In-Wall Speakers
M&K Announces IW150A In-Wall/In-Ceiling Speaker
The M&K Sound IW150A in-wall/ceiling speaker provides installation flexibility for use with Dolby Atmos or standard surround sound configurations.
M&K Sound IW150A In-Wall Speakers
M&K Sound has announced an addition to its in-wall/in-ceiling speaker line, the IW150A.
What makes this speaker a little different is that can be used as a ceiling height speaker in addition for use as an in-wall surround or LCR (Left, Center, or Right channel) speaker.
M&K Sound IW150A In-Wall Speaker Wide
The IW150A includes a 15-degree fixed-angled tweeter and 5.7-degree fixed-angle pair of woofers, which are designed to produce a good off-axis response. This design approach the IW150A provides flexibility for home theater installers.
M&K states that the IW150A is ideal for use as a height channel for Dolby Atmos, DTS:X, or Auro3D audio setups. The speaker can also be used angled down- or angled up-firing for LCR applications where placement locations may be limited (such as above or below a flat-panel display), or as an in-wall or in-ceiling-based surround or music speaker.
The IW150A supports a 30-degree voicing angle but its vertical dispersion enables an optimal listening window of +/- 30 degrees (+/- 2dB) from the line of sight, with a vertical dispersion window of +/- 45 degrees. Horizontal dispersion extends to +/- 60 degrees.
M&K Sound IW150A In-Wall Speaker Angle Left
The IW150A can produce room-filling sound pressure levels (SPL) in rooms of up 3,000 cubic feet (85 cubic meters).
Whether the speaker is used as a height or surround channel, listening hotspots are mitigated and more audience members can experience even audio coverage throughout the seating area. Wide horizontal dispersion also makes the speaker well-suited as an in-wall home cinema LCR, optimizing both dialogue intelligibility and front soundstage effects placement.
IW150A boasts M&K Sound’s signature sonic neutrality and timbre matching, which aids many home theater installers in providing the optimum speaker setup for their customers.
M&K Sound IW150A In-Wall Speaker Front and Back
IW150A Specifications
  • Product Number: IW150A
  • Speaker Design: Two-way, In-wall, Sealed Cabinet
  • Tweeter: 1x 25mm silk dome with neodymium magnet
  • Tweeter Angle: 15 degrees fixed
  • Woofer:  2 x 5.25-inch coated glass fiber
  • Grill Color: White (metal construction)
  • Impedance: 4 Ohms
  • Frequency Response: 80Hz to 20kHz ±3dB
  • Sensitivity: 90 dB (2.83V/1m)
  • Crossover: 2 kHz
  • Max Peak SPL: 116 dB
  • Power Handling: 90 to 180 watts
  • Amplifier Power Range: 25 to 400 watts
  • Terminals: Gold Plated Push Terminal (accommodates 4mm speaker cable)
  • Cutout Dimension Requirements (H x W): 13.03 x 11.33 inches (331 x 288 mm)
  • Cabinet Dimensions (H x W): 12.95 x 11.25 inch (329 x 286 mm)
  • Cabinet Depth: 3.74 inches (95 mm)
  • Grille Dimensions (H x W): 14.17 x 12.48 inches (360 x 317 mm)
  • Weight: 21.6 lbs (9.8 Kg)
Tweeter Construction
M&K Sound IW150A Custom Designed Bass Driver
Woofer Construction
Pricing & Availability
The M&K Sound IW150A has a suggested retail price of $1,099 (USD)/£1,295 (GBP) and will be available from M&K Sound authorized distributors from early October 2022.
Tip: If you don’t have experience installing in-wall or in-ceiling speakers, you should consult a home theater installer regardless of brand or model.
For more information: mksound.com
Relating Reading
Focal Unveils 100-T Series In-ceiling and Outdoor Speakers: CEDIA 2022
DALI Phantom K-60 LP & M-675 In-Wall Speakers: CEDIA 2022
Perlisten Audio Announces World’s First In-Wall Speakers With THX Dominus Certification
Monoprice Introduces Monolith THX In-Wall Speakers
DALI Introduces New Phantom K-Series In-Ceiling And H-R Series In-Wall Loudspeakers
Monoprice Announces Monolith In-Wall Subwoofers
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Treat the audio enthusiast in your life to the best DTS-powered products this holiday season.
Sony just unveiled two new entry-level Dolby Atmos-compatible soundbars for those who want to beef up their TV sound without breaking the bank.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Close To Perfect, Expanded Atmos Mix Takes Yes Surround Sound To Immersive Heights.
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
