Preview: Monitor Audio’s Climate Series 3G Outdoor Speakers Can Be Used Anywhere
Available in two sizes, Climate Series 3G weatherproof speakers are rugged enough for the outdoors and versatile for indoor mounting.
Monitor Audio Climate 3G Series Outdoor Speakers in Black and White
The CI loudspeaker category continues to grow in 2024 with a new range from Monitor Audio. The British manufacturer has announced the Climate Series 3G outdoor speakers which are designed to deliver high-end performance regardless of where you install them.
Let’s take a look at what the Climate Series 3G speakers might be able to offer you.
Monitor Audio is initially offering up two models: Climate Medium (CL2 M) and Climate Small (CL2 S)
Climate Series 3G
Monitor Audio Climate 3G Series CL2 M Outdoor Speakers in Black and White Lifestyle
Here is a roundup of core features that both speakers in this series share.
Transparent Design Philosophy: The Climate Series 3G speakers carry on Monitor Audio’s R&D approach of maintaining a balance between design and technology, both equally important. Musical neutrality and acoustic transparency are balanced within physical speaker designs to provide optimized blending into the environments the speakers will be used in.
Monitor Audio Gold Dome Tweeter
C-CAM Gold Dome Tweeter: Since its first appearance in Monitor speakers in 1982, C-CAM tweeters have been refined to deliver better clarity, realism, and detail. This is especially important given the need to provide the best possible highs for both outside and inside listening environments. In addition, the Climate Series 3G features an enhanced gold C-CAM dome which is coated in a deep black finish.
Monitor Audio RST II Woofer
Bass-Mid Driver: Incorporating Rigid Surface Technology II (RST II) the Mid-bass driver provides pistonic motion for optimal realism and clarity, and a precise high-fidelity, life-like sound that delivers enhanced audio listening.
Auxiliary Bass Radiator: For enhanced lower frequency response the Climate Series 3G series speakers incorporate a large, sealed Auxiliary Bass Radiator (ABR) – aka Passive Radiator, on the rear of each model.
The ABR panel is concave complemented with Monitor Audio’s signature Hex pattern. The ABR works like a sealed port tube. It prevents environmental elements from entering the speaker enclosure but supports lower bass frequencies to exit providing similar bass support that a port would provide.
Crossover Design: Speakers that employ tweeter and midrange/woofers need a good crossover to provide a smooth transition from lower to higher frequency reproduction. In the case of the Climate Series 3G, the crossover has been designed, voiced, and tuned by Monitor Audio’s in-house acoustic engineering team.
Sealed Enclosure: The Climate Series 3G speakers incorporate a one-piece molded cabinet, made from dense ABS (Acrylonitrile Butadiene Styrene) and reinforced with glass fiber, protecting the important elements within for a lifetime of use.
A large Auxiliary Bass Radiator (ABR) and fully sealed front baffle housing the drive units, ensure the whole design can withstand the harshest of weather conditions.
Monitor Audio Climate 3G Series Outdoor Speakers in Black Back and Side
Quik-Link Bracket System: To ensure easy and sturdy wall mounting, the Climate Series 3G incorporates a die-cast aluminum bracket. Lightweight and strong, this allows the speakers to be positioned almost anywhere. The bracket design allows a Climate Series 3G speaker to be rotated through 180 degrees in both the vertical and horizontal plane – so it can be ‘aimed’ into the desired listening location.
Monitor Audio Climate 3G Series Outdoor Speakers in White Rotate Angle
The bracket design allows Climate Series 3G speakers to be rotated 180-degrees.
IP66 Rating: The Climate Series 3G speakers have an IP66 rating. This means users can place the speakers outdoors safely to enjoy a great audio listening experience.
Climate Medium – CL2 M
Climate Medium is a mid-sized, two-way design that incorporates a 25mm (1”) black C-CAM dome tweeter and a 165mm (6”) RST II bass-mid driver, supported by an Auxiliary Bass Radiator (ABS). Its Quik-Link bracket system makes installation easy. The contemporary design blends in as seamlessly with both outdoor and indoor settings.
