M&K Sound Introduces V+ Series Subwoofers
M&K adds three V+ Series models in 10, 12, and 15-inch sizes for 2022. Find out what they have to offer for your home theater setup.
M&K Sound V+ Subwoofers 2022
M&K Sound (aka Miller & Kreisel) is one of the historical inventors of the subwoofer and has never lost its touch as its subs continue to provide leading-edge performance and design.
Following up on the introduction of their X+ high-end subwoofer series, M&K has announced three new “midrange” V+ Series subwoofers in the 10, 12, and 15-inch sizes. Let’s take a look at what this trio of subwoofers offers.
M&K Sound V+ Subwoofers Front 2022
M&K Sound V+ Series Subwoofer Features
THX Certification: While the V10+ is designed to deliver good performance, it’s not THX Certified. However, the V12+ and 15+ are THX certified. This means that these subwoofers have been submitted and passed THX standards for application and performance.
THX Certification Process
The V12+ is THX Select Certified which means it is optimized for rooms up to 2,000 cubic feet and a 10-foot viewing distance from the screen.
The V15+ is THX Ultra Certified which means it is optimized for rooms up to 3,000 cubic feet and a 12-foot viewing distance from the screen (when two V15+ subwoofers are used together).
THX Certified Performance Classes
Subwoofer Design: The V+ series subwoofers all feature a single driver/sealed cabinet design.
Cabinet Construction: The V+ Subwoofers have a 1-inch thick MDF cabinet with 1 1/2inch Baffle and a full center brace/woofer magnet support.
Speaker Driver Construction: The V+ Drivers have a reinforced steel frame, ceramic magnet, honeycomb treated paper cone with fiberglass dust cap.
Amplification: Class D power amplifiers are incorporated into all three subs with the following power output capabilities:
  • V10+: 300 Watts RMS/600 Watts Peak
  • V12+: 400 Watts RMS/800 Watts Peak
  • V15+: 500 Watts RMS/1000 Watts Peak
Low-Frequency Extension: Under optimum conditions, the V10+ and V12+ reach down to 25Hz, and the V15+ goes down to 20Hz.
M&K Sound V15+ Subwoofer Rear
M&K Sound V15+
M&K Sound V12+ Subwoofer Rear
M&K Sound V12+
M&K Sound V10+ Subwoofer Rear
M&K Sound V10+
Crossover Frequency (Adjustable): 60-200 Hz (V10+), 43 -300Hz (V12+), 42-300Hz (V15+)
App Control: Both the V15+ and V12+ subwoofers enable configuration via the downloadable M&K Professional Control App (iOS or Android).
Available app settings include:
  • Volume Control
  • Night Mode
  • THX Mode (V12+ and V15+)
  • Music and Movie Modes
  • Low Pass Filter
  • Phase
  • Delay
  • Four band Parametric EQ
  • Auto Room Equalization
  • Power control settings
Finish: Black Satin or White Satin
Dimensions (HWD – All Sides): 13.6 in/345mm (V10+), 15.6 in/395mm (V12+), 18.5in/470mm (V15+)
Weight:  34.0 lbs/15.4 kg (v10+), 35.9 lbs/16.3 kg (v12+), 46.3 lbs/21.0 kg (v15+),
M&K Sound V15+
M&K Sound V12+
M&K Sound V10+
Pricing and Availability:
The V+Series will become available in February 2022 from authorized M&K Sound distributors/dealers at the following U.S. MSRPs. Each model is available in black satin or white satin finishes.
  • $1,499 (V10+)
  • $1,899 (V12+)
  • $3,199 (V15+)
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
The eCoustics editorial team grows to its largest point ever, adding coverage for new music releases and custom installation A/V solutions.
