Commercial-Grade 65-inch LCD Monitor With Front and Rear Light Sensors and Built-in CAT5 Receiver
Mitsubishi’s new MDT651S 65-inch LCD monitor is their first monitor that is IP-addressable for easy control and management, using Mitsubishi’s own networking software. The new MDT651S monitor is designed for traditional conference room visual display as well as for videoconferencing and digital signage applications.
“Our new 65-inch completes our LCD monitor product line,” said James Chan, senior director, product marketing, Mitsubishi Digital Electronics America’s Presentation Products Division. “Whether it is for digital signage, lobby displays or conference room visuals and videoconferencing, the MDT651S large-sized monitor fits the bill with its sleek design and high-quality finish, not to mention the crisp, clear images you’ll see when it’s in use.”
Unlike many digital commercial displays on the market today, Mitsubishi’s MDT651S 65-inch LCD is one of the first monitors to offer both front and rear ambient light sensors that detect lighting conditions in two areas. These sensors adjust the monitor’s brightness level based on its readings and automatically balance image brightness for optimum viewing, regardless of the brightness of the ambient light either in front of, or behind the monitor.
When installed in venues where lighting changes constantly, the owner realizes energy savings through reduced power consumption when the ambient lighting turns darker. When the sun comes out, brightness in the monitor’s display is automatically increased to create the best possible image in the new lighting condition.
Mitsubishi’s new 65-inch LCD monitor streamlines installation and reduces the number of necessary components. It also eliminates cable clutter with its built-in CAT5 receiver that keeps image quality consistent, even with cable lengths of up to 500 feet or 150 meters between source and display. Video and RS-485 serial-control signals can be simultaneously delivered over the same CAT5 cable, eliminating the need for a separate, distance-limiting serial-control cable. Users can also daisy chain up to five monitors, making content delivery easy and more efficient.
The 65-inch monitor has a narrow aluminum bezel that is stylish and classy, reducing image distortion in tiled installations, and can be tiled up to 25 displays in a five-wide by five-high configuration. A frame compensation function also helps adjust for the width of the bezels so images are accurately displayed. The structural design of the monitor allows for landscape and portrait display for unique, innovative, eye-catching installations.
Panel service life is extended while saving energy by using the 65-inch LCD monitor’s new programmable scheduling and multi-level screen saver functions. Up to seven different intervals by time, day of the week, input port and separate content feeds can be programmed. Displays can be automatically turned on or off or set to one of four screen saver levels. The cooling fan is also automatically activated when internal temperatures reach a pre-designated limit.
Image quality and flexibility are a hallmark of Mitsubishi’s new 65-inch LCD monitor. It offers a wide range of color temperature adjustments as well as a six-axis color fine-tuning function. This precise level of color control allows independent hue and saturation modifications, which is important in creating exact color images, particularly in broadcasts, retail food imagery, digital posters and logo reproduction.
The new monitor offers full high-definition 1920 x 1080 resolution for clear, accurate computer graphics and HD video with a 700 cd/m2 high brightness, 2000:1 high-contrast screen that delivers impressively sharp, vivid images and information, even in brightly lit public spaces. Picture-in-picture, picture-out-of-picture, and side-by-side image configurations are supported, enabling video and presentation content to be displayed simultaneously, an ideal feature for broadcasting and videoconferencing applications.
Mitsubishi’s 65″ LCD monitor is competitively priced (check price) and available now through authorized Mitsubishi dealers. The monitor is covered for three years by Mitsubishi’s limited warranty program backed with an advanced express replacement program that allows for convenient servicing and replacement at a customer’s designated schedule.
