Mitsubishi HC8000D and HC7800DW DLP Projectors
Mitsubishi HC8000D DLP Projector
Mitsubishi has introduced the HC8000D and HC7900DW home theater projectors, which use the latest DLP .065-inch DMD chip to create vibrant 2D and 3D images in Full HD 1080p resolution. An ultra-hushed fan in each creates 23 dBa in low mode, so viewers only hear quiet dialogue or soft music during a movie or television show, not an annoying fan hum.
The HC7900DW and HC8000D projectors use one of the industry’s best 2D-to-3D Frame Rate Conversion technologies, resulting in a near-perfect simulation of a true 3D frame of vision. Using Mitsubishi’s own algorithms in calculating and interpolating multiple depth levels in a 2D image, this new, high-speed frame reproduction technology produces detailed, high-definition 3D images with minimum crosstalk or distortion so 3D content appears to literally jump off the screen, even in high-speed action scenes.
[youtube id=”MqOo4G3bJEA” width=”610″ height=”373″]
The HC8000D supports Mitsubishi’s proprietary 3D glasses (sold separately), but both models are compatible with Universal 3D glasses, making family viewing easy and more affordable. The projectors also allow friends to watch 3D sporting events like football games in a party atmosphere, with attendees bringing their own 3D glasses.
Mitsubishi’s HC8000D boasts an impressive 330,000:1 contrast ratio for rich details, even in darkly-lit movies or film noir and 1300 lumens of brightness, making it a great option for gaming. Its extra-long lamp life, up to 5000 hours in low mode, can provide years of movie, television and gaming enjoyment, depending on usage.
The new HC7900DW projector features 150,000:1 contrast ratio, 1500 lumens of brightness and up to 5000 hours of lamp life as well. It comes in a white cabinet, and when installed, can easily match the aesthetics of a white ceiling.
Mitsubishi HC8000D - back
Two of the latest HDMI version 1.4 inputs in each projector support 3D signals as well as provide easy set-up options for multiple video inputs. The projectors’ RS232 support offers plug-and-play connectivity for easy integration with third-party remote operations and control in higher-end installations.
Price and Availability
Mitsubishi HC8000D → check price
Mitsubishi HC7900DW → $2,499
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
