. However, it does enter a very competitive field in the under $7,000 (USD) loudspeaker segment with competition from the Bowers & Wilkins 700 S3 Series, the Focal Aria Evo X Series and the KEF R Meta Series, among others.
On the other hand, the Gold Series 6G offers significant cost savings over the flagship Platinum series, and may even narrow the performance gap. We’re definitely intrigued and hope to get a listen soon.
Monitor Audio Gold 6G Series Model 500 Loudspeakers in High Gloss Black
Availability & Pricing
The Monitor Audio Gold Series 6G loudspeakers are available now through authorized retail, online, and installation dealers at the following prices.
Monitor Audio Gold 50 6G Bookshelf Speakers in Satin White
Tip: Optional ST-2 Stand for the Gold 50 and 100 6G speakers: $750,  £550,  €675 per pair
For more information: monitoraudio.com/en/gold-series-6g/
Related Reading
2 Comments
2 Comments
  1. Nait
    August 18, 2024 at 11:15 am
    The 100 6G!
    But what is with the 130w into 4ohm minimum power requirement?
  2. Kevin C
    August 24, 2024 at 12:52 am
    With these prices, they better sound less pedestrian than they look.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
Zu Audio hints of new products to debut at Capital Audio Fest from November 8-10, 2024, but photos and details are scarce.
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