Monitor Audio Climate 3G Series Medium Outdoor Speakers in White Lifestyle
Climate Medium CL2 M
Climate Small – CL2 S
The Climate Small is designed to support a great listening experience despite its compact size. The two-way design incorporates a 25mm (1”) black C-CAM dome tweeter and a 100mm (4”) RST II bass-mid driver, supported by an Auxiliary Bass Radiator (ABS). It has the same ‘Quik-Link’ bracket system and contemporary design as the CL2 M.
Monitor Audio Climate 3G Series CL S Outdoor Speakers in White
Climate Small CL2 S
Climate Series 3G Speakers Comparison
Climate Medium – CL2 MClimate Small – CL2 S
Price (pr)$900$750
Speaker Type2-Way2-way
Enclosure Type SealedSealed
Tweeter1 x 25 mm (1”) C-CAM black dome tweeter1 x 25 mm (1”) C-CAM black dome tweeter
Mid-Bass1 x 165 mm (6”) C-CAM RST II bass-mid driver1 x 100 mm (4”) C-CAM RST II bass-mid driver
Auxiliary Bass RadiatorYesYes
Recommended Amplifier Power​ (RMS)200 W150 W
Continuous Power Handling (CTA 426-B)100 W70 W
Nominal Impedance6 Ohms6 Ohms
Frequency Response, On-Wall (-6dB)42Hz – 30kHz56Hz – 30kHz
Maximum Peak SPL (AES75, Z-weighted)110 dB108 dB
Sensitivity (2.83v @ 1m, Installed)85.5 dB84 dB
Crossover Frequency2.6 kHz3.3 kHz
IP RatingIP66IP66
External Dimensions with all accessories fitted
(HxWxD)
332 x 190 x 240 mm
(131/16 x 71/2 x 97/16″)
247 x 140 x 217 mm
(93/4 x 51/2 x 89/16″)
Weight (each)4.1 kg
(9 lbs, 1 oz)
2.7 kg
(5 lbs, 15 oz)
Finish Matt Black, Matt WhiteMatt Black, Matt White
Initial Impressions
One thing that turns me off with some outdoor speakers is that they sound like outdoor speakers. However, it looks like Monitor Audio has made an effort to bring indoor speaker performance to an outdoor design by incorporating key technologies present in its higher-end speaker products.
That being said, the Climate Series 3G speakers carry reasonable price points that should make them highly competitive in the CI and commercial categories.
The icing on the cake may be that they offer high-end sound quality that will make them ideal for home gyms, home theater spaces, and even your home office if you prefer a wall-mounted option.
Monitor Audio Climate 3G Series CL2 S Outdoor Speakers in White Back
Climate CL2 S
Pricing & Availability
The Climate Series 3G speakers will be available beginning in September 2024 through authorized Monitor Audio retail, online, and installation dealers.
Related Reading
1 Comment
1 Comment
  1. N.B.
    August 7, 2024 at 2:48 pm
    Mom can we have the Bowers & Wilkins AM-1?
    No, we have the Bowers & Wilkins AM-1 at home.
    At home…
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
The new Roksan Caspian 4G Integrated Amplifier arrives at $3,750, while the Caspian 4G Streaming Amplifier will set you back $5,000.
Priced from $2,250 to $7,000 per pair, Monitor Audio's Gold Series 6G loudspeakers include six models for stereo or home theater setups.
A/V Furniture & Accessories
Blok delivers modern and stylish ways to showcase audio and home theater gear with new Stax 2G Shelf Collection.
At $2,500/pair, the Monitor Audio Studio 89 bookshelf speaker combines inspiration from the past with flagship Hyphn technology.
Theory Audio Design has adapted its award-winning in-ceiling and subwoofer drivers for outdoor use.
For those seeking the ultimate in high fidelity music playback, the ultra luxury high-end audio market continues to innovate with loudspeakers at jaw dropping...
In-Wall Speakers
The outdoor CI market is hot and rather wet apparently. The DALI PHANTOM E-60 and E-80 WR in-ceiling speakers will be available from March,...
